Topic: First line of serial communication distorted (Read 1 time) previous topic - next topic
Tentationem
Hello,
I'm trying to communicate with my arduino  through the posix serial library.
It kind of works  but the first line is distorted.
It should print "flamingo:" in the console
but most of the time I get stuff like
flamflamingo
or
fflamingo
that's for the first line
the other lines seem to work well.
I've seen this happening in the arduino serial monitor too but only on rare occasions...
Here is the code I'm using
Code: [Select]
#include <stdio.h>    /* Standard input/output definitions */
#include <stdlib.h>
#include <stdint.h>   /* Standard types */
#include <string.h>   /* String function definitions */
#include <unistd.h>   /* UNIX standard function definitions */
#include <fcntl.h>    /* File control definitions */
#include <errno.h>    /* Error number definitions */
#include <termios.h>  /* POSIX terminal control definitions */
#include <sys/ioctl.h>
#include <getopt.h>
int serialport_init(void);
int main()
   int fd = 0;
   char buf[256];
   int n;
   int i;
    char b[1];
    int wloopc=0;
  fd = serialport_init();
   while(wloopc<1){
    i=0;
    while( b[0]!='\n' ) {
         n = read(fd, b, 1);  // read a char at a time
        if( n==-1) break;    // couldn't read
        if( n==0 ) {
            usleep( 10 * 1000 ); // wait 10 msec try again
            continue;
        buf[i]=b[0];
        i++;
    buf[i]=0;   // 0 terminate the string
    fputs(buf,stdout);
    b[0]=0;    // reset b[0] so while loop can start over
    struct termios toptions;
    int fd;
    int baud=B9600;
    //fprintf(stderr,"init_serialport: opening port %s @ %d bps\n",
    //        serialport,baud);
    fd = open("/dev/ttyUSB0", O_RDWR | O_NOCTTY | O_NDELAY);
    if (fd == -1)  {
        perror("init_serialport: Unable to open port ");
        return -1;
    if (tcgetattr(fd, &toptions) < 0) {
        perror("init_serialport: Couldn't get term attributes");
        return -1;
    speed_t brate = baud; // let you override switch below if needed
   brate=baud;
    cfsetispeed(&toptions, B9600);
    cfsetospeed(&toptions, B9600);
    // 8N1
    toptions.c_cflag &= ~PARENB;
    toptions.c_cflag &= ~CSTOPB;
    toptions.c_cflag &= ~CSIZE;
    toptions.c_cflag |= CS8;
    // no flow control
    toptions.c_cflag &= ~CRTSCTS;
    toptions.c_cflag |= CREAD | CLOCAL;  // turn on READ & ignore ctrl lines
    toptions.c_iflag &= ~(IXON | IXOFF | IXANY); // turn off s/w flow ctrl
    toptions.c_lflag &= ~(ICANON | ECHO | ECHOE | ISIG); // make raw
    toptions.c_oflag &= ~OPOST; // make raw
    // see: http://unixwiz.net/techtips/termios-vmin-vtime.html
    toptions.c_cc[VMIN]  = 0;
    toptions.c_cc[VTIME] = 20;
    if( tcsetattr(fd, TCSAFLUSH, &toptions) < 0) {   //Was TCSANOW
        perror("init_serialport: Couldn't set term attributes");
        return -1;
    return fd;
Any ideas?
PaulS
Quote
The usual solution is a small delay() after the Serial.begin() in the Arduino sketch, to allow the port time to be opened, before sending data.
Tentationem
Thank you Paul
I've thought the same and already tried that  but that didn't help.
Normally the first line isn't that important since it's just a hello line  in setup();
I'd just like to know why it happens to make sure it's  just the first line and not something that's going to repeat itself throughout the code.
I've noticed that it depends on how fast I run the program again after terminating it  how much distortion there will be.
april
#3
Sep 19, 2012, 11:07 pm Last Edit: Sep 19, 2012, 11:10 pm by april Reason: 1
You asked any ideas?
If it puts "    flamflamingo   "  it might be it is doing a reset after "flam" so maybe its doing a double reset or init
If it puts "    fflamingo   "  it might be it is doing a reset after "f"
The devices are very fast and you probably would not notice this apart from the extra start characters
Tentationem
Thank you April.
I think that might explain it.
When I press the reset button manually the thing resets and prints everything just fine.
I'm using a mega 2560
Can't come up with a way to solve it for now.
Except maybe adding a special character before every new word then removing it later.
