Topic: Arduino 1.0.1 causes Mac OS X to crash regularly. Ideas? (Read 69301 times) previous topic - next topic
chriswei
I downgraded to Arduino 1.0 and was having better luck, but then today I've had a couple immediate reboots using 1.0 and a Diecimila board. It seems to have the most problems when the Serial Monitor window is open and I either try to upload to the board or try to close the Serial Monitor window.
The OS X kernel panic crash report didn't have anything obvious to say.
I'm going back to Arduino 1.0.2 and continuing the investigation. I'm thinking maybe it's something in the latest OS X Mountain Lion update (I'm running 10.8.2).
- Chris
cmiyc
Make sure you have the latest FTDI drivers installed.
I don't consider "immediate reboots" and "kernel panics" to be the same thing.  So which is happening?
chriswei
Sorry for the ambuguity - I'm admittedly not an expert on OS X internals. The effect I'm experiencing is an immediate reboot of the machine - no intermediate screen or other error indication, just an instant reboot (gray screen, boot sound, spinner and eventually back to my desktop). After the reboot, as the Mac is coming back up, I see a crash report dialog. One of the lines in that report mentions a "kernel panic" from an unknown thread.
Papa G
I'm getting exactly the same reaction. I think the problem has to do with Java, the 1.0.x versions of the IDE and USB communication. There have been some upgrades to Java for OS X this Fall. I haven't upgraded to the latest Oracle supplied Java. I am still running Java for OS X 2012-006 version 1.0 from October 2012.
kg4wsv
Maybe not, but a kernel panic usually causes a reboot...
-j
cmiyc
The IDE uses RXTX to determine what serial ports are available and for the Serial Monitor to communicate with the serial port.  avrdude handles the serial port directly for programming.
It is more likely there is a driver / chip issue that is causing the problem and less likely the IDE.
Why would you use the Oracle supplied Java?
I have never had an "immediate reboot" on OSX.  Kernel Panics go to a very distinctive error screen that requires a power cycle.  There is nothing immediate about it.
Papa G
Because Apple stopped supplying the upgrade with the 2012-006 release. I personally have not used the Oracle supplied Java.
I have never had one either, before this. It is like the power is interrupted for a moment.
Ayur
#22
Dec 05, 2012, 08:43 pm Last Edit: Dec 06, 2012, 11:16 am by Ayur Reason: 1
In my case it's a kernel panic (on a early 2008 MBP (running 10.8 ) with an Uno).
boisy
#23
Jan 29, 2013, 02:11 pm Last Edit: Jan 29, 2013, 09:06 pm by Coding Badly Reason: 1
Forget Arduino 1.0.1.  This kernel panic is happening to me with my 24" iMac running 10.8.2 and Arduino 1.0.3. I even upgraded to the latest 10.8.3 beta (I'm a registered developer) and am still getting the panic. Here are the details:
In the Arduino Editor, all that I have to do is click the checkmark button to compile the code in the window. *IF* there are no compile errors, then about 1 out of every 8 times when I click this, the mouse stops moving, and 1 second later the screen goes black and I get the grey panic screen.
This is so frustrating. It makes development a crapshoot because I don't know when the panic will occur. It appears more likely to occur if I do a number of successive compiles in short order (after fixing bugs or adding small features), but it could also happen if I wait minutes or hours to do a compile.
Here is my panic report. Granted, the stack has little information to go on.
