Topic: The HATRED for String objects - "To String, or not to String" (Read 30525 times) previous topic - next topic
nickgammon
A fairly simple fix in fact is to have a naming convention for class variables, eg.
int m_myVariable;   // m_ = member; or:
int myVariable_;    // using trailing underscore on class variables
pYro_65
Yes I prefer namespaces or trailing '_G'
The example is a good point I think as many are avoiding 'this->' to keep their code 'pretty', whereas blatant use will save you without even knowing it was a problem. i_NewVal is fine as its callee scope is non-dependant. Further templated functions would require further qualification.
The important part of my post was showing how the global was the sole cause of problems, the code otherwise would not have compiled.
So rather than receiving an error about 'i' being undefined in the class ( 'this->' is required to make the name dependant ), the previous definition of 'i' is silently used.
Forum Mod anyone?
https://arduino.land/Moduino/
fiddler
Interesting and thank for clarifying this.
One question tho
When allocation static memory does that automatically become a global variable ?
Kim
marcello.romani
I'm not sure I understand your last question... Are you asking if qualifying a variable as "static" makes it global ?
Scope and lifetime are two related but distinct properties of a variable.
majenko
One question tho
Kim
No.  A global (i.e., defined in the "global" scope) variable and static variable are different.
A global can be accessed anywhere.  A static can only be accessed in the function it is defined in.  A static variable retains its value across subsequent calls to the function.
The memory for a static is, as the name suggests, static - it is always at the same location, so theoretically it can be accessed globally through the address:
int *superGlobal;
void myFunc()
  static int localStatic = 4;
  superGlobal = &localStatic; // Assign address of localStatic to superGlobal pointer
  localStatic++;
void myOtherFunc()
  int myLocal;
  myFunc();
  myLocal = *superGlobal; // "myLocal" now contains whatever localStatic contains.
Not something that is done often - it's more common to either return the value from the function, or return a pointer to the static variable.  Such functions, though, are not re-entrant, and are frowned on in today's multithreaded environments.  Perfectly fine on the Arduino though :)
marcello.romani
:smiley-eek-blue:
I hope you are aware that the code above is fine as an "extreme" didactic example, but it's definitely a coding horror(1). And the reason is, it's the perfect recipe for spaghetti code ;)
(1) As in "Code Complete 2"; see Jeff Atwood's blog icon for an effective visual representation of the concept :)
GoForSmoke
Re-entrant code can build up the stack really fast if you're not very, very careful. Remember, UNO has only 2k of RAM for stack and heap space.
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
fiddler
Thanks
Coming from Assembly and a bit of basic, I'm trying to get my head around the GNU C compiler and the way it does things.
Been reading the GNU documentation, but sometimes it is "clear as mud" :-)
K
PeterH
You're thinking of recursive code?
GoForSmoke
Right. Functions that call themselves or call others that call them, etc.
It's been a while since I wrote that kind of stuff.
majenko
Re-entrant is entirely different.
Re-entrant code can be safely called by two different threads at the same time without trashing any global / static variables.  They often involve passing of pointers to work areas to the function, so each thread has its own bit of memory.
GoForSmoke
Something else I wouldn't try with a 328P chip.
Long live the state machine!
majenko
Hell yeah :)
I had fun a bit back trying to move a few non-re-entrant library routines (from the printf family) into kernel space on RetroBSD so as to reduce user-process size (kind of a pre-cursor to shared libraries) a bit back... Not nice trying to convert them to re-entrant ;)
Delta_G
The String class is kind of like training wheels on a bicycle.  Babies need them in order to learn how to ride (or code), but as soon as you want to do anything remotely useful you have to take them off and throw them away.
So many of the "Why don't they fix this bug?" complaints could easily be rewritten as:
"Wah!  I want to be able to do BMX tricks but I'm scared to let go of my training wheels."
If at first you don't succeed, up - home - sudo - enter.
zoomkat
Wow, another String class whiner!  :smiley-roll: Sad that the String class whiners almost never correct/adjust the usually simple they constantly whine about. Sad
