Topic: The HATRED for String objects - "To String, or not to String" (Read 37535 times) previous topic - next topic
GoForSmoke
For most cases this will result in no pointer change at all and a simple adjustment of the allocated length - usually out into free space in most use-cases on a small system like this.
Assuming the String is at the top of the heap in 'most cases'. Otherwise not.
Andy Brown, I think you will find that Nick knows more about the code than you credit. And he isn't given to make unfounded claims.
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
3) http://gammon.com.au/interrupts
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
zoomkat
So is there anything in the external programming that can be done to free the no longer used allocated memory space?
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
retrolefty
Perhaps enable the WDT, let if time out, and have the sketch start all over?  :D
zoomkat
Quote
Close to what my magic 8-Ball suggested.  :)
nickgammon
I don't have any argument with Andy. I think he has the fixed malloc/free library on his site anyway.
There is a bug in 'free' in the current Arduino library. I think we are all agreed on that. What Andy says about free spaces being combined by the library would almost certainly be correct. But the bug in question is something to do with the first (or last?) allocated block not being freed correctly, or something like that.
I have heard people say that, with the fixed free() installed, they can use String objects at some length with no problems, which supports what Andy says about the library combining unused blocks.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
nickgammon
In one of the threads about this problem I suggested incorporating the corrected free function into existing code, and having a define along the lines of:
Code: [Select]
#define free myfree
in one of the header files that gets pulled into all libraries (including the String library). For the sake of a few dozen extra instructions you then have a workaround until the real library is fixed.
zoomkat
Quote
Then is there any way in the code to keep that particular block filled with nothing?
GoForSmoke
I took what Andy wrote to be saying there is no bug/problem. My error.
pYro_65
global variables work better for me and I haven't heard of a good reason I should avoid them in my Arduino sketches.
Lefty
I can share at least one reason why you should reconsider globals. Here is a little sketch showing how a global can cause a very bad day.
This calculates the square of 2.
Code: [Select]
   //A global
   int i = 666;
   template <typename T> struct Base{
     Base( int i_NewVal ) : i( i_NewVal ) {return;}
     int i;
   template <typename T> struct Squared : public Base<T>{
     Squared( int i_NewVal ) : Base<T>( i_NewVal * i_NewVal ) {return;}
     T Result() { return i; }
      Squared< long > s_Square( 2 );
      Serial.begin( 9600 );
      Serial.print( "2 squared = " );
      Serial.print( s_Square.Result() );
      return;
  void loop(){return;}
Forum Mod anyone?
https://arduino.land/Moduino/
nickgammon
Code: [Select]
   int i = 666;
I haven't even tried to run your sketch, but straight away, I sense trouble. ;)
marcello.romani
@pyro
You sketch is not about globals, rather it warns of the perils one faces by using poorly named variables :)
pYro_65
The name of the variable could be something intuitive, I used 'i' for this example.
It does not affect the example. The sketch below works fine.
Code: [Select]
   //A global
   int i = 666;
      int i = 2 * 2;
      Serial.print( i );
      return;
In my previous example,
The global is a non-dependant name, it is satisfying a rule where non-dependant names in dependant types take the last definition seen. The compiler doesn't consider the base class during name lookup, even though its 'i' is the closer scope. This is quite different to the snippet above where the closer scope is setup::i which is also used.
So rather than receiving an error about 'i' being undefined in the class ( 'this->' is required to make the name dependant ), the previous definition of 'i' is silently used.
As a minimum, place the global in a namespace so it has to be explicitly used.
Forum Mod anyone?
marcello.romani
Quote
Very interesting posts. I would add as a minimum don't go against common practices by naming a global with a name usually "reserved" for narrow-scoped counters and array indexes. IOW, don't produce code that's confusing to _read_ in the first place. :)
PaulS
Quote
I see it more as a problem with having local and global variables with the same name, and making assumptions about which will be used when.
Having local and global variables of the same name is rarely a good idea.
nickgammon
I going to agree with PaulS here. In your (rather obscure) example pYro_65 you set up a case where the compiler chose a global instead of a class variable by using the same name for both. To fix the sketch BTW you need to change the derived class to:
Code: [Select]
public Base<T>{
    return;
  T Result() {
    return Base<T>::i;
Notice the qualification of "i" there. But you could say the same thing about virtually any variable. If you had a global i_NewVal and then misspelt i_NewVal in the constructor you would have a similar issue.