Interval Since Last Panic Report:  142025 sec
Panics Since Last Report:          1
Anonymous UUID:                    C9D979AD-BC62-8A09-D830-6AE020D91210
Tue Jan 29 06:53:45 2013
panic(cpu 1 caller 0xffffff80080b7e95): Kernel trap at 0xffffff80083665c3, type 14=page fault, registers:
CR0: 0x000000008001003b, CR2: 0x0000000000000154, CR3: 0x00000000527dc000, CR4: 0x0000000000000660
RAX: 0x0000000000000000, RBX: 0xffffff8019da2660, RCX: 0xffffff80b91150b8, RDX: 0xffffff8017a67070
RSP: 0xffffff8012ccbd90, RBP: 0xffffff8012ccbe50, RSI: 0x000000000000001f, RDI: 0xffffff8019ddb550
R8:  0x000000000000003c, R9:  0x00000000000003ff, R10: 0xffffffffffffffff, R11: 0x00000000ffffffff
R12: 0x0000000000000000, R13: 0x0000000000000004, R14: 0xffffff8017a67020, R15: 0x0000000000080000
RFL: 0x0000000000010246, RIP: 0xffffff80083665c3, CS:  0x0000000000000008, SS:  0x0000000000000010
Fault CR2: 0x0000000000000154, Error code: 0x0000000000000000, Fault CPU: 0x1
Backtrace (CPU 1), Frame : Return Address
0xffffff8012ccba30 : 0xffffff800801d626
0xffffff8012ccbaa0 : 0xffffff80080b7e95
0xffffff8012ccbc70 : 0xffffff80080cd4dd
0xffffff8012ccbc90 : 0xffffff80083665c3
0xffffff8012ccbe50 : 0xffffff8008356082
0xffffff8012ccbec0 : 0xffffff8008039ce9
0xffffff8012ccbef0 : 0xffffff800803c7e8
0xffffff8012ccbf20 : 0xffffff800803c65e
0xffffff8012ccbf50 : 0xffffff800801b70d
0xffffff8012ccbf90 : 0xffffff80080b84a3
0xffffff8012ccbfb0 : 0xffffff80080cd4ac
BSD process name corresponding to current thread: Unknown
Mac OS version:
12D54
Kernel version:
Darwin Kernel Version 12.3.0: Sun Jan  6 22:37:10 PST 2013; root:xnu-2050.22.13~1/RELEASE_X86_64
Kernel UUID: 3EB7D8A7-C2D3-32EC-80F4-AB37D61492C6
Kernel slide:     0x0000000007e00000
Kernel text base: 0xffffff8008000000
System model name: iMac7,1 (Mac-F42386C8)
System uptime in nanoseconds: 146999748730101
last loaded kext at 143699045128632: com.apple.driver.AppleUSBAudio 2.9.0f6 (addr 0xffffff7f8a254000, size 262144)
last unloaded kext at 144811937227386: com.silabs.driver.CP210xVCPDriver64 3.1.0d1 (addr 0xffffff7f8a20d000, size 28672)
loaded kexts:
com.vmware.kext.vmioplug.10.1.24 10.1.24
com.vmware.kext.vmx86 0090.04.91
com.vmware.kext.vmnet 0090.04.91
com.vmware.kext.vsockets 90.4.22
com.vmware.kext.vmci 90.4.18
com.FTDI.driver.FTDIUSBSerialDriver 2.2.18
tc.tctechnologies.driver.AlesisFirewire 3.5.6 11675
com.apple.filesystems.smbfs 1.8
com.apple.driver.AppleBluetoothMultitouch 75.19
com.apple.filesystems.autofs 3.0
com.apple.driver.AudioAUUC 1.60
com.apple.driver.IOBluetoothSCOAudioDriver 4.1.3f3
com.apple.driver.AppleHWSensor 1.9.5d0
com.apple.driver.AppleHDA 2.3.7fc4
com.apple.driver.AppleUSBCDCACMData 4.1.23
com.apple.iokit.CSRBluetoothHCIControllerUSBTransport 4.1.3f3
com.apple.driver.ACPI_SMC_PlatformPlugin 1.0.0
com.apple.driver.AppleLPC 1.6.0
com.apple.driver.AppleBacklight 170.2.5
com.apple.driver.AppleUSBCDC 4.1.23
com.apple.driver.AppleUpstreamUserClient 3.5.10
