Topic: Using SD card only for the initial configuration: how eject it? (Read 2628 times) previous topic - next topic
yggdrasilien
I have the Arduino Ethernet Shield with an SD card reader.
I would like read the SD card only while the setup() process. As soon as the program runs the main loop I wish remove my SD card (for using it with another Arduino project or with my camera). Well, after reading my configuration my SD card is useless.
Which code I have to write for a clean eject? Just closing my ini file, some pins to power off?
During the setup my 13-led is HIGH. So while this led switch off, I know I can remove the card… if it is the right way.
PaulS
What does this mean? You need to throw it away and buy a new one?
All that really needs to be done is close all open files, and make sure you never try to access the device in loop(). Setting the slave select pin HIGH again wouldn't hurt.
yggdrasilien
Don't panic, all is right ;)
Just that I'm rewriting my configuration in a text file instead as #define in an header file. And my code about the SD is only in my setup.
Thanks!
MattiasOfTheMetal
Another alternative:
Set a DoOnce variable at the start of the loop, have it open/read/close the file on the SD card, then set DoOnce again so it doesn't repeat it until next bootup.
Like:
int DoOnce;
//Your code here
digitalWrite(13,HIGH);  //Optional status led
if (DoOnce==0)
    //Your code to open, read, and close here
  digitalWrite(13,LOW);  //Goes along with the Setup status led
  DoOnce=1;
//Rest of your code
Food for thought.
Nom.
