Topic: AVR Programmer (Read 1 time) previous topic - next topic
jefferson987
CrossRoads
Yes.
You might have to add to the file programmers.txt for it to be recognized.
I don't know if that will impact the USB interface.
JoeN
#2
Sep 21, 2012, 11:12 pm Last Edit: Aug 25, 2014, 01:32 am by JoeN Reason: 1
You can, but let me make a similar suggestion.  I now hardly touch my Arduinos because what I do is put an ATMega328 on a breadboard or solder them up with an ISP 6 pin header like that and write my code in the Arduino editor but write it to the board using an Atmel Dragon with the programmer in Atmel Studio.  There is no bootloader under these circustances either and you can use 328 chips which are $1.81 each in quantites of 25 from Digikey.  Since that device will look like a STK500 to Atmel Studio, you can send it up the same way.
From the current project:
I will never ask you to do anything that I wouldn't do myself.
jefferson987
Would I still need to add that file if I went with this one http://www.dfrobot.com/index.php?route=product/product&product_id=405#.UFzAiqTyadR
CrossRoads
USBTinyISP is listed in the IDE under bootloaders, so maybe not.
And even if you do, its a small change, for example
usbasp.name=MDFLY
usbasp.protocol=usbasp
for this programmer which I use for '328s
http://www.mdfly.com/index.php?main_page=product_info&cPath=5&products_id=415
