Topic: I2C communication between arduino and uvga (Read 2707 times) previous topic - next topic
antho59
ok, i try this tomorrow.
you can explain me how to send multiple data by serial?
PaulS
Quote
Code: [Select]
Serial.print("This");
Serial.print("is");
Serial.print("how");
antho59
if i do this i recover just the first value on the uvga
PaulS
Quote
What is that value? "This" or "Thisishow"?
antho59
when i say value i want to say numeric value, i don't try char ascii
PaulS
You can do the same thing with numeric values.
int a=13, b=4572, c=-14;
Code: [Select]
Serial.print(a);
Serial.print(" ");
Serial.print(b);
Serial.print(" ");
Serial.print(c);
or
Code: [Select]
Serial.write(a);
Serial.write(b);
Serial.write(c);
Keep in mind that write()ing non-byte sized variables will result in multiple bytes being sent, and you must reassemble them in the correct order.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
