Loading...
Pages: [1]   Go Down
Author Topic: Midi Out delay and strange noise Problem  (Read 902 times)
Offline Offline
Newbie
View Profile
Hey Guys
i have a small Problem during my Midi Out Project. Maybe somebody can help me.
scope of work: To send a note without delay via midi out on TX Port  by pressing a button until its released.
Problem: If i push and hold the button principal the note signal works and is send without a delay and thats fine. I tryed it with my yamaha keyboard and its midi in port. The strange thing is that if i insert a delay after the noteOn message it sounds clear but without a delay time when i push the button it sounds first like going from a low frequency to a high very fast before i hear the right and clear tone. Could it be something with the debouncing time? Maybe somebody has an idea. Thanks smiley
Here is my primitive code
const int buttonPin = 4;
int buttonState = 0;
  //  Set MIDI baud rate:
  Serial.begin(31250);
  pinMode(buttonPin, INPUT);
  // play notes from F#-0 (0x1E) to F#-5 (0x5A):
   buttonState = digitalRead(buttonPin);
    int note1 = 0x40;
    //Note on channel 1 (0x90), some note value (note), middle velocity (0x45):
    if (buttonState == HIGH){
    noteOn(0x90, note1, 0x45);
      else {
//  plays a MIDI note.  Doesn't check to see that
//  cmd is greater than 127, or that data values are  less than 127:
void noteOn(int cmd, int pitch, int velocity) {
  Serial.write(cmd);
  Serial.write(pitch);
  Serial.write(velocity);
Logged
Dublin, Ireland
Offline Offline
Newbie
View Profile
WWW
I'm only beginning play with midi code but I was under the impression once you send note-on it would play until you send note-off?
Apart from that... it might also depend on how your how yamaha keyboard interprets midi signals... best bet is to add debounce...
« Last Edit: November 05, 2012, 08:17:05 pm by MikeOToole » Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Remember loop is looping constantly - you will be calling noteOn maybe a thousand times a second (depending on the serial clock for midi).
You need to detect button-down event and button-up event separately - you don't want to do actions everytime you see a state, just when you see the state change - ie a state-transition.
[BTW note use of code tags...]
Code:
int prev_state ;
void loop ()
  int state = digitalRead (buttonPin)
  if (state != prev_state)  // only do actions on state-changes
    prev_state = state ;   // record for next time
    if (state == HIGH)  // decide which action
      noteOff(...) ; // or whatever
Logged
Pages: [1]   Go Up
Print
Jump to:
