Loading...
Pages: 1 2 [3] 4 5 ... 9   Go Down
Author Topic: SoftwareSerial with ATTiny84 using ATtiny library  (Read 15836 times)
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Quote
I can upload the blink sketch as before but when I try to send a exclamation mark (!) in the serial monotor, all I get is  this
No sign-on message from the Monitor?
Is the PC-to-Arduino baud rate set to 19200?
Logged
Offline Offline
Newbie
View Profile
@Coding Badly
Thanks, I'll try that once I get back from work today.
Logged
Denmark
Offline Offline
God Member
View Profile
WWW
Quote
No
Quote
Yes if you mean the com port that connects to the Arduino
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
What I did and the results...
• Download the latest version of TinyISP...
https://github.com/Coding-Badly/TinyISP/zipball/master
• Extract the contents to a directory named TinyISP in my Arduino sketchbook folder
• Load TinyISP.pde into Arduino 1.0.1
• Navigate to the TinyISP_BuildOptions.h tab
• Change RELAY_SERIAL_ENABLED to this (change the zero to a one)...
#define RELAY_SERIAL_ENABLED              1
• Navigate to the TinyISP tab
• Remove the comment from this line...
#include <SoftwareSerial.h>
• Upload the sketch to my Uno
• Open Serial Monitor
• Ensure No line ending is selected
• Ensure 19200 baud is selected
• Enter a single exclamation mark (!) and click Send
• The following line is output by the Arduino...
--- Monitor starting ---
--- Monitor stopped ---
Logged
Denmark
Offline Offline
God Member
View Profile
WWW
Ohh I totally overlooked this, sorry
Now it works as expected.
Thankyou Coding Badly for your help and patience.
With this setup it is so much easyer to program the tiny's no more swappinp between programmer and serial/usb connectors
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Excellent.  Let me know when you are ready to try Knock-Bang.
Logged
Denmark
Offline Offline
God Member
View Profile
WWW
I am ready  !!!
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Modify TinyISP to use Knock-Bang instead of Serial...
• Change RELAY_KNOCK_BANG_ENABLED to this (change the zero to a one)...
#define RELAY_KNOCK_BANG_ENABLED           1
• Change RELAY_SERIAL_ENABLED to this (change the one to a zero)...
#define RELAY_SERIAL_ENABLED               0
• Add a comment to this line...
// #include <SoftwareSerial.h>
• Upload the sketch to your Uno
« Last Edit: September 25, 2012, 02:12:20 pm by Coding Badly » Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Install the Tiny Debug Knock-Bang library...
• Download the latest version of Tiny Debug Knock-Bang...
https://github.com/Coding-Badly/TinyDebugKnockBang/zipball/master
• Extract the contents to a directory named TinyDebugKnockBang in your Arduino sketchbook library folder
• Start the Arduino IDE
• Ensure one of the tiny processor "boards" is selected
• Copy-and-paste this small test into the edit window...
Code:
#include <TinyDebugKnockBang.h>
void setup( void )
  Debug.begin( 250000 );
void loop( void )
  Debug.println( F( "Caitlin! " ) );
  delay( 1000 );
• Verify that the sketch compiles
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
At this point, you should be able to upload the test sketch to a tiny processor and use Serial Monitor for debugging.
Knock-Bang uses MISO (and GND) for communications.  You only need to connect the target (the tiny processor) and programmer (the Uno) as would normally do for programming.  No extra connections are needed.
Logged
Denmark
Offline Offline
God Member
View Profile
WWW
That worked right out of the box !
So it seems that if you only need the output from the tiny you would choose KnockBang, and if you need to also send something to the tiny you would use
RelaySerial ?
Another observation in the test script you use
Code:
But you have to set the serial monitor to 19200 (I mean usually they should be the same) ?
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Excellent.
Quote
So it seems that if you only need the output from the tiny you would choose KnockBang, and if you need to also send something to the tiny you would use RelaySerial ?
That's what I do.  Knock-Bang is smaller, faster, more reliable, uses a pin already connected to the programmer, and consumes almost zero CPU time if the programmer is not connected.  For simple debugging it is a great choice.
Quote
Code:
Sort of.  My ultimate goal is to provide three Tiny Debuggers: Serial, Knock-Bang, and Null.  The parameter (the "250000") will eventually be the baud rate for Serial.  For the other two debuggers the parameter is ignored.  You can put what you'd like in there but 19200 is certainly a better choice.
« Last Edit: September 25, 2012, 03:45:04 pm by Coding Badly » Logged
Denmark
Offline Offline
God Member
View Profile
WWW
I am impressed with the tools you have made
  It will be interesting to hear what a Null debugger can be used to
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Thanks.
Quote
What popped into your mind when you read "Null debugger"?
Logged
Denmark
Offline Offline
God Member
View Profile
WWW
My first thought was null modem, as in the old days when we interconnected two PC's with a crossover serial cable.
 So maybe a smart way to let 2 attiny communicate together, while debugging the result ?
Logged
Pages: 1 2 [3] 4 5 ... 9   Go Up
Print
Jump to:
