Topic: simple sketch question (Read 820 times) previous topic - next topic
markthespark
Sep 22, 2012, 05:51 pm Last Edit: Sep 22, 2012, 09:23 pm by markthespark Reason: 1
hi all
i have this sketch but it aal runs as one sketch i would like for it to 3 different sketches in one
i would like led1 to blink constantly led2 to blink more slowly as led 3 but the problem i have is thet led 2 follows led 1 and led 3 follows led2 i would like them to blink seperatly can this be done and how i'm still a noob ?
the idea is for a halloween mouth
led1 blink eyes
led2 mouth open
led3 mouth close
cheers marko
sketch
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  This example code is in the public domain.
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
int led1 = 9;
int led2 = 10;
int led3 = 11;
// the setup routine runs once when you press reset:
  // initialize the digital pin as an output.
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
// the loop routine runs over and over again forever:
  digitalWrite(led1, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(150);               // wait for a second
  digitalWrite(led1, LOW);    // turn the LED off by making the voltage LOW
    digitalWrite(led2, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(led2, LOW);    // turn the LED off by making the voltage LOW
  delay(150);
    digitalWrite(led3, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(500);               // wait for a second
  digitalWrite(led3, LOW);    // turn the LED off by making the voltage LOW
Jimmy60
It's probably a simple fix but without the sketch how can we know?
This is always a good place to start.
http://arduino.cc/forum/index.php/topic,97455.0.html
AWOL
Blink without delay is always a good starting point.
Understand it, and many things suddenly become doable.
markthespark
#3
Sep 22, 2012, 08:45 pm Last Edit: Sep 22, 2012, 09:21 pm by markthespark Reason: 1
if i used this sketch how do i make each led have its own delay ?
/* Blink without Delay
Turns on and off a light emitting diode(LED) connected to a digital
pin, without using the delay() function.  This means that other code
can run at the same time without being interrupted by the LED code.
The circuit:
* LED attached from pin 13 to ground.
* Note: on most Arduinos, there is already an LED on the board
that's attached to pin 13, so no hardware is needed for this example.
created 2005
by David A. Mellis
modified 8 Feb 2010
by Paul Stoffregen
http://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
// constants won't change. Used here to
// set pin numbers:
const int ledPin1 =  10;      // the number of the LED pin
const int ledPin2 =  11;      // the number of the LED pin
const int ledPin3 =  12;      // the number of the LED pin
// Variables will change:
int ledState = LOW;             // ledState used to set the LED
long previousMillis = 0;        // will store last time LED was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval = 100;           // interval at which to blink (milliseconds)
  // set the digital pin as output:
  pinMode(ledPin1, OUTPUT);
  pinMode(ledPin2, OUTPUT);
  pinMode(ledPin3, OUTPUT);
  // here is where you'd put code that needs to be running all the time.
  // check to see if it's time to blink the LED; that is, if the
  // difference between the current time and last time you blinked
  // the LED is bigger than the interval at which you want to
  // blink the LED.
  unsigned long currentMillis = millis( );
  if(currentMillis - previousMillis > interval) {
    // save the last time you blinked the LED
    previousMillis = currentMillis;
    // if the LED is off turn it on and vice-versa:
    if (ledState == LOW)
      ledState = HIGH;
      ledState = LOW;
    // set the LED with the ledState of the variable:
    digitalWrite(ledPin1, ledState);
    digitalWrite(ledPin2, ledState);
    digitalWrite(ledPin3, ledState);
AWOL
You don't need to use delay.
Can you please start using code tags? My scrolling finger is hurting.
markthespark
so how do i make 3 pins blink sepperate to each other like an eye blinking while mouth chatting ?
AWOL
