Loading...
Pages: [1]   Go Down
Author Topic: what happens if...  (Read 319 times)
Offline Offline
God Member
View Profile
if the ldr was connected 5v ~~~~ 1k ~~~~ ldr ~~~ A1
does the voltage divider  no longer work? A1 should act as gnd no?
« Last Edit: September 16, 2012, 11:48:01 pm by cjdelphi » Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
A1 is not connected tho.
A0 might act as ground if you used
digitalWrite(D14, LOW);
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
SF Bay Area (USA)
Offline Offline
Faraday Member
Strongly opinionated, but not official!
View Profile
Typically, an input pin (analog or digital) will NOT "act as ground"; inputs are almost an open-circuit.
Logged
Offline Offline
God Member
View Profile
digitalWrite(A1, LOW);  //as suggested should do it though....
Turning the pins to low saves a lot of work using an extra pin smiley - ok cool thanks
Logged
Anaheim CA.
Offline Offline
Edison Member
Experienced old Whitebeard with a Full head of Hair...
View Profile
Also would Guarantee the circuit operation... You would Know what state it was in... just by looking at the sketch.
Doc
Logged
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
South Texas
Offline Offline
God Member
View Profile
Okay - I'll ask - why do you want to use A1 (or A0) as a ground?
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
I can think of a few examples where one might want to use two output pins to drive a device. Say a two color led that activates one color or the other depending on direction of current flow, or simulate a third combined color be switching the two output pins at significant clocking speed. I've used a small 20ma single coil latching relay where I could select to set or reset the relay depending on current direction, or once set or reset I could place both outputs to the same state to allow for zero current consumption for the relay. There are other applications where it might be useful to 'power' a device via two output pins, it just has to have a maximum current draw less then the output pins are rated for.
Lefty
Logged
Pages: [1]   Go Up
Print
Jump to:
