Topic: conversion double float recieved to int? (Read 9321 times) previous topic - next topic
JHEnt
Here's my problem. Mt device sends masages with 64bit IEEE denormalized double float values. I can save the message bytes in an array. I have found a function on this forum that is supposed to take the 8 bytes and bring it down to 4 bytes floating type numbers. I'm a bit confused as to how to pass the bytes to the function. I am posting the function code from the forum below.
Code: [Select]
float conv(byte *dn)
    union {
        float f;
        byte b[4];
    } fn;
    int expd = ((dn[7] & 127) << 4) + ((dn[6] & 240) >> 4);
    int expf = expd ? (expd - 1024) + 128 : 0;
    fn.b[3] = (dn[7] & 128) + (expf >> 1);
    fn.b[2] = ((expf & 1) << 7) + ((dn[6] & 15) << 3) + ((dn[5] & 0xe0) >> 5);
    fn.b[1] = ((dn[5] & 0x1f) << 3) + ((dn[4] & 0xe0) >> 5);
    fn.b[0] = ((dn[4] & 0x1f) << 3) + ((dn[3] & 0xe0) >> 5);
   return fn.f;
I also am trying to format the data to resend out in a RTCM format. This is also confusing as it states it should be a 38bit int but says it holds +/-13,743,895.3471meters.  How does an int type data hold fractional information?
Coding Badly
Either as a fraction ... stored value / constant ... or a as fixed-point.
The two are essentially the same.  What differs is the range of the constant divisor.
(2^38) / 13743895.3471 = 2000.  So the divisor is 2000.
JHEnt
#2
Sep 28, 2012, 01:38 pm Last Edit: Sep 28, 2012, 01:44 pm by JHEnt Reason: 1
So the constant is "understood" to be 2000 by any device programmed to read the standard and the reading device will perform the conversion after it recieveds the interger value?
For the function do I pass the 8 bytes in like this?
Code: [Select]
for(int i=0; i<8; i++){
conv(&arrayName[i]);
So will this pass 8 bytes into the function and return the modified 4 bytes to array 0-3 to be read as a float type? I don't see how float f can be read out of the function.
Coding Badly
Yes.
Value From Device / 2000.0 = Value As A Human Would Understand It
(uint38_t)((Value As A Human Would Understand It * 2000.0) + 0.5) = Value As Device Would Understand It
Quote
No...
Code: [Select]
conv(&arrayName[0]);
Quote
Looks like it.
Quote
The union is the key.
JHEnt
So am I understanding this right?
Do you
Code: [Select]
float misc = conv(&storedArrayName[0]); //where 0 is the first position of the 8 bytes
This reads 8 bytes and returns a float value to variable "misc" ? I'm not seeing where the array dn[] is initialized. Or does the "dn" mean something else?
Coding Badly
#5
Sep 29, 2012, 06:36 am Last Edit: Sep 29, 2012, 06:39 am by Coding Badly Reason: 1
Do you
Code: [Select]
Yes.
Quote
This reads 8 bytes...
No.  Nothing is "read" or moved around.  Arrays are always passed "by reference" (another way of saying "by pointer").  The code you posted above and this...
Code: [Select]
float misc = conv( storedArrayName );
...produce the same result.  As does this...
Code: [Select]
float misc = conv( & storedArrayName );
I prefer the first version because I think it makes it clear that a pointer to the first element of the array is being passed.
Quote
Yes.
Quote
dn does not have any special meaning.  It is a simple parameter.  When the conv function is called, dn becomes a pointer that points to the first byte in the storedArrayName array.
It's kind of like an alias.  Outside of the conv function, the section of memory is called storedArrayName .  Inside of the conv function, the same section of memory is called dn.
In C(++), arrays and pointers are essentially interchangeable.  dn[0] and *dn and *(dn+0) all result in the first byte of the storedArrayName array.  dn[1] and *(dn+1) all result in the second byte of the storedArrayName array.
Whoever wrote conv really should have prototyped the function like this...
