Topic: The HATRED for String objects - "To String, or not to String" (Read 34484 times) previous topic - next topic
nickgammon
Re-entrant would also be where an ISR calls a function.
Say you are in the middle of a Serial.print. A timer interrupt fires. Inside the timer you do a Serial.print (a bad idea, I know). Then the Serial.print function is "re entered". And say inside Serial.print it keeps a variable (eg. for working out how to convert a float). That variable is now changed by the re-entry. So the original one (the one that got interrupted) is now corrupted.
This is another reason why you should keep interrupt service routines short. And why those people that try to work around Serial.print "not working" inside an ISR by adding a line to turn interrupts on, are really shooting themselves in the foot.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
Bachi
Regarding the String class, there is actually a method 'reserve()' that was added with 1.0.
Strange enough totally undocumented on http://arduino.cc/en/Reference/StringObject, but available: http://code.google.com/p/arduino/issues/detail?id=449
I assume with this many dynamic mem allocation probs should be solved if one stays within the reserved memory. And we still can use the richer api. Tested it and it solved my mem leak problem immediately.
GoForSmoke
Is it love of C++ String, dislike of C string or just not used to C string that drives people to accept the behind your back actions and overhead RAM bytes of C++ String?
Look at all String does to "make it easier" to manipulate text in a number-like manner. Ooooh! Power windows! Hey, turn the car on just so I can open the window! No, that's not inefficient, that's con-veeen-yence!
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
3) http://gammon.com.au/interrupts
zoomkat
How is your world of horses, buggies, and telegrams/bag phones? C strings are difficult for non programmers like me and appear to somewhat primitive operations compared to the ease of Strings. The "old timers" just don't get it.  ;)
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
GoForSmoke
When you're on a horse, you don't expect a steering wheel. An MCU is not a PC.
As far as not knowing C strings, once you understand what a char array with NULL terminator the rest with few exceptions is very straightforward. Yes there is some memorizing of shortened words but strcat() means string concatenation isn't hieroglyphs. Strtok() takes a bit of study but after writing your own array parsing it's no surprise at all. In fact I'd go so far as to say that writing your own version of any of those commands and then refining/rewriting to compact code will teach not only C string but better array handling and coding in general.
The old timers get that an MCU is not a PC. Many of us have written lots of code on both. We know to avoid the traps that the inexperienced walk right into and would rather save others from wasting their time.
michinyon
I find C++ Strings  annoying and unreliable on any platform.   In Java I use strings  but in C++ I use C-style char arrays.
AWOL
Quote
I saw a feature on TV recently about small-scale logging, using draught horses to extract the timber.
The horses could go where the tractors could not, and their impact on the environment much less, and they could work woodlands too small for ordinary commercial operations.
A reasonable analogy, I think.
The right tool/technique for the right problem.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
RudiAhlers
I'm fairly new to Arduino's, and C coding for that matter as well but have done PHP / MySQL / ASP / HTML coding before.
Can someone please explain to me, what to use if we shouldn't use strings? I see, in many forum posts, where people have problems they're simply being told "don't use strings", and more often than not no sample of an alternative piece of code is given for their problem so the OP in said forum thread doesn't learn anything. And, consequently other newbies don't learn anything useful either and still use strings, since most of the tutorials and forum sample code has them.
wildbill
C++ Strings are objects that require memory allocation routines (malloc, free) to be called when they are used. For a long time, there was a bug in the implementation of free that the arduino uses that meant that you could run out of memory, so Strings were a dangerous proposition.
More recent versions of the IDE do not have this defect, but manipulating Strings still requires that you free and allocate memory. Given that arduinos have so little RAM, there is still the possibility that you will run out of space or fragment your free memory in such a way that there isn't a big enough contiguous piece to satisfy a request. At this point, your sketch will likely fail in unexpected ways, which will be hard to debug and when you ask for help on the forums you will be told "Don't use Strings".
There's nothing inherently wrong with C++ Strings if you have the memory for them and suitable error handling for dealing with low memory conditions, but for arduino, where you don't have these things, they are not sensible, particularly if your sketch is expected to run in perpetuity. As an alternative, arrays of char let you see exactly what memory you are using without any 'sleight of hand' stuff happening behind the scenes.
nickgammon
I see, in many forum posts, where people have problems they're simply being told "don't use strings" ...
There is a terminology problem here. The posts usually say don't use "String" (which is a specific class) not "don't use strings".
Depending on your requirements you can use an array of characters using the normal C functions like strcpy and strcat. A lot of the Arduinos only have 2048 bytes of RAM, so you don't have a lot of memory for arrays, dynamically allocated strings, or anything else.
At least with manually allocated arrays you know how much memory they are taking. And for constants, you can use strings directly from program memory, eg.
Code: [Select]
Serial.println (F ("hi there"));
Quote
... where people have problems  ...
Some problems are caused by the String class, when it had bugs. Some are caused even afterwards because of memory fragmentation. Some are unrelated. However when people post a lengthy sketch, which uses String extensively (as opposed to "strings") one of the first suggestions is to rework without using the String class.
Quote
... and more often than not no sample of an alternative piece of code is given for their problem ...
I have examples below which show receiving serial data. They stores strings into static buffers but do not use "String".
http://www.gammon.com.au/forum/?id=11425
zoomkat
Don't expect any of the "string" advocates to fix your code using the "string" functions, most likely due to the fact that the real code issue rarely ever has to do with using Strings. If persons can't wrap their head around the real issue, or are just stumped, they can always say "praise Jesus, drink more milk, and don't use Stings". Maybe the cure..., maybe not.
Arrch
Give a man a fish...
PeterH
... because there have been dozens, probably hundreds, of examples posted showing how to do this yourself and it is not hard.
nickgammon
I can wrap my head around issues, thanks. When I see something obviously wrong, I mention it. If that doesn't fix it, we can move onto subtle things.
Example: If your care won't start, and it's out of petrol, that's probably the problem. Putting petrol in doesn't guarantee it will start, maybe the spark plugs are bad, but let's fix the simple stuff first.
RudiAhlers
My bad..... I didn't see the Capital S in "Strings", and misread it as "strings"
