Topic: Problem with dc motor (Read 2041 times) previous topic - next topic
serbar
Hello.
I am newbie, i am trying to put a small dc motor working and regulate speed with PWM generated by arduino. The transistor i am using is a bc547c.
The problem is that the motor make a strange noise but doesn t spin (no its not damaged). Connected an amp to see the colector current and it increases as i increase duty cycle, but the voltage between colector and emiter stays more or less the same. Shouldn t that decrease as current increase? There is no voltage across the motor as it stays in the transistor.
Motor is a mabuchi from a car toy;
As external motor source i used 4 1,5 V batteries;
I calculated resistor base to have enough current to feed the motor according to transistor and motor datasheets.
Do you have any idea for wath is happening?
Thanks.
zachwiej
Try wider pwm pulse(analogWrite() 100-250 )  or maybe try more powerfull transistor
serbar
Thanks for reply.
Already tried TIP31C that is a power amplifier transistor. By the way it was the first i tried, before bc547c. It does exactly the same, What do you mean aboute wider PWM? Bigger than 100 DutyCycle? (Sorry if i think something absurd)
Thanks.
cr0sh
Because we are mind readers and can see your circuit...
HINT: Post a schematic and/or picture of your circuit, then maybe we can begin to help you - code might also be helpful, but maybe at a later stage.
Thanks.
You're welcome.
serbar
Here is the schematic hand made.
I will post a picture of the circuit i made.
Thanks.
serbar
Here is the picture of the circuit.
serbar
serbar
Problem solved.
It was not enough current in base to achieve saturation of transistor.
Now it works ok. I don t have any resistance in base, the rest remains the same.
Thanks.
AWOL
The maximum collector current for that part is 100mA, but your circuit shows 130mA.
Do you think that is wise?
serbar
I consulted several that sheets in the last days for BC547c, there is one, http://www.datasheetcatalog.org/datasheets/150/128380_DS.pdf,
that is 200 mA max amp on colector, and 0,5 W heat dissipation. I think the transistor i have is equivalent to this.
In saturation i have 240 mA in collector times 0,5 V voltage drop in the transistor equals 0,12 W. I think its safe and goes even more as i tried it.
The least current, for this circuit i made, for the motor to spin is 123 mA and 4,58 V voltage drop on transistor and equals to 0,56 W, a litle more than 0,5 V. Let the motor spin a couple of minutes at this condition, touched the transistor and it was not hot.
I think its more or less ok.
