Topic: Change I2C-address of the srf08 with arduino (Read 1 time) previous topic - next topic
iToby
I want to change the I2C-address of a srf08 ultrasonic sensor with an arduino UNO.
I shifted the Codes but it does not work:
Code: [Select]
#include <Wire.h>
#define Old_Address 0x70
#define New_Address 0x72
  Wire.begin();
  delay(100);
    Wire.beginTransmission(Old_Address);
    Wire.write(0);
    //Wire.write(0xA0);
    Wire.write(0x50);
    Wire.endTransmission();
    delay(60);
    Wire.write(0);
    //Wire.write(0xAA);
    Wire.write(0x55);
    delay(60);
    Wire.write(0);
    //Wire.write(0xA5);
    Wire.write(0x52);
    delay(60);
    Wire.write(0);
    Wire.write(New_Address);
    delay(60);
void loop(){
pylon
You have to send it in one sequence, not 4 and use the correct values as the datasheet describes:
Code: [Select]
#include <Wire.h>
#define New_Address 0xF2
  Wire.begin();
  delay(100);
    Wire.write(0);
    //Wire.write(0xA0);
    Wire.write(0x50);
    delay(60);
    Wire.write(0xA0);
    Wire.write(0xAA);
    Wire.write(0xA5);
void loop(){
After that you have to use the new address, which will be 0x79 (8bit 0xF2 shifted to the right one bit).
iToby
#2
Oct 23, 2012, 08:44 am Last Edit: Oct 23, 2012, 08:52 am by iToby Reason: 1
It is still not working.  :smiley-slim:
Code: [Select]
#include <Wire.h>
 Wire.begin();
 delay(100);
   Wire.write(0xA0);
   delay(50);
   Wire.write(0xAA);
   delay(50);
   Wire.write(0xA5);
   delay(50);
void loop(){
iToby
Ok. I have it. Thank you for your help!
Code: [Select]
#include <Wire.h>
#define oldad 0x70
#define newad 0xE4
  Wire.begin();
  delay(100);
    Wire.beginTransmission(oldad);
    Wire.write(0x00);
    Wire.write(0xA0);
    delay(60);
    Wire.write(0x00);
    Wire.write(0xAA);
    delay(60);
    Wire.write(0x00);
    Wire.write(0xA5);
    delay(60);
    Wire.write(0x00);
    Wire.write(newad);
void loop(){
