Topic: Reading data at 10 Khz rate (Read 27761 times) previous topic - next topic
graynomad
I think you'll be back soon because you don't have code that will sync with the data yet :)
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
graynomad
#31
Oct 03, 2012, 04:46 pm Last Edit: Oct 03, 2012, 05:36 pm by Graynomad Reason: 1
This seemed like an interesting problem so I spent a little time working on some code because I think you are still a long way from having a real solution.
It's a problem crying out for a state machine so here is my first pass
Code: [Select]
const int CLOCK_PIN     =     2;
const int DATA_PIN      =     4;
const int PACKET_BITS   =     128;
const int PREAMBLE_LEN  =    6;
const int DATA_LEN      =    ((PACKET_BITS / 4) - PREAMBLE_LEN);
enum {
    PRE_0,    PRE_1,    PRE_2,    PRE_3,    PRE_4,    PRE_5,    DATA
} states;
byte     preamble [] = {0x0C,0x0A,0x0A,0x0C,0x01,0x0F};
char     hexAsciiVals[] = "0123456789ABCDEF";
byte     state = PRE_0;
byte     nibble;
int        nibble_count = 0;
  pinMode(CLOCK_PIN, INPUT);
  pinMode(DATA_PIN, INPUT);
    nibble = getNibble();
    nibble_count++;
    switch (state) {
        case PRE_0:
            if (nibble_count > PREAMBLE_LEN + DATA_LEN) {
                // we've read 32 bytes and still not found a match
                // for the preamble so skip a clock pulse
                while (digitalRead(CLOCK_PIN) == HIGH);
                while (digitalRead(CLOCK_PIN) == LOW);
                nibble_count = 0;
                state = (nibble == preamble[0]) ? PRE_0 : PRE_1;
        case PRE_1:
            state = (nibble == preamble[1]) ? PRE_0 : PRE_2;
        case PRE_2:
            state = (nibble == preamble[2]) ? PRE_0 : PRE_3;
        case PRE_3:
            state = (nibble == preamble[3]) ? PRE_0 : PRE_4;
        case PRE_4:
            state = (nibble == preamble[4]) ? PRE_0 : PRE_5;
        case PRE_5:
            state = (nibble == preamble[5]) ? PRE_0 : DATA;
        case DATA:
            Serial.write (hexAsciiVals[nibble]);
            if (nibble_count == DATA_LEN) {
                // all done, start again
                state = PRE_0;
                nibble_count = 0;
byte getNibble() {
    byte val = 0;
    for (byte bit_count = 0; bit_count < 4; bit_count++) {
        val <<= 1;
        val |= digitalRead(DATA_PIN);
    return (val &= 0x0F);
It compiles but I may have stuffed up some logic, hopefully not.
As the states are contiguous you could probably replace some of the switch() cases with a simple state++ but I think this allows for changes to be more easily implemented.
______
Rob
newbee_2
#32
Oct 04, 2012, 06:56 am Last Edit: Oct 04, 2012, 07:28 am by newbee_2 Reason: 1
Yes you are absolutely right though its reads corrects value some times but once its looses its sync it does take lot of value to again com its actual position. So what could i do to make to once it looses its sync on next or in 2-3 iteration its sync again.  :(   :(
Code: [Select]
const int pin2 = 2;
const int pin4 = 4;
int clock = 0;
int clock1 = 0;
  pinMode(pin2, INPUT);
  pinMode(pin4, INPUT);
  Serial.begin(2400);
     static byte num_bits  = 0;
     static byte value = 0;
     clock = digitalRead(pin2);
     if ((clock == HIGH) && (clock1 == LOW))
            value = (value << 1) | digitalRead (pin4);
            if (++num_bits >= 8)                          // have we done 8 iterations?  If so print it out
                     Serial.print(value, HEX);
                     num_bits = 0;
                    value = 0;
    clock1= clock;
newbee_2
Just for curiosity can ISR(edge triggered) be used at that frequency
strykeroz
Reading through Rob's code,  if it loses its way, it will/should pick up the next preamble characters so long as the 4-bit boundary is maintained.  So if you've got out of sync by 1, 2 or 3 bits one way to potentially make it pick up the trail sooner is to construct a state machine looking for the pattern of bits of the preamble rather than the sequence of nibbles (which wouldn't be found if you are no longer sampling nibbles at the correct bit boundary).  Also, presuming there's a bit on every high clock pulse I'm wondering if the marked line below, will mean the first ever bit in the stream is always lost which would throw it out of sync from the start?
Code: [Select]
byte getNibble() {
    byte val = 0;
        while (digitalRead(CLOCK_PIN) == HIGH);  // <<< THIS LINE
        val <<= 1;
You do say it works, so I presume I'm wrong on that point.
Geoff
"There is no problem so bad you can't make it worse" - retired astronaut Chris Hadfield
graynomad
It might get a bit tight Geoff, after getting a nibble you have ~100uS to get back to the getNibble() function. If you don't make it you are out of sync again. I'll have a think about the timing but it may be better to put that code inline, at least that will save a function call.
Quote
I'm not sure newbee_2 is using my code.
