Topic: SoftwareSerial with ATTiny84 using ATtiny library (Read 108206 times) previous topic - next topic
Coding Badly
That actually uses SoftwareSerial for the relay.  Would you prefer one of the other USARTs like Serial1?
Yes, I noticed that.  But isn't why you are using SoftwareSerial because you can direct it to the MISO pin?
The first version of TinyISP was made for the m328 processor when Knock-Bang did not exist.  Serial was the only way to send debugging information.  At that point it made sense to use SoftwareSerial with MISO as the RX pin.
The new idea is to use Knock-Bang for debugging and Serial for data.  As I port TinyISP to other processors I have always used a USART if I could.
Quote
If you use the USART then you would have to wire additional connections from the target?
Well, one extra connection.
Quote
SoftwareSerial seems to be working okay, what would be the benefits of using a USART? More speed options? Better accuracy?
Yes and yes.
With the new interrupt driven Serial, there is also a high probability of dropped data.  Using a USART for Serial Relay eliminates that problem.
hiduino
You're not using a capacitor to disable auto-reset?
Yes, I didn't think I needed to disable auto-reset for Serial Monitor mode, but I guess that makes sense.  (After all I did not have to disable auto-reset for ISP programming.)
Out of habit, I exit Monitor when I finish but doing that should not actually be necessary.  There is code in TinyISP that automatically switches from Monitor to Programmer.
Okay, I didn't know about that, Great feature!
So when I exit Monitor mode, it keeps on running after I close Serial Monitor, until I try an upload using programmer or burnbootloader?
sej7278
Did you remember to Burn Bootloader so the target is actually running at the correct speed?
yes.
Coding Badly
The fault codes are here... https://github.com/Coding-Badly/TinyISP/blob/master/KnockBangReceiver.cpp#L285
0x11 is fault_timeout_knock which occurs when the pin-change interrupt fires, a knock is detected, but the knock duration is (way) too long.  Loose wire, target at the wrong speed (running at 1 MHz; sketch built for 8 MHz), or the programmer is running significantly faster than 16 MHz.
0x04 is fault_no_knock which occurs when the pin-change interrupt fires and no knock is detected.  Loose wire, target at the wrong speed (running at 8 MHz; sketch built for 1 MHz), or side-effect of a previous failure.
0x13 is fault_timeout_sample_0 which occurs when the first timing mark is not detected.  Loose wire, target running at the wrong speed, or side-effect of a previous failure.
Coding Badly
Wow.  You are actually able to program a target with a 10 second bootloader time-out?
Your experience will be greatly improved by disabling auto-reset!
Thanks.
Quote
Correct.
sej7278
#155
Jun 17, 2013, 10:42 pm Last Edit: Jun 17, 2013, 10:55 pm by sej7278 Reason: 1
my bootloader/sketch speeds match and i doubt there's a loose wire as they work fine for ArduinoISP and TinyISP. (i assume you mean 50-53?) and the Mega2560r3 is running at stock 16MHz. do you think i need to use tinytuner or edit the fuses somehow?
as far as wiring goes, we are just using MISO/MOSI/SCK/RESET with a USB cable from mega to pc as you would for ISP'ing, and not TX/RX with a USB UART or something?
hiduino
#156
Jun 18, 2013, 12:27 am Last Edit: Jun 18, 2013, 12:30 am by hiduino Reason: 1
When burning bootloader or Upload using programmer, the IDE appears to be using the stk500v1 protocol (for Arduino as ISP) which avoids invoking the auto-reset on the Mega2560 board.
But I guess I will still need to disable auto-reset for Serial Monitor use.  This could be avoided also if the Mega2560 bootloader did something similar to Optiboot, where it will skip out of bootloader if the wrong baud rate is detected?
Coding Badly
Anything extra connected to MISO?  LED?  SPI device?
hiduino
I often use a LED to make sure the sketch running at the expected clock rate.
Try this:
Code: [Select]
#include <TinyDebugKnockBang.h>
int led = 3;
void setup( void )
  Debug.begin( 250000 );
  pinMode(led, OUTPUT);
void loop( void )
  digitalWrite(led, HIGH);
  digitalWrite(led, LOW);
  Debug.println( F( "Caitlin! " ) );
//  delay( 1000 );
sej7278
yes that's it - i've got a resistor and led coming out of pin 6 on the tiny, if i remove them, knockbang works!
however if i'm doing anything useful in my sketch (some counting, analogWrite, random, delay....) knockbang seems to sit there doing nothing, gets stuck at monitor startin.....
Coding Badly
Are you asking for helping?  Or did you just need a whine to vent some frustration?
hiduino
That sounds interesting.  So Knock-Bang will continue to use MISO for debugging  and you would also relay Serial via the USART? They both show up on Serial Monitor?  Are you also implying two way with Serial?
Coding Badly
I have an Uno with the framing-error-quick-escape feature.  I had problems getting it to work as a programmer.  The capacitor makes a significant positive difference.  It is worth the 10 cent investment.   ;)
Coding Badly
Yes.  (With the addition that an alternate pin can be used for Knock-Bang if MISO is otherwise needed.)
Quote
Yes.
Quote
Yes.
While I have not tested it, that is the way it should work now.
hiduino
#164
Jun 18, 2013, 04:22 am Last Edit: Jun 18, 2013, 04:41 am by hiduino Reason: 1
Not to beat this subject dead, but I've been using an Uno R3 without the capacitor and no problems with TinyISP or ArduinoISP.  The bootloader escape seems to work fine on the Uno R3.  It's not a problem to use the capacitor, but it's a little hassle to get it to contact into the headers good or otherwise jumper it from a breadboard.
It appears that avrdude does not invoke the auto-reset when using the stk500v1 protocol to the Uno R3 or Mega2560 R3.  It does if you use the "arduino" protocol.  So the reset capacitor really doesn't do anything in this case, except for going into Serial Monitor.
