Topic: Bluetooth Shield COM problem (Read 1 time) previous topic - next topic
zuzzuz
Sep 25, 2012, 09:35 am Last Edit: Sep 25, 2012, 10:08 am by zuzzuz Reason: 1
Hi, i have this shield http://iteadstudio.com/store/index.php?main_page=product_info&cPath=18&products_id=307
I can't have data back from BT COM, for test i used this sketch
Code: [Select]
unsigned int timeout=0;
unsigned char state=0;
ISR(TIMER2_OVF_vect)          //Timer2  Service
 TCNT2 = 0;
 timeout++;
 if (timeout>61)
   state=1;
   timeout=0;
void init_timer2(void)
 TCCR2A |= (1 << WGM21) | (1 << WGM20);
 TCCR2B |= 0x07;   // by clk/1024
 ASSR |= (0<<AS2);  // Use internal clock - external clock not used in Arduino
 TIMSK2 |= 0x01;   //Timer2 Overflow Interrupt Enable
 TCNT2 = 0;
 sei();
 pinMode(2,INPUT);
 pinMode(13,OUTPUT);
 attachInterrupt(0,cleantime,FALLING);
 init_timer2();
 switch(state)
 case 0:
   digitalWrite(13,LOW);
 case 1:
   digitalWrite(13,HIGH);
   Serial.print("Hellow BT");
void cleantime()
 timeout=0;
 state=0;
This is what i see from my computer
As u can see USB port is OK but COM9 data is bad
Have someone the same shield? Can someone help me?
Thx bye
PaulS
Code: [Select]
    state=1;
  switch(state)
void cleantime()
  state=0;
And, yet, state is not declared volatile. Is there a reason for that?
Ditto for timeout.
Finally, forgive me for asking what might be a really obvious question. Why are you creating such a complex sketch to test whether the bluetooth device works?
zuzzuz
This is test sketch that i found in documentation of this shield.
I solved my problem changing my BT adapter, i think my old adapter was dead.
Thx
