Topic: 1602 Display trouble? (Read 4685 times) previous topic - next topic
funkyguy4000
Hello,
So I have had this 1602 display laying around for ages and I haven't ever been able to figure out why.  I'm sick of it so I decided I'm gonna do whatever I can to make this thing work.
I've been using this and I have loaded its sample program up and it still won't do anything.
http://arduino.cc/en/Tutorial/LiquidCrystalDisplay
I don't even see the pixels turn on or anything.  Its just completely idle.  Any ideas?
Accelerate to 88 miles per hour.
nickgammon
Not enough information.
Link to datasheet? How have you wired it? What code are you running?
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
floresta
Quote
Any ideas?
You have made over 700 posts on this forum so you should know that your problem cannot be answered by others with the information you have supplied.
You are using a very common display with a library that is known to work so where do you think the trouble might be?
Don
funkyguy4000
Sorry, I wasn't at my workbench when I made the post.  I'd thought somebody would have some obscure situation with a solution.
The display I'm using is a POWERTIP PC1602C Rev A
It also has PHICO D-0 94V-0  on it.
From what I've found it should be the same pin out as a normal 1602 display.
I have no idea what the problem is, that's why I'm here asking...
floresta
Where are the pins located with respect to the display?  Some of the Powertip displays have the pins at the lower left and those typically do not have the same pinout as a normal display.
Don
funkyguy4000
#5
Sep 20, 2012, 04:01 am Last Edit: Sep 20, 2012, 04:03 am by funkyguy4000 Reason: 1
Just like the picture.
That is what I assume to be the proper way, seeing as how the text is upright.
floresta
That looks 'normal' to me.
First get the backlight working (pins 15 and 16), you will probably need a current limiting resistor in one of the backlight leads.
Next connect the the power and the contrast (pins 1, 2, and 3) and see if you can adjust the contrast to get blocks on the top row.
Don't bother with the Arduino until you get this working.
After you get the blocks then connect the six connections to the Arduino, connect R/W (pin 5) to GND, and try the 'hello world' demo sketch.
Post photos if you have problems.  I'll check back in the morning to see how you did.
Don
funkyguy4000
wow, i wasnt turning the pot enough.
Alright so I uploaded the hello world to the arduino and this is all I'm getting.
I tried changing the contrast to make sure the hello world wasn't buried.
liuzengqiang
Seems to me the display is not initialized. Can you post your code?
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
funkyguy4000
Its just the HelloWorld from the liquidcrystal library. Nothing too special or custom.
Code: [Select]
  LiquidCrystal Library - Hello World
Demonstrates the use a 16x2 LCD display.  The LiquidCrystal
library works with all LCD displays that are compatible with the
Hitachi HD44780 driver. There are many of them out there, and you
can usually tell them by the 16-pin interface.
This sketch prints "Hello World!" to the LCD
and shows the time.
  The circuit:
* LCD RS pin to digital pin 12
* LCD Enable pin to digital pin 11
* LCD D4 pin to digital pin 5
* LCD D5 pin to digital pin 4
* LCD D6 pin to digital pin 3
* LCD D7 pin to digital pin 2
* LCD R/W pin to ground
* 10K resistor:
* ends to +5V and ground
* wiper to LCD VO pin (pin 3)
Library originally added 18 Apr 2008
by David A. Mellis
library modified 5 Jul 2009
by Limor Fried (http://www.ladyada.net)
example added 9 Jul 2009
by Tom Igoe
modified 22 Nov 2010
by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/LiquidCrystal
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("hello, world!");
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  lcd.print(millis()/1000);
floresta
Quote
That's a 10-turn pot.
It looks like you have pin 5 connected to +5v instead of to GND.
Don
liuzengqiang
Quote
Don
Good eye! I looked at the pic too but I saw the black and trusted this fellow a bit more than I should  :smiley-mr-green:
funkyguy4000
Oh wow, musta misplaced it.  I'll change when I get back to my dorm and let you know if it works or not!
funkyguy4000
Okay so I put the pin 5 to the ground and I'm still getting the same issue
funkyguy4000
whoops, I also had a couple pins in the wrong place as well.
Other than that, I have a question.  How would I use everything?  I only have 4 data lines connected now, how would I use the other 4?