Wonder how the serial monitor handles this, I've looked through the source and found a couple read functions,  not so familiar with Java though.
Anyways thanks for the suggestions ^^
eried
Thank you April.
Can you check if the same happens with my tweaked version? http://arduino.cc/forum/index.php/topic,118440.0.html
IDE flushes the serial port, but I removed that and the winavr wrapper handles that flush, also you can press Ctrl when clicking upload to auto-open the serial monitor, maybe solves your issue.
Can you post all the related files to your sketch? I can test it locally to research what is happening
My website: http://ried.cl
Tentationem
#6
Sep 22, 2012, 10:47 pm Last Edit: Sep 22, 2012, 10:50 pm by Tentationem Reason: 1
Hello eried
Thanks but I'm on Linux so your Win prog won't work here.
Anyways If someone can benefit from the source here it is.
I'm not familiar with the library but everything seems okay except for the first line issue.
Just change the name of the serial port in the serialport_init function(fd=open...)  to the one your adruino is on in /dev
The baud rate is 9600
It will listen on that port and print whatever the arduino sent in the console.
Code: [Select]
#include <stdlib.h>
#include <getopt.h>
void clear_string();
int serialport_read_until(int fd,char until);
int serialport_write(int fd, const char* str);
char b[1];
char buf[256];
char sendbuf[256];
int i=0;
int len;
int w;
int main()
  int fd = 0;
  int StatusRec=3;
  //sendbuf[0]='2';
 //  sendbuf[0]='9';
  // sendbuf[1]='9';
   //sendbuf[2]='\n';
  // sendbuf[3]='\0';
usleep(200);
while(1){
       do{
        StatusRec=serialport_read_until(fd,'\n');
        //usleep(10);
       }while(StatusRec==-1||StatusRec==2);
          //printf("__%d__",StatusRec);
          printf("%s",buf);
/*  Send data to the arduino with this...  If using sketch  below just un-comment this
   printf("What shall be sent?");
           scanf("%s",&sendbuf);
           sendbuf[strlen(sendbuf)]='\n';
           sendbuf[strlen(sendbuf)+1]='\0';
           printf("%s\n",sendbuf);
           serialport_write(fd,sendbuf);
 */          clear_string();
       usleep(1000);
   int fd;
   int baud=B9600;
   if (fd == -1)  {
       return -1;
       return -1;
  brate=baud;
   // 8N1
   // no flow control
   if( tcsetattr(fd,TCSANOW , &toptions) < 0) {   //Was TCSAFLUSH
       return -1;
   return fd;
void clear_string()
   int f;
    for(f=0;f<256;f++){
     buf[f]=0;
i=0;
   do {
       int n = read(fd, b, 1);  // read a char at a time
       if( n==-1) return -1;    // couldn't read
       if( b[0]==0||n==0 ) {
           printf("^^");
           continue;
       else{
       buf[i] = b[0]; i++;
   } while( b[0] != until );
  if(b[0]==until){
   buf[i] = 0;  // null terminate the string
   return 0;
   i=0;
   b[0]=0;
  else{
  return 2;
   int len = strlen(str);
   int n = write(fd, str, len);
   if( n!=len )
       return -1;
   return 0;
As for the arduino code you can add just a few  Serial.println()'s
The code below will listen for input(int)  when it receives input it will delay that much and then send the input back to the pc.
If you input 99  it will blink led 13  twce and then send back the input
Just make sure to un-comment the send part in the code above.
Code: [Select]
#include <HardwareSerial.h>
void init_process_string(void);
char STRING[128];
int serial_count;
int delaytime=0;
int ledpin=13;
void setup(){
 pinMode(ledpin,OUTPUT);
 delay(700);
 Serial.println("start");
   Serial.flush();
  char c;
  if (Serial.available() > 0)
     c = Serial.read();
     if (c != '\n')
        STRING[serial_count] = c;
        serial_count++;
  //mark no data.
     delayMicroseconds(100);
  //if theres a pause or we got a real command, do it
  if (serial_count && (c == '\n'))
        delaytime=atoi(STRING);
        delay(delaytime);
        if(delaytime==99){
          digitalWrite(ledpin,LOW);
          digitalWrite(ledpin,HIGH);
                   delay(5000);
                   delay(5000);
        Serial.println(delaytime,DEC);
        Serial.flush();
     //clear command.
     init_process_string();
void init_process_string()
  //init our command
  for (byte i=0; i<128; i++)
     STRING[i] = 0;
  serial_count = 0;
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
