Topic: HOw to detect the flow of water through a pipe (Read 12421 times) previous topic - next topic
travis12
Hi, I need to detectt the flow of water through a pipe of 1" Diameter but  I can't find anything to do the job  :(
This is exactly what I need but for 1"
This is the SeeedStudio Liquid Flow Switch. This sensor works as a switch, conducts while flow pass though. It features the maximum resistance of 100 ohm. Maximum load current is 1.0A and the maximum load power is 10W. More information is given in specification tab. Color may vary. The thread is a 1/2 inch NPT tapered thread, one on each end.
Does somebody saw something like this for 1" somewhere? Any other idea of how I can detect the flow of water through the pipe, the pipe is always full of water, but I need to know when the flow start.
Thank you!
johnwasser
Here's one.  It has male threads on both ends so you may need an adapter:  http://www.aliexpress.com/item-img/Small-Size-Plastic-Piston-Flow-Switch-1-inch/326245735.html
travis12
#2
Sep 25, 2012, 05:48 am Last Edit: Sep 25, 2012, 07:13 am by travis12 Reason: 1
Thank you johnwasser, I never bough something from China, but I think it will be my only choice. I don´t have nothing againt China products, but hope the shipping don´t take too long
tkbyd
Depending on WHY you want to know about flow, and what flows are involved, two "answers" may be available....
a) Keep an eye on the pressure in the pipe, or the pressureS at two well chosen points.
b) Why does the water move? If it moves because of a pump, just monitor the electricity going to the pump.
(I'm not calling anyone stupid with that second suggestion.... well, unless you include me in the group. For YEARS I looked for a way to watch for leaks from my domestic water system at times when I'm away from the house... before realizing that as I am on a well, monitoring the well's pump would alert me to a leak.)
pantonvich
I got really lucky on ebay and got a new elster amco meter v-100 3/4" for $15 including shipping. It cost me an additional $18 for the couplings that I sourced at the local plumbing supply house - I tried to get the couplings online - but couldn't really find any thing that much cheaper based on not knowing actually what would work.
This type of meter is simple pulse and I'm using it for whole house water count.
A quick search on ebay (just now) I found a buy it now for about $46 with shipping.
woodc
Did you find any documentation for the Elster that shows the wiring info?  I found that it is "pulse count" but nothing specific about the 4 wires  :~
pantonvich
I can't recall if I found a doc or just tried different pairs - I've had mine running for 11 months - so I'll check out the color pair that I wired up and post back in the next day or so.
woodc
I worked on this some today...  If you apply 5V/ground to the red/black the other two wires (blue and yellow IIRC) will go high (5V) when the meter increments another full unit then falls low (0V) before the halfway point (need to test more to pinpoint this...manually blowing air into the fitting on my bench was getting old fast) to the next full unit and back to high at one full unit.  It appears each instance of going high marks 1 unit.
Now to decide how to use this info  :P  I am thinking of polling the unit every 30 seconds, recording the state (high or low) then incrementing a number if the state has changed.  This number will then be sent to Cosm...
If anyone has a better/different solution I am certainly open to ideas!
For the record I wish this sensor (elster amco meter v-100 3/4) had better resolution  =(  It looks like it will be great for "I used this much water today/this week" but not so great for what I wanted which is more of a "when is water being used and at what rate".  For example I just flushed a toilet and it went from a little under 14.2 to a little over 14.3 which is going to result in exactly nothing on whatever graphing solution I end up with.  I am thinking an analog sensor that changes based on the rate water flows through it might be more my speed since I care more about flow/duration
Also for the record the male threads on the meter seem to be not quite right/not standard plumbing threads.  This is according to two folks in different plumbing departments and me since one connection worked on the first try with plumbers dope and the other leaked with plumbers dope and still leaks (ever so slight drip once every few minutes) on the second try with another round of fittings and teflon tape.  Disclaimer:  I have never used plumbers dope before so I might not have used enough or let it cure long enough...
pantonvich
You need "water meter couplings" do a search on google and you will see what they look like.
See one of my comments above - they cost about $18 for a pair of them. I when too a plumbing supply place (the big box stores aren't going to have them). You should be able to find them on eBay.
Polling every 30 seconds is not going to work you will miss pulses - could use an interrupt to catch the pulses.
woodc
Thanks for the tip on the couplings!
