sej7278:
however if i'm doing anything useful in my sketch (some counting, analogWrite, random, delay....) knockbang seems to sit there doing nothing, gets stuck at monitor startin.....
Are you asking for helping? Or did you just need a whine to vent some frustration?
That sounds interesting. So Knock-Bang will continue to use MISO for debugging and you would also relay Serial via the USART? They both show up on Serial Monitor? Are you also implying two way with Serial?
hiduino:
This could be avoided also if the Mega2560 bootloader did something similar to Optiboot, where it will skip out of bootloader if the wrong baud rate is detected?
I have an Uno with the framing-error-quick-escape feature. I had problems getting it to work as a programmer. The capacitor makes a significant positive difference. It is worth the 10 cent investment.
Not to beat this subject dead, but I've been using an Uno R3 without the capacitor and no problems with TinyISP or ArduinoISP. The bootloader escape seems to work fine on the Uno R3. It's not a problem to use the capacitor, but it's a little hassle to get it to contact into the headers good or otherwise jumper it from a breadboard.
It appears that avrdude does not invoke the auto-reset when using the stk500v1 protocol to the Uno R3 or Mega2560 R3. It does if you use the "arduino" protocol. So the reset capacitor really doesn't do anything in this case, except for going into Serial Monitor.
hiduino:
Arc the pins so the capacitor hangs over the middle of the board. If you always use the same capacitor arcing the pins also helps to ensure the capacitor is connected the correct way around.
Huh. So it doesn't. I wonder if that changed or if I have been a dumb-ass.
Does anyone know if this can be used with something else that uses the MISO/MOSI? I need to debug an ATTiny84 connected to an NRF24L01+ transmitter, but I just get knock bang faults when trying to debug. I assume its conflicting on the MISO/MOSI pins.
Is there an alternative? Can the TinyDebugKnockBang use a different pin? (I understand I would have to move the pin once the programming is done, but its better than no debug!)
Hi, I´m currently trying to get Tiny Debug Knock-Bang to work with my Attiny 85 @ 8mhz. I followed the guide from page 2 #33 and succeeded in getting Serial Monitor response to "!" . Then i followed on to the Knock-Bang debug but i cant get it to work even though my baud rate in Serial Monitor was set to 19200. When the capacitor between gnd and reset isnt set my arduino (328 nano) led blinks every time i change the baud rate in the monitor. Totally have no clue what is going on, i can compile the example sketch and upload it but i can´t read my tiny I even tried it with 1 mhz makes no difference.
The only option i have left is using Serial and switching pins all the time but it works.
Now i´ve gotten a way bigger problem, flashed following sketch :
Now my nano led keeps blinking all the time, the analog read on the CLK pin on the tiny seems to mess up with tinyISP, i can´t upload any more and getting sync errors ( i can see it is being initialized RX/TX on nano blinking shortly). I just need to "reset" or overwrite the progmem of the tiny. What are my options here ?
I don't think the sketch you uploaded to the tiny is the problem.
I just tried to upload your sketch, and afterwards I could upload the blink sketch without problems.
I use TinyISP on a UNO, (and a 10uF capacitor from reset to ground)
Do you have something else connected to the tiny while programming ?
I don´t know i´ve read that using pinmode can cause some problems, i tried flashing arduinoISP and tinyISP again. Somehow i got lucky and the led didn´t blink any more maybe the setting of tinyISP was wrong (buildoptions) and i was able to flash, now i still wanna try tinydebugknockbang. From what i have understood the reply to the ! message is arduino based not tiny based so i kinda didnt figure out how to get a Serial read from my tiny except using Serial and a Serial USB converter (used for programming pro mini).
Yes i have connected a line from pb3 (Serial TX) to RX of my Serial USB converter, even while i Flash since the port is not used. I can definately tell that the blinking only occured when PB2 was connected to D13 ( i guess there was a bug because i used Serial in my programm but had turned the settings to using Knockbang).
Since I wanted to programm differential read and I´m getting strange offset readings (around 1000), i thought maybe because I use Serial. Does the DIDR0 reg set off the ADC ? I am measuring PB4-PB4 and i still get high values even though my DIDR0 reg is --11 1111.
Only when I leave the BIN in ADSCRB 0 i get 0 as measurement, which should be not true.
Sorry for going offtopic here, maybe u tried smth. similar and had same issues.
Do you realy want ton use a bootloader ?
If you use a programmer as mentioned in that tutorial, you don't need a bootloader.
Burning bootloader is just a way to set the fuses for the desired clock frequense
I am using arduino 1.5
If you use version 1.5 you will have to make a few changes.
It is a very smart way to communicate with the t2313. If you use it you don't have to use a external serial/USB converter,
and you don't need to change between programming and serial connection, it is almost like programming an Arduino Uno.
You have to use a special sketch. Use this called TinyISP
Thanks for your response. I was a little bit surprised to find the author here. Thanks for your time & effort that you put in the article to help us. Thanks to Coding Badly too.
I have successfully uploaded sketches to ATtiny2313 by using (Arduino UNO) ArduinoISP & SPI protocol. I used the ATtiny core for arduino1.5
Now the other half. I have a sketch loader circuit (FTDI based breakout board). I want my ATtiny to get burnt using the FTDI chip just like we upload sketches in ATmega328 on BreadBoard.
I want to replace the UNO board by FTDI breakout board (Tx, Rx, RST pin). I did this but IDE says NO USB aavailable. Any help please.
What it TinyISP? Has it something to do with my issue? I have downloaded the coding-badly tinyISP zip file. What should I do now? Thanks for all your support & guidance
cheers.
It is just a replacement for ArduinoISP, with extra features
If you want to use a FTDI board , you will need a bootloader. I haven't heard of any bootloader for the t2313, maybe because of the very small memory :2K Flash, 128 SRAM
You are welcome.
And just to avoid any mistakes.
The Tiny core, TinyISP and so on are developed and maintained by Coding Badly.
Something like that far exceeds my programming skills, I am just a hobbyist
