Loading...
Pages: 1 ... 7 8 [9]   Go Down
Author Topic: SoftwareSerial with ATTiny84 using ATtiny library  (Read 15654 times)
Denmark
Offline Offline
God Member
View Profile
WWW
I am confused too.
I think it would be a good idea if you describe your project in more detail. It is unclear how many and which pins you are expecting to use and for what purpose.
Just to be clear that we are talking about the same:
The Capacitive Sensing Library ned a sense and receive pin
http://playground.arduino.cc//Main/CapacitiveSensor?from=Main.CapSense
If you are using TinyISP and knockbang , the serial output form attiny is pin PB1 (physical pin 6) connected to pin pin 12 on the UNO,
This is also the reason why you should not use this pin as sense pin, as I tryed to explain
That leaves you with 2 pins (three if you use the reset pin)
« Last Edit: February 28, 2013, 09:10:41 am by Erni » Logged
Offline Offline
Full Member
View Profile
WWW
I am confused too.
ok this is where I am confused. I have the capacitive sensor hooked up to the attiny not the arduino (maybe that is where the confusion is). you say "using 0 and 1 you are interferring with MISO" I don't see how that will interfere with MISO on attiny...? nor did I know it even had it.
Those sketches I have up there are both uploaded to the attiny, I have capacitive sensor on 0 and 1 of attiny. and reading serial from attiny on PB3 (I thought this was default, I have always used this and it used to work fine) going into Tx of arduino. But I also leave it plugged into the programming board, but not sure if this will cause any unexpected errors.
let me know if this clears it up or if its still confusing.
Logged
for(i = 0, i < 820480075, i++){ Design(); Code(); delay(1000); } // hellowoo.com
Denmark
Offline Offline
God Member
View Profile
WWW
Quote
So do I   smiley-grin
Quote
It does, see the picture above
Quote
Look at the picture PB1 (or 1) is MISO used by TinyISP to communicate with your Arduino
Quote
Again 1 is MISO
Quote
No, the default is PB1 when you are using TinyISP.
If you use TinyDebugSerial, the default is PB3
« Last Edit: March 01, 2013, 07:41:10 am by Erni » Logged
Offline Offline
Full Member
View Profile
WWW
Quote
So do I   smiley-grin
Quote
Quote
Quote
Again 1 is MISO
Quote
Ohhhh, I was confusing myself because I was using a different core last time. it definitely had a different pin, i made suggestions you made and all is well. thanks for your patience smiley everything is working as expected. so using TinyISP is 0 the serial in( like Rx on arduino)? this relationship kind of confuses me because I have output from attiny going into Tx of arduino, which I thought was transmit. I would expect it to go into Rx.
Logged
Offline Offline
Newbie
View Profile
Hi, I would need some help to bring my ATTiny85 to life.
My goal is to establish a serial communication on my Tiny.
I've already spent long hours for looking a working solution but with no luck :/.
Tried various libraries, settings, pins .. so now I am stuck .
The scenario :
Arduino Bare - working fine
Uploaded a blinky sketch and that is working fine
Uploaded 2 kind of bootloaders (?) Various serial implementations.. I am confused smiley-sad Heeelp please.
I would be happy to start the whole process from the beginning because surely I missed something.. wrong bootloader, library..something..
Thanks !
Logged
Denmark
Offline Offline
God Member
View Profile
WWW
If you can upload a working blink sketch to your Tiny, you should be able to use TinyDebugSerial, which is a one way communication.
Code:
  Serial.println("Testing..");
  delay(100);
The output from the tiny is pin PB3.
You the need a serial/usb converter to connect it to your computer/serial monitor
more on this:
http://www.ernstc.dk/arduino/tinycom.html
As you see you have other options:
1. TinyDebugSerial
2. SoftwareSerial
3. Use TinyISP and Tinyknockbang
4. Use TinyISP and Serial Relay
5. Use TinyISP and Nullmodem
Logged
Pages: 1 ... 7 8 [9]   Go Up
Print
Jump to:
