Topic: A Dark IDE Theme (Read 27860 times) previous topic - next topic
Jerware
Sep 26, 2012, 09:46 pm Last Edit: Sep 26, 2012, 10:21 pm by Jerware Reason: 1
I took the theme from ArduOpen and modified it a bit, adding back the default icons/tabs and tweaking some colors. I figured I'd share it in case anyone else was having a hard time staring at the bright default IDE and couldn't find any good dark alternatives. Props to the ArduOpen team for their great color choices.
http://www.ledseq.com/downloads/arduino_theme.zip
EDIT: To install a theme (at least on Windows), rename the "theme" folder in your /lib folder to something else like "theme_original" and then copy the theme folder in the zip I provided into /lib instead. Restart the IDE.
oldPGMguy
leo72
Not bad but IMHO it's not as clearly readable as the original one
graynomad
I quite like that, I've always been happy with the standard white background but that's very easy on the eyes. Especially the message panel that is normally red on black and very bad for readability.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
eried
Looks cool, but black background it is not good for readability :D I am pretty sure the folks on MS did lots of tests because even if Windows Phone UI is all black for energy consumption, when you read a mail or document, background turns to white.
But this makes me wonder, maybe a theme manager is a good idea to add?  :P
My website: http://ried.cl
smilem
#5
Dec 07, 2013, 07:44 am Last Edit: Dec 07, 2013, 08:00 am by smilem Reason: 1
Here is update dark Theme, now it's easy to read.
I would like to make other colors, but it seems on windows it's not working.
int water_pump = 2;
The text "water_pump = 2;" is all same color, I would like to have number "2" representing pin number another color.
How can I change this, I edited the theme.txt, but can't find this?
Also the preferences.txt file line
# anti-aliased text, turned off by default
editor.antialias=true
Changing it makes no change either.
The white text can't be made bold either, or the line ending ";" symbol color cant be changed either. Why so many bugs on Windows 1.5.5 IDE?
Quote
P.S.
EDIT LINE "editor.bgcolor" to set desired black level. Ligh black 404040, Medium black, 363636, Very black 262626
Darker black gives more contrast, but it also stains the eyes as the character and background are very different, so experiment to your taste.
bikas
i put the theme in my /lib folder yet i see no change despite restarting the IDE. What might be the cause?
Mows
This is a lot better on my eyes, would like red or amber functions , not complaining at all;
 nice work.
Thank you
jim_beam
Current Version (1.6.12) does not start with the theme.txt, any update available?? It would be great to use the dark theme again! Thx
pert
Which theme.txt? Jerware's or smilem's version?
lornioiz
I don't know about Jim_beam, but I can't start the IDE with Smilem version (MacOsX).
pert
Here's the smilem dark theme updated to be compatible with recent Arduino IDE versions: https://github.com/per1234/ino-themes/archive/themeDark-smilem.zip.
I did make a few changes because I found the poor contrast between some of the original color settings made it very difficult to use.
I don't actually use this theme so please let me know if you find any issues or improvements at https://github.com/per1234/ino-themes. There are some new graphics files(*.svg and *@2x.png) that were not included with the original themes but it seems to work OK without them.
I'll have the Jerware theme converted soon.
pert
The Jerware theme is now updated and can be downloaded from https://github.com/per1234/ino-themes/archive/themeDark-Jerware.zip. I changed the line highlight and operator colors for contrast.
Jerware
#13
Dec 09, 2016, 07:10 pm Last Edit: Dec 09, 2016, 07:25 pm by Jerware
Thanks for doing this update.
probole
Thanks a lot.
Works fine with 1.6.12 IDE
Young guys often can't appreciate it ....yet! ;)