Code: [Select]
float conv(byte dn[8])
...to make it quite clear that an array of eight bytes is expected.
JHEnt
I am considering using a C++ compiler instead of the Arduino IDE because it alows using 64 bit double floats and 64 bit long long int. So I am thinking if I take a 64bit float, multiply it by 10000.0 to shift the decimal, then cast it to a 64 bit signed int, it should trunicate at the point of precision my application requires.
From there I am still trying to figure out what to do. I need the int to fit into a 38bit signed 2's complement type. Assuming the measurement should fit into the capability of 37 bits and a sign bit can I just pull the bytes from an array. Read the sign bit from the original 64 bit number and map it onto the 38th bit of the number I need to send? If it does fit into the 37 bit value segment then all other bits would be 0 anyway, right?
I need the 38 bit int to represent a measurement to .0001 meters. The device send this in a 64bit float value.
I really need some guidence here.
MichaelMeissner
If you are getting denormalized 64-bit floating point, then you have very little hope of processing this on the arduino that only gives you access to 32-bit floating point numbers (double and long double are the same format as float).  This is because a 64-bit denormal number is outside the range of a 32-bit floating point number.
Coding Badly
Quote
Which is?
Range?
PaulS
Quote
What do you intend to do with the resulting .o file, then?
JHEnt
#10
Oct 04, 2012, 01:18 pm Last Edit: Oct 04, 2012, 01:31 pm by JHEnt Reason: 1
Paul S, I have a C++ ide that allows AVR projects I have played with a little. I also have downloaded ATMEL's IDE but haven't really begun looking into it yet.
Coding Badly, In practice I need to measure to approx +/- 4,000,000.0001 meters. So an INT number in the +/- 100,000,000,000
Also based on the measurement of this output I would say the 64bit float is normalized? A different meassage outputs radians which would be 0.xxxxxxxx and would be denormallized?
PaulS
Quote
Each of them uses the same compiler that the Arduino IDE uses, which does NOT support 64 bit doubles or ints.
Quote
4 million meters at plus/minus one tenth of a millimeter? Get real.
JHEnt
#12
Oct 04, 2012, 01:38 pm Last Edit: Oct 04, 2012, 01:50 pm by JHEnt Reason: 1
PaulS, that is the RTCM Special Commitee 104 standard for Earth Centered Earth Fixed antenna position cooordinates. I,m just trying to make the actual measurement fit into their critera.
So what your saying is there is no way to directly work with 64 bit numbers on the 8bit AVR MCU?
I was thinking of moving up to a 32bit AVR with built in FPU but I didn't want to spend on having custom circuit boards made untill I had figured out how to make it work on something I was somewhat familiar with.
PaulS
Quote
Exactly. Nick Gammon put together a library called BigNumbers that provides the capability you seem to be looking for. It has, of course, tradeoffs. Speed being the first thing sacrificed.
MichaelMeissner
#14
Oct 04, 2012, 01:58 pm Last Edit: Oct 04, 2012, 02:04 pm by MichaelMeissner Reason: 1
In IEEE floating point, except for very small numbers, every number is normalized, which means for non-zero/special numbers, the binary exponent is set so that the top mantissa bit is always 1, and in the encoding, this bit is implicit, and not actually recorded.  The formats are:
A denormal 64-bit value has 0 in the exponent field (which is 2**-1024), and then the fractional part is the 52 bits in the mantissa.  A denormal 32-bit value has 0 in the exponent field (2**-128) and the fractional part is the 23 bit mantissa.  So if you extract the top 20 bits of the mantissa from the double and plop it into the bottom 20 out of 23 bits in the single precision, it would work.
One other thing to watch out for is the AVR is little endian, which means the least significant byte is the first byte.  If you are transmitting raw values from another computer, you might need to swap bytes, depending on whether the remote system is big endian or little endian.  Typically, if you are transmitting values in standard format, the network order is big endian, so you may need to swap bytes as you are getting them from the wire.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
