This seemed like an interesting problem so I spent a little time working on some code because I think you are still a long way from having a real solution.
It's a problem crying out for a state machine so here is my first pass
const int CLOCK_PIN = 2;
const int DATA_PIN = 4;
const int PACKET_BITS = 128;
const int PREAMBLE_LEN = 6;
const int DATA_LEN = ((PACKET_BITS / 4) - PREAMBLE_LEN);
enum {
PRE_0, PRE_1, PRE_2, PRE_3, PRE_4, PRE_5, DATA
} states;
byte preamble [] = {0x0C,0x0A,0x0A,0x0C,0x01,0x0F};
char hexAsciiVals[] = "0123456789ABCDEF";
byte state = PRE_0;
byte nibble;
int nibble_count = 0;
pinMode(CLOCK_PIN, INPUT);
pinMode(DATA_PIN, INPUT);
nibble = getNibble();
nibble_count++;
switch (state) {
case PRE_0:
if (nibble_count > PREAMBLE_LEN + DATA_LEN) {
// we've read 32 bytes and still not found a match
// for the preamble so skip a clock pulse
while (digitalRead(CLOCK_PIN) == HIGH);
while (digitalRead(CLOCK_PIN) == LOW);
nibble_count = 0;
state = (nibble == preamble[0]) ? PRE_0 : PRE_1;
break;
case PRE_1:
state = (nibble == preamble[1]) ? PRE_0 : PRE_2;
break;
case PRE_2:
state = (nibble == preamble[2]) ? PRE_0 : PRE_3;
break;
case PRE_3:
state = (nibble == preamble[3]) ? PRE_0 : PRE_4;
break;
case PRE_4:
state = (nibble == preamble[4]) ? PRE_0 : PRE_5;
break;
case PRE_5:
state = (nibble == preamble[5]) ? PRE_0 : DATA;
break;
case DATA:
Serial.write (hexAsciiVals[nibble]);
if (nibble_count == DATA_LEN) {
// all done, start again
state = PRE_0;
nibble_count = 0;
break;
byte getNibble() {
byte val = 0;
for (byte bit_count = 0; bit_count < 4; bit_count++) {
val <<= 1;
val |= digitalRead(DATA_PIN);
return (val &= 0x0F);
It compiles but I may have stuffed up some logic, hopefully not.
As the states are contiguous you could probably replace some of the switch() cases with a simple state++ but I think this allows for changes to be more easily implemented.
______
Rob