One thing I/we didn't think of is that presumably the PC still needs to see the preamble as it doesn't know all this is happening. So after we get in sync we need to send those 6 bytes.
_____
Rob
graynomad
Quote
Yes, and that may be a good way to go. But if we're worried about having enough time interrupts will make it worse.
______
Rob
newbee_2
Ok this code is most efficient so far once it goes out of Sync in 2-3 iteration it comes back but they are saying make it like sliding window and you keep on sliding 1 bit at a time until you found the match("CAAC1F") and when found send it reaming bits(128-24=104) and again start the process. Can it be done?
Thanks and Regards
Niladri
graynomad
Quote
Which code are we talking about now?
Quote
2-3 iteration
What is an "iteration" in this context?
Quote
Can it be done?
I think that's what my example did but I haven't revisited it because I don't know if you have tried it or not.
______
Rob
newbee_2
The code on post 32.
Some time that code also looses its Sync but once it looses it comes back after 2-3 wrong value
No in that code you have checked only 32 byte and after you skip a pules but data stream is continuous so pulse skip might not possible
Code: [Select]
enum {
} states;
byte     state = PRE_0;
byte     nibble;
    nibble_count++;
    switch (state) {
        case PRE_0:
            if (nibble_count > 32) { // I made this change for my own understanding
                nibble_count = 0;
        case PRE_1:
        case PRE_2:
        case PRE_3:
        case PRE_4:
        case PRE_5:
        case DATA:
                state = PRE_0;
                nibble_count = 0;
byte getNibble() {
    byte val = 0;
          val <<= 1;
strykeroz
So if it goes out of sync it recovers with the loss of no more than 3 frames of data.  Is that acceptable to you or do you need to refine that further?
newbee_2
Hi guys I am back with another problem.
If i want to read the data exactly on each rising edge using interrupt how to approach that way???
All other things mentioned earlier still remains same ( reading "CAAC1F" and match found read the next remaining 32 bytes of data).
I have never written an ISR and pretty clueless how to set the proper register(currently i am going through the datasheet but without any background knowledge i am struggling a lot)
Any help???
Thanks in advance
Niladri
strykeroz
Hi Niladri
Can you share the code as you have it presently?
Geoff
newbee_2
Sorry this is the present code
Code: [Select]
const int DATA_LEN      =    26;
enum {
} states;
byte     state = PRE_0;
byte     nibble;
   nibble_count++;
//    Serial.print(digitalRead(CLOCK_PIN));
   switch (state) {
       case PRE_0:
               nibble_count = 0;
               if(nibble == preamble[0])
                     state = PRE_1;
                     state = PRE_0;
       case PRE_1:
           if(nibble == preamble[1])
                state = PRE_2;
                state = PRE_0;
       case PRE_2:
           if(nibble == preamble[2])
               state = PRE_3;
               state = PRE_0;
       case PRE_3:
           if(nibble == preamble[3])
              state = PRE_4;
              state = PRE_0;
       case PRE_4:
           if(nibble == preamble[4])
             state = PRE_5;
             state = PRE_0;
       case PRE_5:
           if(nibble == preamble[5])
            state = DATA;
            state = PRE_0;
       case DATA:
           Serial.print (hexAsciiVals[nibble]);
               state = PRE_0;
               nibble_count = 0;
byte getNibble() {
   byte val = 0;
         val <<= 1;
newbee_2
Finally it's working thanks everyone for their help and support without your help it would not been possible and i am posting the working code if in case anyone wants to refer it for their future use....
Thanks...
Code: [Select]
const int PACKET_BITS   =     256;
enum {
} states;
byte     state = PRE_0;
byte     nibble;
byte     firstval;
    //nibble_count++;
    switch (state) {
        case PRE_0:
//            if (nibble_count > PREAMBLE_LEN + DATA_LEN) {
//                // we've read 32 bytes and still not found a match
//                // for the preamble so skip a clock pulse
//                while (digitalRead(CLOCK_PIN) == LOW);
//                while (digitalRead(CLOCK_PIN) == HIGH);
//                nibble_count = 0;
//            } else
//                firstval = 12;
//                Serial.write(hexAsciiVals[firstval]);
                state = (nibble == preamble[0]) ? PRE_1 : PRE_0;
              //  Serial.write(hexAsciiVals[nibble]);
        case PRE_1:
           // Serial.write (hexAsciiVals[firstval]);
           // Serial.print(hexAsciiVals[12]);
            Serial.print(hexAsciiVals[nibble]);
            state = (nibble == preamble[1]) ? PRE_2 : PRE_0;
            //Serial.write (hexAsciiVals[nibble]);
        case PRE_2:
            state = (nibble == preamble[2]) ? PRE_3 : PRE_0;
        case PRE_3:
            state = (nibble == preamble[3]) ? PRE_4 : PRE_0;
        case PRE_4:
            state = (nibble == preamble[4]) ? PRE_5 : PRE_0;
        case PRE_5:
            state = (nibble == preamble[5]) ? DATA : PRE_0;
        case DATA:
                state = PRE_0;
                nibble_count = 0;
                Serial.println(' ');
            nibble_count++;
            //Serial.println();
  //  delay(10);
byte getNibble() {
    byte val = 0;
        val <<= 1;
