Loading...
Pages: [1]   Go Down
Author Topic: Arduino Dashboard  (Read 2001 times)
Offline Offline
Newbie
View Profile
Dear All,
I have created an Arduino Dashboard that communicates with the arduino via the serial port. It takes design command from the arduino to display controls in the main window like button, combobox, checkbox, slider and graph. It also allows the plotting of values of a single source or all analog ports (6 for now). The source is written in Visual Basic and I am working on a Linux Port. Here some pictures, the source, the exe and a demo sketch can be found on my arduino pagehttp://www.mathias-wilhelm.de/arduino:
I hope you find it useful - enjoy
Ciao, Mathias
Logged
Malaysia
Offline Offline
Newbie
A place for DIY projects
View Profile
WWW
I downloaded your file (ArduinoDashboard v1.1.0), can't find any arduino demo sketch.
Logged
Electronics and computer projects
http://ediy.com.my/
Offline Offline
Newbie
View Profile
Salut,
the demo sketch is on the project page (as it is rather short) or here:
Code:
#include <MsTimer2.h>
int bufferCount;    // Anzahl der eingelesenen Zeichen
char buffer[80];    // Serial Input-Buffer
char temp[80];
char lastpin=2;
int blinkdelay;
boolean dbOpen = false;
boolean readPort = false;
boolean sglPort = false;
int maxSequence = 1;
int sequence = 0;
int c2chrt = 0;
  for (int i=2;i<14;i++) {
    pinMode(i,OUTPUT);
  MsTimer2::set(150, t2Isr); // 500 ms period
  MsTimer2::start();
  // do nothing for the GUI handling, serial is done through interrupt
void serialEvent(){
  char ch = Serial.read();
  buffer[bufferCount] = ch;
  bufferCount++;
  if(ch == 13){
    evalSerialData();
void evalSerialData()
  int ptr;
  int val;
  strcpy(temp,"");
  if ((buffer[0]=='S')&&(buffer[bufferCount-2]=='E')) {
    strncat(temp, buffer, bufferCount-1);
    if (strcmp(temp,"SQVERSIONE")==0){
      strcpy(temp,"AC 1.0.0");
    if (strcmp(temp,"SINITE")==0){
      // setup the Dashboard
      Serial.println("STTL1Dashboard DemoE");
      Serial.println("SBTN001.0020.0040.0080.0025.Click MeE");
      Serial.println("SCKB001.0105.0040.Led 5E");
      Serial.println("SSLD001.0020.0070.0002.0013.0001.Led SwiperE");
      Serial.println("SSLD011.0020.0150.0000.0250.0025.Led FaderE");
      Serial.println("SCBO001.0020.0240.0080.0025E");
      Serial.println("SCBA001.Port A0E");
      Serial.println("SCBA001.Port A1E");
      Serial.println("SCBA001.Port A2E");
      Serial.println("SCBA001.Port A3E");
      Serial.println("SCBA001.Port A4E");
      Serial.println("SCBA001.Port A5E");
      Serial.println("SCBS001.0002E");
      c2chrt = 2;
      Serial.println("SLBL001.0250.0240.0080.0030.0.00E");
      Serial.println("SCKB011.0335.0040.Chart Timeline DataE");
      Serial.println("SCKB021.0105.0240.Show Port DataE");
      dbOpen = true;
    if (strcmp(temp,"SGoodByeE")==0){
      // stop the Dashboard
      dbOpen = false;
    if ((buffer[1]=='C')&&(buffer[2]=='K')&&(buffer[3]=='B')){
      ptr = (buffer[4]-48)*10 + (buffer[5]-48);
      if (ptr==0) {
        digitalWrite(5,((buffer[6]-48)==1));
      if (ptr==1) {
        readPort = (buffer[6]-48)==1;
      if (ptr==2) {
        sglPort = (buffer[6]-48)==1;
    if ((buffer[1]=='C')&&(buffer[2]=='B')&&(buffer[3]=='O')){
      c2chrt = buffer[12]-48;
      if ((c2chrt<0) || (c2chrt>5)) c2chrt = 0;
    if ((buffer[1]=='B')&&(buffer[2]=='T')&&(buffer[3]=='N')){
        digitalWrite(i,!(digitalRead(i)));
    if ((buffer[1]=='S')&&(buffer[2]=='L')&&(buffer[3]=='V')){
      val = (buffer[6]-48)*1000 + (buffer[7]-48)*100 + (buffer[8]-48)*10 + (buffer[9]-48);
      if (ptr==0) {
        digitalWrite(lastpin,LOW);
        lastpin=val;
        digitalWrite(lastpin,HIGH);
      if (ptr==1) {
        analogWrite(10,val);
  else {
    strcpy(temp,"BadCmd: ");
    strncat(temp, buffer, bufferCount);
    Serial.println(temp);
  bufferCount=0;
void t2Isr()
  int led_pin = 13;
  int led_pin2 = 12;
  int ar[6];
  int val;
  char dstr[40];
  switch (sequence) {
  case 0:
    for (int i=0; i<6; i++) {
      ar[i] = analogRead(i) + i * 65;
    sprintf(dstr,"STLViii.%4d.%4d.%4d.%4d.%4d.%4dE",ar[0],ar[1],ar[2],ar[3],ar[4],ar[5]);
    if (readPort) {
      if (dbOpen) {
        Serial.println(dstr);
  case 1:
    if (sglPort) {
      digitalWrite(led_pin, !digitalRead(led_pin));
      if (dbOpen) {
        val = analogRead(c2chrt);
        Serial.print("SLBV001.");
        Serial.print(millis() % 1000);
        Serial.println("E");
        Serial.print("SCHV001.");
        Serial.print(val);
  sequence++;
  if (sequence>maxSequence) sequence = 0;
The project page also documents (work in progress) the syntax.
Ciao, Mathias
Logged
Nice, France
Offline Offline
Full Member
View Profile
I agree that including the demo sketch in the download would be easier.
Havng copy-pasted the demo from your website, I got an error:
Code:
dashboard_demo:19: error: 'MsTimer2' has not been declared
I see
Code:
so I guess this library from the playground needs to be installed. It would be useful to document any libraries that need to be installed.
The dashboard looks interesting, in particular the charting function (although that part seems to be undocumented as yet).
« Last Edit: October 07, 2012, 07:12:13 am by Nantonos » Logged
Nice, France
Offline Offline
Full Member
View Profile
OK, it works. Scan ports is nice.
Pity that it shows an UNO board when I am using a Mega2560 smiley
More seriously, in the example sketch. the port dropdown shows A0 to A5, three times. Itrs not clear why; also, while ports with something connected are read corectly, ports with nothing connected display a sine wave. It would be nice to see what the random noise on an unconnected port looks like.
Logged
Offline Offline
Newbie
View Profile
Salut,
ok - the picture is a challenge ... will introduce a version query that includes the board and amend the picture  smiley-cool
I will check the port read - bad news: From the reference of the analogRead() function:
Quote
Note
If the analog input pin is not connected to anything, the value returned by analogRead() will fluctuate based on a number of factors (e.g. the values of the other analog inputs, how close your hand is to the board, etc.).
If you get near an unconnected analog pin with your finger you will see your quality as an antenna  smiley-wink
With respect to the triple set of dropdowns I have to change the code to accept a reset of the dropdown entries.
Ciao, Mathias
« Last Edit: October 07, 2012, 02:33:08 pm by GastonLagaffe » Logged
Eastern Carolina
Offline Offline
Newbie
Learning uP
View Profile
@Mathias very nice demo.
Logged
Walt
North Carolina
Pages: [1]   Go Up
Print
Jump to:
