Offline
Newbie
« on: September 26, 2012, 09:34:01 pm » |
Greetings, I was wondering if anyone had any experience with WaveShare's Micro SD Storage Board: http://www.wvshare.com/product/Micro-SD-Storage-Board.htmIn particular, I'm wondering how I should go about interfacing it with my stock Arduino Uno R3. I've tried the 'Diode' and 'Inline Resistor' methods outlined on: http://www.sparkfun.com/tutorials/65with no success. Any suggestions would be greatly appreciated. Peter Spierenburg.
Logged
0
Offline
Newbie
Yes.
« Reply #1 on: September 27, 2012, 01:42:24 am » |
I'm using that board right now...
I've got it plugged into the 3v3 line on my mega, works a treat. They don't recommend it but the resistor divider built in seems to work.
on the pic:
Power and Ground are 3.3v and gnd; rest of the data lines are SPI connections as regular. *(I should mention make sure to read the SPI side of the board (back silkscreen) not the SDIO (front side) for connection names)
Edit 6: After reading the sparkfun site comments, some people were having problems because 10k was too high for some sensors; try 1k in series with mosi and CLK...I probably should too. Not too worried about my 64MB microsd though.
« Last Edit: September 27, 2012, 01:55:22 am by frollard »
Logged
Offline
Newbie
« Reply #2 on: September 27, 2012, 06:55:14 am » |
Greetings,
I was a little too chicken to wire the board directly to the Arduino, especially with what it says on the Sparkfun site.
I will give it a try when I get home from work.
Thanks so much for the help! This is an awesome community!
Peter.
Logged
Offline
Newbie
« Reply #3 on: September 27, 2012, 05:27:17 pm » |
It worked like gang busters!
Thanks so much!
Logged
Offline
Newbie
« Reply #4 on: January 30, 2013, 03:35:35 am » |
Can you please list out all the resistors you use for 3.3v, GND, MISO, MOSI, SCLK, and CS?
I am new to Arduino. I am afraid that I may fry the Arduino UNO.
Thanks!!
Logged
Curitiba
Offline
Newbie
« Reply #5 on: April 17, 2013, 02:06:02 pm » |
I just received my micro sd reader and I'm having some problems to... I'm trying to use it with Arduino mega 2560 but I cant read or write on the card, I tested two diferente cards... Some help please? Thanks!
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #6 on: April 21, 2013, 04:24:24 pm » |
What code? What errors? We've hired a psychic, but he isn't due to start until the 12th of never. If you can't wait that long, you know what to do.
Logged
Offline
Newbie
« Reply #7 on: April 29, 2013, 04:53:08 am » |
Hey mate, care to provide a tad more detail on how you solved this as to help others.
Personally I also have the WS Micro sd connected to 2560 of Freeduino version with outputs set at 3.3v. DO on pin 50 DI on pin 51 CLK on pin 52 CS on pin 53
I can successfully get cardinfo to work but card writing comes back with the card failing to initialize.
Thoughts/Hints/Tips? Cheers guys
FIXED: Although it is never mentioned, SD.Begin(4) from all the uno examples should be changed to SD.begin(53)
« Last Edit: May 05, 2013, 05:13:51 am by Surge86 »
Logged
