California
« Reply #15 on: October 24, 2012, 09:16:53 pm » |
So the "A new network interface has been detect" box did not come up after plugging in the Uno? You will have to bear with me until a real Mac user comes by
Toledo, Ohio
« Reply #16 on: October 24, 2012, 10:39:42 pm » |
I keep getting the same problem as well. My mac recognizes the board and everything yet when I try to upload a simple test program it fails and says programmer is not responding. Im running mountain lion 10.8.2. The correct board and serial port is selected. Any feedback would greatly be appreciated. Thank you!
California
« Reply #17 on: October 24, 2012, 11:36:45 pm » |
Does "Network Preferences" show the Uno anywhere? If the driver enumerates the Atmega8/16u2 it should show up as a device on the network. If so, what kind of properties does it have?
« Reply #18 on: October 25, 2012, 01:20:23 pm » |
I solved this problem by selecting a different board. I have an Uno R3 Plus. However, it is an OEM board which means different chips. I was able to get it to work by selecting the Duemilanove ATmega328. works fine now.
California
« Reply #19 on: October 25, 2012, 02:00:13 pm » |
I was wondering why they call it an Uno not a Duemilanove Plus
« Reply #20 on: October 26, 2012, 02:50:04 pm » |
So the "A new network interface has been detect" box did not come up after plugging in the Uno? You will have to bear with me until a real Mac user comes by  No, no dialog box appears when I plug in the Uno. Does "Network Preferences" show the Uno anywhere? If the driver enumerates the Atmega8/16u2 it should show up as a device on the network. If so, what kind of properties does it have?
Network Preferences shows a USB Modem, Not Configured. I do not believe that this is the Uno, however, because the entry persists even without the Uno plugged in. I am fairly sure the Arduino application detects the Uno board, because when I plug the Uno board in, there are two more selections to choose from under Tools > Serial Port. Thanks for the replies!
« Last Edit: October 26, 2012, 03:02:04 pm by James K »
« Reply #21 on: October 26, 2012, 03:35:38 pm » |
Another point, because my "Uno" was actually connecting as a Duemilanove-ATmega328 (not an Uno) the Mac created a serial connection. I loaded the FTDI driver to support this connection.
California
« Reply #22 on: October 26, 2012, 09:34:01 pm » |
Network Preferences shows a USB Modem, Not Configured. I do not believe that this is the Uno, however, because the entry persists even without the Uno plugged in. I am fairly sure the Arduino application detects the Uno board, because when I plug the Uno board in, there are two more selections to choose from under Tools > Serial Port. Thanks for the replies! Are you sure you have an Atemga8/16u2 and not an FTDI chip? If you have an FTDI chip you will need to download: http://www.ftdichip.com/Drivers/VCP/MacOSX/FTDIUSBSerialDriver_v2_2_14.dmg
« Reply #23 on: October 30, 2012, 04:20:29 pm » |
I have no idea what Atmega and FTDI are, but the box that the Uno board came in says Microcontroller: ATMEGA328P. Is that any help?
California
« Reply #24 on: October 30, 2012, 09:36:20 pm » |
Does your Uno look like this:  or this:  Primary focus is on the black square or rectangle to the right of the USB socket. If it is rectangular with pins on both sides, it is FTDI. If it is a square it is either an Atmega8u2 or Atmega16u2.
Wisconsin
I LOVE THIS STUFF!!!!
« Reply #25 on: October 30, 2012, 10:01:21 pm » |
Body feels not good, then go to the hospital for examination, the doctor asked X-rayed, Cheap GW2 CD Keys X-ray, MD wrote diagnosis, and then I took the diagnosis and film to the doctor. Surprisingly, the doctors took X-ray diagnosis began shaking his head, his mouth Gee, I was immediately pumped wow cool, want to ask the doctor left how long results that doctors say is: "Oh, now young doctors, the handwriting is really bad. " Diablo 3 GoldIn all my days, I have never had quite a period of wtf as I just did.
Accelerate to 88 miles per hour.
« Reply #26 on: November 14, 2012, 06:14:38 pm » |
snip Primary focus is on the black square or rectangle to the right of the USB socket. If it is rectangular with pins on both sides, it is FTDI. If it is a square it is either an Atmega8u2 or Atmega16u2.
My Uno looks like  The chip to the right of the USB socket is square, so I don't need the FTDI Drivers, I'm assuming. Thanks for the continued assistance.
California
« Reply #27 on: November 17, 2012, 01:34:02 am » |
Do you have a USB hub handy (thingy that plugs into the USB and splits off 3 or 4 other ports)? I am not sure how the MacOS handles the Hub, but with Windoze, it assigns another device and starts the installation process again. Make sure you have proper permissions (User Account with Admin rights).
USA
« Reply #28 on: November 23, 2012, 06:51:00 pm » |
I solved this problem by selecting a different board. I have an Uno R3 Plus. However, it is an OEM board which means different chips. I was able to get it to work by selecting the Duemilanove ATmega328. works fine now. Thanks, that solved the problem for my Arduino Uno R3 + Mac combination!
