Topic: SoftwareSerial with ATTiny84 using ATtiny library (Read 114112 times) previous topic - next topic
hiduino
I found some commented out lines in KnockBangReceiver.cpp, "Skip the Hello"?  What was this for?
When I put back the commented out code I was able to get KnockBang to work on the Mega2560 and Uno to some tinys.
Code: [Select]
--- Monitor starting ---
KnockBang-Testing...
--- Monitor stopped ---
Coding Badly
Does TinyDebugKnockBang need to be updated also?
Yes.  Sorry about that.  TinyISP and TinyDebugKnockBang are paired and I made a change to the Knock-Bang protocol...
Coding Badly
The protocol goes like this...
MISO is held high by the internal pull-up resistors on both sides.  When the transmitter (the ATtiny processor) wants to send data it sinks MISO low and holds it low for a few microseconds.  This triggers a pin-change interrupt on the receiver.  The receiver checks MISO to ensure there was not a false positive then waits for MISO to float high.  The transmitter changes MISO back to an input w/ pull-up allowing it to float high.  That sequence is the "knock".
The receiver then pulls MISO low for a few microseconds.  Upon noticing MISO go low the transmitter prepares to send data; it waits for MISO to float high.  The reciever changes MISO back to an input w/ pull-up allowing it to float high.  That sequence is the "hello".
Once MISO floats high, the transmitter proceeds to output data at ~3us per bit followed by a termination string.  That sequence is the "bang".
I dropped the "hello".  It solves a problem that does not exist.
Quote
Excellent.  Updating TinyDebugKnockBang should get the whole thing working.  Until you have all the kinks worked out I suggest adding a series resistor (220 to 1000 ohms) on MISO.  With the "hello" in the protocol on one side but not on the other there is a slight possibility of a short-circuit through the two processors.
hiduino
Opps, I hope my avrs are still okay. :smiley-eek:
So with the new protocol on both sides, this short-circuit issue is prevented?
Will you have your updated TinyDebugKnockBang on Git also?  I checked but the last update was a year ago.
Coding Badly
The resistors are generally a good idea especially when testing software.   However, I made a mistake with this...
Quote
At one point I had a version of TinyDebugKnockBang that skipped the "hello".  That version was never published.  TinyDebugKnockBang always waits the 6us.  I did not drop the "hello"; I made it optional.  I apologize for the mistake and the unnecessary concern.
Quote
Something weird is going on with Github.  I did a pull and the versions match but browsing they do not match.  (The code of interest is here... https://github.com/Coding-Badly/TinyDebugKnockBang/blob/master/TinyDebugKnockBang.cpp#L475).  bbailout2 was moved...
Code: [Select]
   // For six microseconds check for Hello
 ".if %[_6us_hst] < 3"                               "\n\t"
   "sbis  %[pin], %[bit]"                            "\n\t"
   "rjmp  L%=bgothello"                              "\n\t"
   "sbic  %[pin], %[bit]"                            "\n\t"
   "rjmp  L%=bbailout2"                              "\n\t"
 ".else"                                             "\n\t"
   "ldi   %[d], %[_6us_hst]"                         "\n\t"  //  1  1
 "L%=bwaitforhello:"  "\n\t"
   "sbis  %[pin], %[bit]"                            "\n\t"  //  1  2 2 1
   "rjmp  L%=bgothello"                              "\n\t"  //  2  - - 2
   "dec   %[d]"                                      "\n\t"  //     1 1
   "brne  L%=bwaitforhello"                          "\n\t"  //     2 2
 ".endif"                                            "\n\t"
 "L%=bgothello:"                                     "\n\t"
   // Putting bbailout2 here instead of with bbailout1 makes the Hello optional
 "L%=bbailout2:"                                     "\n\t"
Coding Badly
hiduino
Okay, with both new copies of TinyISP and TinyDebugKnockBang, Knock-Bang is working on the Mega2560 going to a tiny84 @1MHz.  I will continue reviewing and testing with various tinys and speeds.
Coding Badly
Ok, I know you said serial relay was note to yourself.  But I tried anyway and was able to get it to work with a Mega2560 and tiny84.  I made two changes to the code.
That actually uses SoftwareSerial for the relay.  Would you prefer one of the other USARTs like Serial1?
Coding Badly
Excellent.  Thank you.
hiduino
Yes, I noticed that.  But isn't why you are using SoftwareSerial because you can direct it to the MISO pin?  If you use the USART then you would have to wire additional connections from the target?  SoftwareSerial seems to be working okay, what would be the benefits of using a USART? More speed options? Better accuracy?
sej7278
#145
Jun 17, 2013, 10:24 am Last Edit: Jun 17, 2013, 10:42 am by sej7278 Reason: 1
I'm having trouble getting KnockBang to work on my Mega2560 (not tried serial yet). What I did:
Download latest TinyDebugKnockBang directory from github, put it in ~/sketchbook/libraries/
Download latest TinyISP directory from github, put it in ~/sketchbook/
Rename TinyISP.pde to TinyISP.ino
Added const to this line:
Code: [Select]
__attribute__ ((used)) char Copyright[] PROGMEM = "blah"
otherwise I got the error:
Code: [Select]
TinyISP.ino:101:42: error: variable 'Copyright' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
Made sure #include <SoftwareSerial.h> was commented out with //
Added these lines to _TinyISP_BuildOptions.h:
Code: [Select]
#define RELAY_KNOCK_BANG_ENABLED 1
#define RELAY_SERIAL_ENABLED 0
Uploaded TinyISP.ino to Mega as usual (removed cap on reset/GND, uploaded, put it back, tried with and without 220ohm resistor on MISO)
Uploaded demo program from here to ATtiny85 (using arduino-tiny 0017 core, 8MHz internal clock, also tried 1MHz)
Opened serial monitor, changed to 19200 baud, waited.... just got a kind of a square character like [], at 9600 baud i get nothing at all
hiduino
On the Mega2560, you have to wait about 10 seconds for the bootloader to timeout after opening Serial Monitor.  You need to watch the "L" LED for the heartbeat pulse before type the "!" character to enter Monitor mode.  When you are done with Monitor mode, don't forget to exit by typing "!" again, to put it back in ISP mode.  You need to keep Serial Monitor at 19200 baud for this.
sej7278
#147
Jun 17, 2013, 12:53 pm Last Edit: Jun 17, 2013, 12:58 pm by sej7278 Reason: 1
ah, didn't realise you had to enter ! for knockbang mode, now i'm getting:
--- Knock-Bang fault: 11 ---
also 4 and 13.....
Coding Badly
You're not using a capacitor to disable auto-reset?
Quote
Out of habit, I exit Monitor when I finish but doing that should not actually be necessary.  There is code in TinyISP that automatically switches from Monitor to Programmer.
Coding Badly
Did you remember to Burn Bootloader so the target is actually running at the correct speed?