I am not sure I can flow enough water to trigger a pulse in under 30 seconds  :smiley-mr-green:
pantonvich
I'm using the red and blue wires - the other two wires I believe are use for the taper protection feature. I don't have them connected.
this is what I do - poll the water  meter - track 5 minutes and total counts - send out the serial every 10 seconds
// Synchronization loop for long intervals (more than 32 seconds)
#define TimeLapLong(t1) (long)((unsigned long)millis()-(unsigned long)t1)
#define TimeLapWord(t1) (int)((word)millis()-(word)t1)
const long WATER_DEBOUNCE = 50;
const long TIME_SEND = 10000;
const long TIME_CLICK = 60000;
const int water_pin = 4;
unsigned long waterTotal = 0;
int waterLastRead = LOW;
unsigned long waterHit = 0;
unsigned int water5[5];
unsigned long timetosend =0;
unsigned long timeclick=0;
void setup(){
  pinMode(water_pin,INPUT);
  digitalWrite(water_pin,HIGH);
  waterLastRead = digitalRead(water_pin);
  for(int x = 0;x<5;x++) water5[x] = 0;
    if (digitalRead(water_pin) != waterLastRead &&  TimeLapWord(waterHit) >=0 ) {
waterTotal++;
        waterLastRead = !waterLastRead;
        waterHit = millis() + WATER_DEBOUNCE; //millis();
if(TimeLapLong(timeclick)>=0) {
        timeclick += TIME_CLICK; //millis();
        for(int x = 0;x<4;x++) water5[x] = water5[x+1];
        water5[4] = waterTotal;
// 10000 every 10 seconds
    if(TimeLapWord(timetosend)>=0)
      timetosend += TIME_SEND; //millis(); // += 10000; //millis();
      outbufferIdx = 0;
      OutTitle('H','0');
      OutBufferPrint(1,waterTotal,1);
      OutTitle('H','5');
      OutBufferPrint(1,waterTotal-water5[0],1);
      outbuffer[outbufferIdx++] ='\n';
      outbuffer[outbufferIdx++] ='\0';
      Serial.println(outbuffer);
void OutBufferPrint(int id, unsigned long reading,unsigned long  i) {
  unsigned long temp;
  while (i*10 <= reading){
   i*=10;
  while (i>0){
    if (outbufferIdx >= OUTBUFFER_SIZE -1) break;
     temp = reading/i;
     reading -= temp * i;
     outbuffer[outbufferIdx++] = 48+temp;
     i/=10;
MikeX
That thing looks very sketchy. Especially the screws in the plastic. :smiley-eek:
Why not get a surplus water meter and monitor it with a hall effect sensor?
woodc
So do the red and blue wires just connect to each other when the meter pulses or?
woodc
Hmmm...what version of the IDE are you running?
I tried to give your code a whirl on a spare Arduino but it exploded (see below)
watermeter.cpp: In function 'void loop()':
watermeter:43: error: 'outbufferIdx' was not declared in this scope
watermeter:45: error: 'OutTitle' was not declared in this scope
watermeter:51: error: 'outbuffer' was not declared in this scope
watermeter.cpp: In function 'void OutBufferPrint(int, long unsigned int, long unsigned int)':
watermeter:66: error: 'outbufferIdx' was not declared in this scope
watermeter:66: error: 'OUTBUFFER_SIZE' was not declared in this scope
watermeter:69: error: 'outbuffer' was not declared in this scope
watermeter:69: error: 'outbufferIdx' was not declared in this scope
watermeter:73: error: expected `}' at end of input
pantonvich
#14
Oct 29, 2012, 11:18 pm Last Edit: Oct 29, 2012, 11:20 pm by pantonvich Reason: 1
Sorry - I cut and pasted my code because it had other stuff in it. Here's the complete code unedited. I'm using ide version 18.
