Topic: DFRobot URM37 v3.2 stop working after 7-8 hours (Read 3091 times) previous topic - next topic
stan001
I have this strange issue with DFRobot's URM37 v3.2 sensors  ( http://www.dfrobot.com/wiki/index.php?title=URM37_V3.2_Ultrasonic_Sensor_(SKU:SEN0001) ) that randomly stop working/freeze after running for 7 to 8 hours ...
I was running two sensors and one of them jut stop working or at times, both of them stop working after running for a long period of time...
When the sensors freeze/stop working, it cannot be recovered even by reseting the sensors by powering it down...
The only way to recover it was by powering it off for a few hours and it will start to work again...
This seems like some sort of "charge" still in the sensors that need to be "discharged" to clear the freeze...
I've got this URM37 working with NewPing library by teckel ( http://arduino.cc/forum/index.php/topic,106043.240.html ) , Mode 1 ( Serial ) , Mode 2 ( Autonomous ) and Mode 3 ( Passive PWM ) ( http://www.dfrobot.com/wiki/index.php?title=URM37_V3.2_Ultrasonic_Sensor_(SKU:SEN0001) ) but the same symptoms of freeze/hang after a long period still shows up..
Any ideas/suggestions on how to resolve this strange issue... as it happens to both my sensors..
Thank you
MarkT
When the sensor freezes, have you tried just reseting the Arduino?  If that clears the problem is suggests software issue, else it is likely hardware.  When its failing check the power supply voltage is adequate - check if the on-board regulator getting very hot.
stan001
Thanks for the suggestions..
Tried resetting both the Arduino UNO & the sensors... no changes...
Let me check the on-board regulator and power related issues...
teckel
Thank you
It sounds like the poor little thing is overheating.  My suggestion is to change the time between pings or the ping delay so it's twice as long.  I'd guess that would either cause it not to lock up or to lock up after a longer period of time.  It really doesn't sound like a software issue because it doesn't work for an hour when this happens.  If it was software, cycling power would restart it right away.
Tim
My hardware: Arduino, Teensy 2.0, Teensy 3.2 & custom ATmega328
My libraries: NewPing, LCDBitmap, toneAC, toneAC2, NewTone, TimerFreeTone
My Projects: https://dogblocker.com & https://baconorbeer.com
My beer: Great Lakes Brewing Co. Lake Erie Monster
stan001
#4
Oct 01, 2012, 07:57 pm Last Edit: Oct 01, 2012, 08:02 pm by Stanley Reason: 1
To prove my point that this sensor is going nuts/faulty, I hook up an Ethernet shield and send the both the URM37 distance sensors feed to cosm.com every second so that I can "see" when the sensor is operational and when it decide to go on strike...
https://cosm.com/feeds/78111
Any idea why/how such things could happen ?
The power regulator on the sensor is not hot at all and I'm powering this up using a 12V 5A SMPS to the DC socket...
Getting the sensor reading every 1000ms ...
The full codes below for the URM37 using Cosm & HttpClient libraries
Code: [Select]
#include <SPI.h>
#include <Ethernet.h>
#include <HttpClient.h>
#include <Cosm.h>
// MAC address for your Ethernet shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// Your Cosm key to let you upload data
char cosmKey[] = "PutYourAPIKeyHere";
// Define the strings for our datastream IDs
char sensorId[] = "Range1";
char sensorId2[] = "Range2";
CosmDatastream datastreams[] = {
 CosmDatastream(sensorId, strlen(sensorId), DATASTREAM_INT),
 CosmDatastream(sensorId2, strlen(sensorId), DATASTREAM_INT),
// Finally, wrap the datastreams into a feed
CosmFeed feed(78111, datastreams, 2 ); // Setup a new stream device/feed ans put the Feed ID here
IPAddress ip(192,168,0,50);  // Change to your IP address
EthernetClient client;
CosmClient cosmclient(client);
// URM Defines
unsigned int i=0;
int URPWM   = 2;   // PWM pin
int URTRIG  = 3;    // Trigger pin
int URPWM2  = 4;  // PWM2 pin
int URTRIG2 = 5;  // Trigger2 pin
unsigned int Distance,Distance2=0;
uint8_t EnPwmCmd[4]={0x44,0x02,0xbb,0x01};    // distance measure command
void setup(){
  Serial.println("Starting single datastream upload to Cosm...");
  Serial.println("Starting Ethernet Client...");
// Setting up Ethernet static IP address
  Ethernet.begin(mac, ip);
  Serial.println("Ethernet client & IP address OK");
// URM Setup
  PWM_Mode_Setup();
  Serial.println("Setting up URM37 PWM Mode...");
  delay(500);   // Wait for sensors to startup...
PWM_Mode();
delay(1000);  // 1 sec per feed updates
//PWM mode setup function
void PWM_Mode_Setup(){
 pinMode(URTRIG,OUTPUT);                     // A low pull on pin COMP/TRIG
 pinMode(URTRIG2,OUTPUT);
 digitalWrite(URTRIG,HIGH);                  // Set to HIGH
 digitalWrite(URTRIG2,HIGH);                  // Set to HIGH
 pinMode(URPWM, INPUT);                      // Sending Enable PWM mode command
 pinMode(URPWM2, INPUT);                      // Sending Enable PWM mode command
 for(int i=0;i<4;i++){
     Serial.write(EnPwmCmd[i]);
void PWM_Mode(){                              // a low pull on pin COMP/TRIG  triggering a sensor reading
   digitalWrite(URTRIG, LOW);
   delay(1);
   digitalWrite(URTRIG, HIGH);               // reading Pin PWM will output pulses
   unsigned long DistanceMeasured=pulseIn(URPWM,LOW);
   delay(10); // slight delays between sensors
   digitalWrite(URTRIG2, LOW);
   delay(1);
   digitalWrite(URTRIG2, HIGH);               // reading Pin PWM will output pulses
   unsigned long DistanceMeasured2=pulseIn(URPWM2,LOW);
   if( DistanceMeasured >= 50000 || DistanceMeasured2 >= 50000){
     Serial.print("PWM Error Values");
   else{
     Distance=DistanceMeasured/50;           // every 50us low level stands for 1cm
     Distance2=DistanceMeasured2/50;           // every 50us low level stands for 1cm
 datastreams[0].setInt(Distance);
 datastreams[1].setInt(Distance2);
 Serial.print("Distance1 :");
 Serial.println(datastreams[0].getInt());
 Serial.print("Distance2 :");
 Serial.println(datastreams[1].getInt());
 int ret = cosmclient.put(feed,cosmKey);
 Serial.print("cosmclient.put returned ");
 Serial.println(ret);
teckel
I'd still guess overheating.  It's basically a speaker which is a moving part.  For kicks, make the sensor ping every 2 seconds instead of 1 second and see if the pattern changes.
Tim
stan001
Tim
Tim,
Thanks for the suggestions.. I also suspect it was caused by overheating issues...
I hv changed the delay to 2 secs and added a small 12V fan blowing at both the sensors since my input power was 12V SMPS..
I've changed back to serial TTL as I can also get the onboard temp sensors too.. added the fields for temp1 & temp2 on Cosm for further analysis...
