Topic: Arduino Mega not resetting via serial [solved] (Read 764 times) previous topic - next topic
InsertTeamNameHere
Sep 28, 2012, 01:41 am Last Edit: Sep 28, 2012, 06:02 pm by InsertTeamNameHere Reason: 1
Edit: DTR actually wasn't being set low like it's supposed to be when the connection is closed. I fixed it by setting the baud rate to 0 (this also causes DTR to go low) on the connection before closing it.
I'm working on a robot for a competition, we have an Arduino Mega 1280 connected to a small computer running Ubuntu Server 12.04. we are able to reset the Arduino by opening the serial monitor in the Arduino IDE but not via our main program. We've looked at the IDE source and haven't been able to find what it does differently from ours, any help would be greatly appreciated.
Here is the code we are using to open a serial connection to the arduino.
Code: [Select]
void set_baud_rate(int baud_rate)
struct termios options;
int i;
* Get the current options for the port...
tcgetattr(fd, &options);
print_options(&options);
* Set the baud rates to 115200...
cfsetispeed(&options, baud_rate);
cfsetospeed(&options, baud_rate);
* Enable the receiver and set local mode...
options.c_cflag &= ~CSTOPB;
options.c_cflag &= ~(IXON|IXOFF);
#ifdef CRTSCTS
options.c_cflag &= ~CRTSCTS;
#else
options.c_cflag &= ~CNEW_RTSCTS;
#endif
options.c_cflag &= ~PARENB;
options.c_cflag &= ~(ICANON | ECHO | ECHOE | ISIG);
options.c_cflag &= ~(ISTRIP | IGNCR | INLCR | ICRNL
#ifdef IUCLC
| IUCLC
#endif
options.c_cflag &= ~(OPOST
#ifdef ONLCR
| ONLCR
#endif
#ifdef OCRNL
| OCRNL
#endif
#ifdef ONOCR
| ONOCR
#endif
#ifdef ONLRET
| ONLRET
#endif
options.c_iflag &= ~IXON;
options.c_iflag &= ~ICRNL;
options.c_iflag |= INPCK;
options.c_oflag &= ~ONLCR;
options.c_oflag &= ~OPOST;
options.c_iflag = INPCK;
options.c_cflag |= CS8;
options.c_cflag |= CLOCAL;
options.c_cflag |= CREAD;
options.c_cflag |= baud_rate;
options.c_lflag = 0;
if (tcsetattr(fd, TCSANOW, &options) < 0)
printf("Unable to configure serial port\n");
void close_port(void)
close(fd);
int open_port(void)
int error;
fd = open(SERIAL_PORT, O_RDWR | O_NOCTTY | O_NDELAY);
if (fd == -1)
{ //Could not open the port.
printf("open_port: Unable to open %s - ", SERIAL_PORT);
return fd;
fcntl(fd, F_SETFL, 0);
set_baud_rate(B9600);
error = close(fd);
if (error == -1)
printf("I failed at life %d times\n", errno);
return -1;
printf("Everything is fine\n");
sleep(1);
if (fd == -1)
return fd;
set_baud_rate(B115200);
sleep(4);
printf("Done opening serial port\n");
return (fd);
retrolefty
Well I can't help you with the Linux stuff, but the arduino board's auto-reset function is activated by having the serial port assert the 'DTR' control signal. Does your opening of a serial port perform that step?
Lefty
InsertTeamNameHere
It should however it seems not to be reliably doing it.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