const long LIGHTNING_1 = 250;
const long LIGHTNING_2 = 500;
const int lightning_pin = 2;
const int errorCt = 50;
//unsigned int waterDebounce = 50;
#define OUTBUFFER_SIZE 300
char outbuffer[OUTBUFFER_SIZE+1];
int outbufferIdx = 0;
unsigned long updatesSince = 0;
unsigned int lightning=0;
unsigned long lightning10=0;
unsigned long lightningTotal=0;
unsigned long lightningTotal60=0;
unsigned int lightning60[60];
unsigned int lightningPos = 0;
unsigned long lightningAttach1 = 0;
unsigned long lightningAttach2 = 0;
void setup(){
 pinMode(lightning_pin, INPUT);
 digitalWrite(lightning_pin,HIGH);
 for(int x = 0;x<60;x++) lightning60[x] = 0;
int interupoff = 1;
int swappedState = 1;
//unsigned long timetoattach=0;
 //if (digitalRead(water_pin) != waterLastRead &&  (millis()-waterHit) > waterDebounce ) {
waterTotal++;
 int dRead = digitalRead(lightning_pin);
 //Serial.println(dRead);
 //if (swappedState == 0 && interupoff == 0 && dRead == 1 && (millis() - timetoattach) > 250) swappedState = 1;
 if (swappedState == 0 && interupoff == 0 && dRead == 1 && TimeLapWord(lightningAttach1)) swappedState = 1;
  if (interupoff == 1) {
    if ( dRead == 0) {
      lightningAdd();
} else if(TimeLapWord(lightningAttach2) && swappedState == 1){
     interupoff = 1;
   //if(millis() - timeclick > 60000) {
       lightningTotal60 = 0;
       lightning60[lightningPos]=lightning;
       for(int x = 0;x<60;x++) {
         if (lightning60[x] < errorCt) lightningTotal60 += lightning60[x];
       lightning10=0;
       int z;
       for(int x = 0;x<10;x++) {
         z = lightningPos - x;
         if (z<0) z += 60;
         if (lightning60[z] < errorCt) lightning10 += lightning60[z];
       lightningPos++;
       if (lightningPos>59) lightningPos = 0;
       lightning = 0;
   //if(millis() - timetosend > 10000)   // 10000 every 10 seconds
     outbufferIdx = 0;
     OutTitle('T','0');
     OutBufferPrint(0,lightning,1);
     OutTitle('T','t');
     OutBufferPrint(1,lightningTotal,1);
     OutTitle('T','l');
     if (lightning < errorCt) {
       OutBufferPrint(2,lightning10 + lightning,1);
       outbuffer[outbufferIdx++] = '0';
     OutTitle('T','6');
       OutBufferPrint(2,lightningTotal60 + lightning,1);
     OutTitle('H','0');
     OutTitle('H','5');
     OutTitle('T','u');
     OutBufferPrint(3,updatesSince,1000);
     updatesSince++;
     OutTitle('T','i');
     for (int x=0;x<60;x++){
       int v = (int)lightning60[x];
         if (v>9) Out('.');
         if (x == lightningPos) Out('>');
         OutBufferPrint(4,v,1);
         if (v>9) Out('.');
     Out(':');
     //OutBufferPrint(5,millis(),1);
     //Out(':');
     //OutBufferPrint(6,millis()- timeclick,1);
     //Out(':');
     //OutBufferPrint(7,dRead,1);
     //Out(':');
     OutBufferPrint(8,outbufferIdx,1);
void OutTitle(char c1, char c2)
 if (outbufferIdx < OUTBUFFER_SIZE -4) {
   outbuffer[outbufferIdx++] = '[';
   outbuffer[outbufferIdx++] = c1; //'T';
   outbuffer[outbufferIdx++] = c2;
   outbuffer[outbufferIdx++] = ']';
void Out(char c)
 if (outbufferIdx < OUTBUFFER_SIZE -1) {
 outbuffer[outbufferIdx++] = c;
 unsigned long temp;
 //if (id > 10){
 //  outbuffer[outbufferIdx++] = 48+(id/10);
  // id -= (id/10)*10;
 //outbuffer[outbufferIdx++] = ',';
  i*=10;
 while (i>0){
    temp = reading/i;
    i/=10;
void lightningAdd()
 //timetoattach = millis();
 lightningAttach1 = millis() + LIGHTNING_1;
 lightningAttach2 = millis() + LIGHTNING_2;
 interupoff = 0;
 swappedState = 0;
 lightning++;
 lightningTotal++;
//int freeRam1 () {
//  extern int __heap_start, *__brkval;
//  int v;
//  return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval);