com.apple.driver.AppleMCCSControl 1.1.11
com.apple.kext.AMDFramebuffer 8.1.0
com.apple.ATIRadeonX2000 8.1.0
com.apple.iokit.IOUserEthernet 1.0.0d1
com.apple.iokit.IOBluetoothSerialManager 4.1.3f3
com.apple.Dont_Steal_Mac_OS_X 7.0.0
com.apple.driver.ApplePolicyControl 3.3.0
com.apple.driver.MaxTranserSizeOverrideDriver 3.1.7
com.apple.driver.AppleIRController 320.15
com.apple.iokit.SCSITaskUserClient 3.5.5
com.apple.AppleFSCompression.AppleFSCompressionTypeDataless 1.0.0d1
com.apple.AppleFSCompression.AppleFSCompressionTypeZlib 1.0.0d1
com.apple.BootCache 34
com.apple.driver.XsanFilter 404
com.apple.iokit.IOAHCIBlockStorage 2.3.1
com.apple.driver.AppleRTC 1.5
com.apple.driver.AppleUSBHub 5.5.5
com.apple.iokit.AppleYukon2 3.2.3b1
com.apple.driver.AirPortBrcm43224 600.36.17
com.apple.driver.AppleFWOHCI 4.9.6
com.apple.driver.AppleAHCIPort 2.5.1
com.apple.driver.AppleIntelPIIXATA 2.5.1
com.apple.driver.AppleUSBEHCI 5.5.0
com.apple.driver.AppleUSBUHCI 5.2.5
com.apple.driver.AppleEFINVRAM 1.7
com.apple.driver.AppleHPET 1.8
com.apple.driver.AppleACPIButtons 1.7
com.apple.driver.AppleSMBIOS 1.9
com.apple.driver.AppleACPIEC 1.7
com.apple.driver.AppleAPIC 1.6
com.apple.driver.AppleIntelCPUPowerManagementClient 196.0.0
com.apple.nke.applicationfirewall 4.0.39
com.apple.security.quarantine 2
com.apple.driver.AppleIntelCPUPowerManagement 196.0.0
com.apple.driver.IOBluetoothHIDDriver 4.1.3f3
com.apple.driver.AppleMultitouchDriver 235.29
com.apple.kext.triggers 1.0
com.apple.driver.DspFuncLib 2.3.7fc4
com.apple.iokit.IOFireWireIP 2.2.5
com.apple.iokit.AppleBluetoothHCIControllerUSBTransport 4.1.3f3
com.apple.driver.AppleUSBCDCACMControl 4.1.23
com.apple.driver.AppleHDAController 2.3.7fc4
com.apple.iokit.IOHDAFamily 2.3.7fc4
com.apple.driver.IOPlatformPluginLegacy 1.0.0
com.apple.driver.IOPlatformPluginFamily 5.3.0d51
com.apple.driver.AppleBacklightExpert 1.0.4
com.apple.driver.AppleSMBusController 1.0.11d0
com.apple.kext.AMD2600Controller 8.1.0
com.apple.kext.AMDSupport 8.1.0
com.apple.iokit.IOSurface 86.0.4
com.apple.iokit.IOSerialFamily 10.0.6
com.apple.iokit.IOBluetoothFamily 4.1.3f3
com.apple.driver.AppleSMC 3.1.4d2
com.apple.iokit.IOAudioFamily 1.8.9fc11
com.apple.kext.OSvKernDSPLib 1.6
com.apple.driver.AppleGraphicsControl 3.3.0
com.apple.iokit.IONDRVSupport 2.3.7
com.apple.iokit.IOGraphicsFamily 2.3.7
com.apple.driver.AppleUSBHIDKeyboard 170.2
com.apple.driver.AppleHIDKeyboard 170.2
com.apple.iokit.IOSCSIBlockCommandsDevice 3.5.5
com.apple.iokit.IOUSBMassStorageClass 3.5.1
com.apple.iokit.IOUSBHIDDriver 5.2.5
com.apple.driver.AppleUSBMergeNub 5.5.5
com.apple.driver.AppleUSBComposite 5.2.5
com.apple.iokit.IOSCSIMultimediaCommandsDevice 3.5.5
com.apple.iokit.IOBDStorageFamily 1.7
com.apple.iokit.IODVDStorageFamily 1.7.1
com.apple.iokit.IOCDStorageFamily 1.7.1
com.apple.iokit.IOATAPIProtocolTransport 3.5.0
com.apple.iokit.IOSCSIArchitectureModelFamily 3.5.5
