Loading...
Pages: [1]   Go Down
Author Topic: Vb.Net DataReceived event doesn´t fire up on leonardo  (Read 1337 times)
Offline Offline
Newbie
View Profile
Hello everyone, recently bought an Arduino Leonardo, however I am not able to receive data on VB.net side, I can send data to Arduino but can´t receive, DataReceived event doesn´t fire on VB.NET, can someone help me, already googled and I can´t see no reason why event DataReceived isn´t working.
Here´s my Vb code :
Code:
Public Class Form1
    Public WithEvents SerialP As System.IO.Ports.SerialPort
    Private Sub Form1_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
        Try
            'GetSerialPortNames()
            SerialP = New System.IO.Ports.SerialPort
            SerialP.BaudRate = 9600
            SerialP.PortName = "COM15"
            SerialP.DataBits = 8
            SerialP.ReadTimeout = 5000
            SerialP.WriteTimeout = 5000
            SerialP.Parity = IO.Ports.Parity.None
            SerialP.StopBits = IO.Ports.StopBits.One
            SerialP.Handshake = IO.Ports.Handshake.None
            'SerialP.Encoding = System.Text.Encoding.Default 'very important!
            SerialP.Encoding = System.Text.Encoding.UTF8
            SerialP.Open()
        Catch ex As Exception
            SerialP.Close()
        End Try
    End Sub
    Public Sub SerialPort_DataReceived(ByVal sender As Object, ByVal e As System.IO.Ports.SerialDataReceivedEventArgs) Handles SerialP.DataReceived
        MessageBox.Show("")
    End Sub
    Sub GetSerialPortNames()
        ' Show all available COM ports.
        For Each sp As String In My.Computer.Ports.SerialPortNames
            'cmboComm.Items.Add(sp)
        Next
    End Sub
    Private Sub SendToSerialP()
        If SerialP.IsOpen Then
            SerialP.Write("H")
        Else
            'SerialP.Write(txtSend.Text)
        End If
    End Sub
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        SendToSerialP()
    End Sub
    Private Sub Form1_Disposed(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Disposed
        SerialP.Close()
    End Sub
End Class
And here is my Sketch :
Code:
const int ledPin = 13; // the pin that the LED is attached to
int incomingByte;      // a variable to read incoming serial data into
int counter;
  // initialize serial communication:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  establishContact();
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  counter = 0;
void establishContact() {
  while (Serial.available() <= 0) {
    Serial.print('A');   // send a capital A
    delay(300);
« Last Edit: September 27, 2012, 07:31:14 pm by ntiagobr » Logged
Offline Offline
Newbie
View Profile
Problem solved  smiley-cool, after some digging, i figured out the issue, properties SerialP.DtrEnable and SerialP.RtsEnable must both be set to True.
Thank you all anyway.
I will leave the this post, who knows, it can be useful to someone else.
Logged
Cambridge,UK
Offline Offline
Newbie
If at first you don't succeed; call it version 1.0
View Profile
WWW
Hi!
Just wanted to say thanks for posting up the solution you found, I'd been trying everything I could think of to trick the Leonardo into thinking that the connection was active, but had completely overlooked the handshaking!  smiley-red
Works a treat, thanks again!
Tom
Logged
Offline Offline
Newbie
View Profile
 smiley-grin Great! smiley-wink
I'm glad it helped, I regret there is so little help about this issue.
Logged
Pages: [1]   Go Up
Print
Jump to:
