Loading...
Pages: [1]   Go Down
Author Topic: proximity sensors + maxuino + M4l to trigger audio clips  (Read 363 times)
Offline Offline
Newbie
View Profile
Hello
hi, iam very very green and would really appreciate any help at all !!
My plan seems simple but i just cant seem to get it to work.
i want to use these proximity sensors (www.oceancontrols.com.au/datasheet/ibe/IBx-xxx_datasheet.pdf)
to trigger audio clips in Live using the maxuino & the mega 2560.
just not sure how to setup maxuino or live?
do i need to add the mega as a midi input?
and how can i map the incoming signal to trigger the clips?
the proximity sensors need 10v, and send out a ≤200mA
i found someone who has used something around about the same and they say to put;
27k resistor from sensor output to Arduino input pin
10k resistor from Arduino input pin to ground
what do you think?
Here are the particulars:
Arduino MEGA AT mega 2560
IBEST proximity sensors cps-12n04b
cant seem to find any info on how to config this
thank you in advance !!!!!
Logged
Pages: [1]   Go Up
Print
Jump to:
