Topic: button (Read 2145 times) previous topic - next topic
packingtape
help
about the button,
i want when i press and hold the button the program inside int execute one, if i want to execute it again i release and press again the button.
thank in advance :)
Grumpy_Mike
Not sure what you want? Do you want some one to do it for you or tell you how to do it.
You need to read the button and hold in a while loop until it is pressed.
Do your thing
Then hold in a while loop until it is unpressed.
packingtape
Do your thing
thanks sir for the reply :)
sir can i have sample code?
my project is a gun sound effect, when i press the trigger it will sound once, until i press it again :)
Arrch
Look at the Signal Edge Detection example in the Arduino program.
packingtape
https://www.facebook.com/photo.php?v=535518566463553
sir this my project..
the problem is when i press and hold the button the sound loop, what i what is when i press and hold the button it will play once.. :)
marcello.romani
You have to detect when the button state (well, its pin actually) changes from LOW to HIGH (or viceversa). For this you have to use a prevBtnState variable anche check it against the current reading.
packingtape
sir can i have example..?
marcello.romani
Sure:
http://arduino.cc/en/Tutorial/ButtonStateChange
That section has several useful example. It's a recommended reading.