com.apple.iokit.IOUSBUserClient 5.5.5
com.apple.iokit.IO80211Family 522.4
com.apple.iokit.IONetworkingFamily 3.0
com.apple.iokit.IOFireWireFamily 4.5.5
com.apple.iokit.IOAHCIFamily 2.3.1
com.apple.iokit.IOATAFamily 2.5.1
com.apple.iokit.IOUSBFamily 5.5.5
com.apple.driver.AppleEFIRuntime 1.7
com.apple.iokit.IOHIDFamily 1.8.1
com.apple.iokit.IOSMBusFamily 1.1
com.apple.security.sandbox 220.2
com.apple.kext.AppleMatch 1.0.0d1
com.apple.security.TMSafetyNet 7
com.apple.driver.DiskImages 345
com.apple.iokit.IOStorageFamily 1.8
com.apple.driver.AppleKeyStore 28.21
com.apple.driver.AppleACPIPlatform 1.7
com.apple.iokit.IOPCIFamily 2.7.3
com.apple.iokit.IOACPIFamily 1.4
com.apple.kec.corecrypto 1.0
Moderator edit: [code] [/code] tags added.
ralfieroo
I am having nearly the exact same issue with my mid-2012 macbook.  My mac does a kernel panic randomly when I unplug the Arduino.  This is incredibly frustrating for development as it seems the only way I can reliably stop the code/serial monitor and upload a new version is to unplug the usb cable from the Arduino.  The Kernel Panic happens randomly somewhere between the 2nd and 10th unplugging of the Arduino.  Always on the unplugging.
Here is my environment:
macbook 2.7Ghz Core i7
OS X 10.7.5
Arduino 1.0.2
Boards: Happens when working with both UNO and MEGA boards
This is a serious bummer and I would appreciate any recommendations if anyone has solved this problem.
Thanks,
Dave
cmiyc
The only time this has even been an issue for me was when the code on the Arduino was sending (too much?) Serial data at a near constant rate.  Small delays helped.
ralfieroo
Just an update:
  Not to be a "quitter" but I really had too much development to keep fiddling with the mac and I had a perfectly good Ubuntu linux PC sitting right next to it.  I've switched my Arduino development to that linux PC and I've had no problems.  Can plug and unplug Arduino's to my heart's content.
Dave
AJB2K3
Currently running version 152 on OSX 10.8.3 with no problems.!
Sorry for the noobish post but my knowledge is 10 years out of date!
westfw
Running all sorts of things on 10.7.5 and never had a problem.
OTOH, I don't unplug my Arduinos while they're generating serial data, either.  Hardly ever.
powellbob424
Has anyone found a solution, or an idea of where this is coming from yet?  It just happened again using IDE version 1.0.4 and uploading a sketch.  I have a late '08, 17" Macbook Pro running 10.8.3.  My panic report is just as uninformative as the one already posted.
Another detail, this crash always happens when uploading to a board.  In my case, a genuine Arduino UNO R3.  It has not happened with the Leonardo yet.
When my Mac crashed this morning, I had only the Arduino IDE and Google Chrome running, in addition to the normal Mac processes.  In order to eliminate the possibility of another USB device confusing the OS, all external devices, other than the Uno, were disconnected.
