Loading...
Pages: 1 ... 5 6 [7] 8 9 ... 12   Go Down
Author Topic: SoftwareSerial with ATTiny84 using ATtiny library  (Read 18320 times)
0 Members and 2 Guests are viewing this topic.
Denmark
Offline Offline
God Member
View Profile
WWW
Quote
(Except for 0.6 MHz.  I'm surprised that works.  As the clock speed is reduced below 1 MHz, the protocol becomes less reliable.  At 0.5 MHz it should fail.)
Now I have done some more testing at 600 kHz and it is indeed unreliable.
I had a sketch running for more than 40 minutes whitout any errors,
other tests only 4-5 lines before I got a KnockBang error, and most tests between those.
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Do you have a need for Knock-Bang to work at clock speeds below 1 MHz?
Quote
Excellent!
Logged
Denmark
Offline Offline
God Member
View Profile
WWW
Quote
No, I was just curious to see if it worked.
Logged
Offline Offline
Full Member
View Profile
WWW
this seems like a really awesome project and exactly what I am looking for. however the sketch doesn't seem to want to compile. I get this error:
Code:
In file included from KnockBangReceiver.cpp:36:
TinyISP_SelectBuildOptions.h:175:2: error: #error
I'm on an Uno and IDE v1.0.1. I think it might have to do with TinyISP_BuildOptions.h, that doesn't seem to be in the files included.i did find TinyISP_SelectBuildOptions.h and that seemed right, however settings in there already matched what you said to change.
any suggestions?
Logged
for(i = 0, i < 820480075, i++){ Design(); Code(); delay(1000); } // hellowoo.com
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Sorry about that.  Try it now.
Logged
Valencia, Spain
Offline Offline
Faraday Member
View Profile
Not sure how this is supposed to work without power...
It won't.
That's what they taught me in EE smiley-wink
It might ... if one of the I/O pins is connected to a voltage source.
OTOH this is a good way to destroy chips, don't try it at home.
Logged
No, I don't answer questions sent in private messages...
Offline Offline
Full Member
View Profile
WWW
ahh, there we go! perfect. thank you.
Logged
Offline Offline
Full Member
View Profile
WWW
Install the Tiny Debug Knock-Bang library...
• Download the latest version of Tiny Debug Knock-Bang...
https://github.com/Coding-Badly/TinyDebugKnockBang/zipball/master
• Extract the contents to a directory named TinyDebugKnockBang in your Arduino sketchbook library folder
• Start the Arduino IDE
• Ensure one of the tiny processor "boards" is selected
• Copy-and-paste this small test into the edit window...
Code:
#include <TinyDebugKnockBang.h>
void setup( void )
  Debug.begin( 250000 );
void loop( void )
  Debug.println( F( "Caitlin! " ) );
  delay( 1000 );
• Verify that the sketch compiles
I seem to be missing something. Maybe I don't fully understand what knock-bang is. Was assuming this was a simple "hello world" type message that you can test this one, could be wrong.
I have selected attiny85 at 8mhz as board and it upload fine and I can even add "!" into debugger and I get "--- Monitor starting ---" but it seems nothing is coming out. Also have 19200 baud set, no line ending. I uploaded the sketch you showed earlier:
Code:
void setup( void )
void loop( void )
  delay( 1000 );
But I am not getting anything in the monitor aside from initiated message. On arduino its connected to Tx (though it seems like it would be Rx but all other monitors I have set up use Rx for some reason) and PB3 on the attiny (with 220ohm resistor between). Might be missing something though?
« Last Edit: January 17, 2013, 11:46:53 pm by hilukasz » Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
You are.  Documentation.  Work keeps getting in the way.
Try this...
• With the TinyISP sketch loaded in the Arduino IDE, switch to the _TinyISP_BuildOptions.h tab # (sadly, it ended up the last tab)
• Add this line below the Put build options here comment...
#define RELAY_KNOCK_BANG_ENABLED  1
• Upload the modified sketch (don't forget to remove the auto-reset disable capacitor)
# Or, with the Arduino IDE not running use an external editor to modify the file.
Logged
Offline Offline
Full Member
View Profile
WWW
Try this...
Quote
Is that the on between reset and ground? I did that and no change, still get the error:
Code:
--- Knock-Bang fault: 11 ---
« Last Edit: January 19, 2013, 12:48:24 am by hilukasz » Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Yes.
Quote
Code:
No change?  Earlier you reported that nothing was being output to the Serial Monitor.  Were error messages being output?
Logged
Offline Offline
Full Member
View Profile
WWW
definitely a change, it now says --- Knock-Bang fault: 11 --- instead of nothing. Of course I should clarify, it did indicate the monitor was starting and stopping.
Edit: trimmed the unnecessary quote.
« Last Edit: January 19, 2013, 01:49:38 am by Coding Badly » Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
The receive errors are listed here...
https://github.com/Coding-Badly/TinyISP/blob/master/KnockBangReceiver.cpp#L285
The one of interest is...
fault_timeout_knock          = 0x11
The receiver (your Uno) is expecting a low pulse of a certain duration (a "knock").  The pulse is too short to be a knock.
The problem could be caused by the target running at 1 MHz with code built for a processor running at 8 MHz.  Which "board" do you have selected?  Have you used "burn bootloader" to change the fuses?
Logged
Denmark
Offline Offline
God Member
View Profile
WWW
Quote
If it is of any help, I just tried a Attiny85 running at 1MHZ and selected board Attiny85 @ 8MHZ and got:
Quote
With the same target and selcting board Attiny85 @ 1MHZ it works as expected (Output to the serial monitor looks as it should)
« Last Edit: January 19, 2013, 07:14:06 am by Erni » Logged
Offline Offline
Full Member
View Profile
WWW
Quote
Quote
yeah, I just did this too. It makes sense since the frequency is 8 times faster, would make the signal shorter. I was under impression serial monitor needed to be 8Mhz like normal, but this seems to run differently.
It works perfect now! thanks guys.
Logged
Pages: 1 ... 5 6 [7] 8 9 ... 12   Go Up
Print
Jump to:
