Topic: Auto open Serial Monitor option please (Read 21996 times) previous topic - next topic
gandboss
Could I request that an option is added that auto opens the Serial Monitor after a successful upload please.
I have a debug monitor program  that I use for all debugging and it is tiresome to always have to manually select the Monitor after every compile.
Thanks
Graham
marcello.romani
I haven't tried this myself, but it might be worth a try:
http://www.eevblog.com/forum/microcontrollers/%28mod%29-arduino-enhanced-release-1-0-1-for-windows-%28installer-drivers-etc%29/
"Hold Control key on Upload: To open the Serial Monitor automatically when upload complete"
gandboss
That looks promising Ill try it tomorrow & let you know.
Thanks very much.
Graham
eried
Thanks very much.
Graham
New version also lets you click the open serial monitor button while uploading :D and it schedules the opening of the monitor when the upload ends (if you forget to hold Ctrl key when uploading)
My website: http://ried.cl
alfiesty
Looks real good! I'm still on 0.22, Is it version specific?
Jim
eried
Yes :( only newer arduino.
But if you want to keep 0022 you can check the changes here https://github.com/eried/Arduino/commits/master and add them to your version :D
alfiesty
From the titles it is hard to find which ones I want. I am specifically interested in 2, 3, 5, 6, 9, 11, 12.
Jim
eried
Yeah, almost all the enhancements are in the ".net upgrades". But I suggest you to go 1.0.1, I tried to keep my lovely 0023 but at the end, all new libraries are coming for the 1.0 :/ so it is like "upgrade or die"
Anyway, my modded version does not shares anything with your 0022, just set another Arduino folder in the options and you are ready to go! I have the 2 ones installed right now, no conflicts, no shared Sketches or libraries.
gandboss
Well done eried that's a huge improvement.  Thanks
Can I request a hot key to select the 'Upload then open Serial Monitor' option please.
Or better... add it as a configuration that forces this as a default when the 'upload' button is pressed.
10/10
Thanks again
Graham
eried
I didn't found a free key :( do you suggest a combination?
gandboss
Ah - I did not think of that as a snag.   :~
Ctrl 'right arrow'     ?
Any chance of a configuration setting to choose the default behaver of 'Ctrl U'   (ie with OR without the Serial Monitor launch)
Graham
marcello.romani
eried
Ctrl shift U ?
Already used, but mapping all the keys I found Ctrl+Alt+U unnused. So next week version will include that.
gandboss
Thanks for that eried (I sent you a donation for this)
Unfortunately the combination Ctrl-Alt-U produces the ascii character 250 (รบ) on my Pc running XP.
Which corrupts the source code without careful placing of the cursor  :=(
cheers
Graham
eried
Oh, I didn't noticed that. There is another menu that uses alt, can you check it?
