Topic: Hooking up multiple LEDs and PIRs (Read 2260 times) previous topic - next topic
friendshipismagic
Hi! I am working a project consisting of many LEDs strips and PIRs. My first question is can PIR motion sensors be placed in any other pins besides  PWMs? If not, what is the biggest board that has the most PWMs? I am working with about 8 White color LED Strips and each one is independent to other strip. Also the one PIR sensor is particular is to power all the LEDs at a dimmed level, while each LED has their individual PIR to power them at full brightness. Thanks for answering my rookie questions.
Far-seeker
Pusle Width Modulation, PWM, is a form of digital output (a square wave to be exact).  For a basic PIR sensor I don't see why that would be required, all I'm familiar with just need a digital input.
I'm answering this because what you want to do with the LED strips might require PWM pins (or software PWM but I beginners should have a working understanding of hardware PWM before trying that).  It would be good to determine whether or not these strips have built-in control logic for things like dimming or patterns (some strips have it and some don't).  If they are just strings of LEDs, you will need to use PWM to dim them.
The Mega is the largest board in physical size and pin count, and it has more PWM enabled pins than the most Arduino boards (15).  However, it is significantly more expensive than an Uno or Leonardo (which have 6 and 7 PWM pins respectively).
This part shouldn't be a problem, you'll just need to have the proper conditional statements to control the LEDs based on what mode the device is in.
PaulS
Quote
Where did you get the idea that a PIR sensor was read on a PWM pin? PWM is an output capability. It has absolutely nothing to do with how an input pin behaves.
Quote
I fail to see how a PIR sensor can power any LEDs. No more than a light switch powers a light on the ceiling. If the switches powered the lights, what would we need the power company for?
Far-seeker
Quote
I read the OP as really meaning "control" when they used the word "power", an understandable novice mistake.  Yet, it is something that should be corrected because not using the proper terminology will only cause confusion.
friendshipismagic
Quote
Thanks for the correction I'll remember that.
Quote
I read a schematic on how to connect a PIR sensor to a board, and realized that the pin it was connected to was not specifically marked PWM like the rest of them. So I can assume I can use any digital pin, including those that have PWMs.
Far-seeker
Yes as mentioned in my first reply, most PIR sensors should be able to use any pin configured as a digital input.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
