Topic: Add delay to "digitalWrite( ledPin,LOW);" via a pushbutton and resume code (Read 3493 times) previous topic - next topic
Alvingston
Hello there, I'm a complete begginer in programming for the Arduino and need some help...
I'm building a lucid dreaming induction device, that while asleep and dreaming would deliver flashing lights to recognize the dream state.
The Arduino flashes my desktop lamp through a relay (works fine).
The code does the following:
relay off (40 min)
alarm (blinking)
relay off (10 min)
alarm (blinking)
relay off (10 min)
alarm (blinking)
relay off (10 min)
alarm (blinking)
The problem is:
that if the "alarm"  wakes me up I can't fall asleep again because the next alarm will go off in ten minutes.
-Possible solutions-
When woken up in the middle of the night, press a debounced pushbutton or switch to:
1. Somehow add a twenty minute delay (my sleep onset time) before resuming the alarm pattern. I've thought of using interrupts but as they cannot contain the delay function, I'm pretty lost...
or
2. When the switch is pressed, skip or silence the next two alarms.  Tried control statements but couldn't sort it out.
Hope I made myself clear... :~
Thank you in advance
johnwasser
Perhaps you could press the Reset button or briefly ground the Reset pin to re-start the sketch.
nickgammon
Alvingston
Thank you for your quick replies.
Pressing reset didn't solve it cause the delays between alarms change throught the night so the whole loop is 8 hours long.
I've finally come across a solution utilising a switch, and applying the following function (onset) before the alarm function:
void onset ()  {
  reading = digitalRead(inPin);
  if (reading == HIGH &&  previous == LOW && millis() - time > debounce && count == false) {
    digitalWrite(pinLed, LOW);
    delay(Onset);
    time = millis();
    count = true;
    previous = reading;
    if (reading == LOW && count == true && millis() - time > debounce) {
      { digitalWrite(pinLed, LOW);
    delay(Onset);
    previous = reading;
      time = millis();
   count = false;
Here's the whole code, please excuse the poor code readability, and spanish comments.
-----DreamLux-----
Utilise any bedside lamp to trigger lucid dreams via flashing light from the lamp.
Activated in REM stage via The Singularuty App (iOS) or built-in REM timer.
int inPin =7;
int Onset = 600000;
int state = HIGH;
int reading;
int previous = LOW;
long time = 0;         // the last time the output pin was toggled
long debounce = 200;   // the debounce time, increase if the output flickers
boolean count = false;
//Aquí almacenamos los datos recogidos del LDR:
int valorLDR = 0;
//Decimos que pines vamos a utilizar para LED o Rele (pin 2)
int pinLed = 2;
//Y que pin para la LDR
int pinLDR = 0;
  //Establecemos como salida los pines para LED
  pinMode(pinLed, OUTPUT);
  pinMode(inPin, INPUT);
  delay(5000);
  alarma (); //Alarma de TEST
  delay(60000); //Previene que se active el programa de forma accidental
  //Guardamos el valor leido en una variable
  valorLDR = analogRead(pinLDR);
  //Y comenzamos las comparaciones:
  /*if(valorLDR >= 800)
  { alarma (); // ALARMA
  delay(20000); //Permite que aunque salga luz de la pantalla solo se den los flashes indicados (20s)
  while(valorLDR >=800)
    delay(40000); //Permite que aunque salga luz de la pantalla solo se den los flashes indicados (40s)
    if(valorLDR > 1)
     digitalWrite(pinLed, LOW);  // Mantiene apagada la luz siempre que la pantalla este negra
      else // Activa el programa 2 si no hay LDR conectada- REM TIMERS
          for (int x=0;x<2;x++) // Señal de que DreamLux opera en modo REM TIMER ALARM
          digitalWrite(pinLed, HIGH);
          delay(2000);
          digitalWrite(13, LOW);
          delay(1200000);  // Sleep onset 20 min
          delay(5400000); //1 Cycle
          delay(5400000); //2 Cycle
          delay(4500000); //3 Cycle
          onset ();
          alarma ();
          delay(900000); // 15 min delay till next alarm
          onset ();
          alarma ();
          delay(4200000); // 4 Cycle
          onset ();
          alarma ();
          delay(600000); // 10 min delay till next alarm
          onset ();
          alarma ();
          onset ();
          alarma ();
          delay(3600000); // 5 Cycle
          onset ();
          alarma ();
          alarma ();
          onset ();
          alarma_5 ();
          // alarma desactivada poca eficacia final de REM [alarma ();]
          delay(2700000); // 6 Cycle
          for(int i=0;i<10;i++)
          { alarma_5 ();
//Distintos tipos de alarma
void alarma_singular ()
      {digitalWrite(pinLed, HIGH);
void alarma () { for (int x=0;x<10;x++) // Alarma de 10 flashes a 1HZ
      {  digitalWrite(pinLed, HIGH);
void alarma_5 () { for (int x=0;x<5;x++) // Alarma de 5 flashes a 1HZ
void alarma_15 () { for (int x=0;x<15;x++) // Alarma de 15 flashes a 1HZ
void alarma_inception () {  for (int x=0;x<4;x++) //Alarma ritmica repetida 4 veces
  digitalWrite(2, HIGH);
  digitalWrite(2, LOW);
  delay(250);
  delay(250);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
void a_custom(int howManyTimes, int Freq) {
  int i;
  for (i=0; i< howManyTimes; i++) {
    delay(((1/Freq)/2)*1000);
//Funcion de retraso conectando interruptor
void onset ()  {
    delay(Onset);
    time = millis();
    count = true;
    previous = reading;
    delay(Onset);
    previous = reading;
      time = millis();
   count = false;
Thank you once again ;)
Thot
How exactly does the Arduino know you are in REM state?
There are three kind of people in the world: Those who can count, and those who can't
Alvingston
There are two ways (modes):
Mode 1 is very simplistic, it is a program that delivers flashes every 90 minutes (if you examine the code you can see it's a bit finetuned) hoping that it will coincide with your REM state. Unfortunately REM cycles differ from night to night making it very unreliable.
Mode 2 uses an amazing app for the iPhone called The Singularity Experience that integrates timing of your sleep cycles (similar to mode 1) and movement via the accelerometer of the device (in REM state you sleep still due to sleep paralysis ) providing a very good determination of the sleep state as experienced by the developer in comparison to a Zeo band. The app iluminates the iPhone screen when you are in REM and via a LDR the arduino gets the trigger signal to deliver the flashes through my bedside lamp.
