Topic: Arduino on a breadboard does not compile [solved] (Read 1 time) previous topic - next topic
storm
Sep 18, 2012, 01:40 pm Last Edit: Sep 19, 2012, 11:32 am by Nick Gammon Reason: 1
Hi
I've got an arduino duemilanove, and I'm following the instructions here: http://arduino.cc/en/Tutorial/ArduinoToBreadboard.  I've download the breadboard.zip file and extracted it into /hardware/breadboard/ in my arduino sketch folder.  However when I come to verify any sketch using the "ATMega328 on a board (8MHz internal clock)" board, I get the following error:
I don't get this error when I verify a sketch using any other board.
I'm using arduino v 1.0.1 and OS X 10.8.1
Can anybody help?
Thanks
Dave
James C4S
I don't see an error.
Copy/paste it or attach the picture (under additional options)
storm
I put it in my original post with the [img] tags, the picture is here: http://i.imgur.com/Ngxke.png
storm
to anybody who has issues, I've solved my problems by reading this: http://flashgamer.com/arduino/comments/using-your-arduino-as-an-isp
The whole lot is worth a read, however the important bit for this problem is:
Problem:
"pins_arduino.h: No such file or directory"
Solution:
Copy the contents from the downloaded boards.txt in your src/hardware folder to the boards.txt in App folder instead. On OSX: right click the Arduino app and browse Contents/Resources/Java/hardware/arduino/boards.txt.
You may also need to add the line below after the other text you pasted as it's missing in the downloadable example file:
atmega328bb.build.variant=standard
