Topic: Usare tutta la memoria dell' atmega8 (Read 2717 times) previous topic - next topic
cece99
Salve a tutti, oggi devo mettere lo sketch per il cubo led 3x3x ]:) su un atmega8, solo che lo sketch non ci sta, perchè l'ide contaggia anche lo spazio del bootloader che non c'è, io nel file boards.txt ho aggiunto questa stringa:
Code: [Select]
atmega8.name=Arduino NG or older w/ ATmega8
atmega8.upload.protocol=stk500
atmega8.upload.maximum_size=8000
atmega8.upload.speed=19200
atmega8.bootloader.low_fuses=0xdf
atmega8.bootloader.high_fuses=0xca
atmega8.bootloader.path=atmega8
atmega8.bootloader.file=ATmegaBOOT.hex
atmega8.bootloader.unlock_bits=0x3F
atmega8.bootloader.lock_bits=0x0F
atmega8.build.mcu=atmega8
atmega8.build.f_cpu=16000000L
atmega8.build.core=arduino
ma mi escono un sacco di errori quando compilo tipo questi:
Code: [Select]
In file included from ledcube.cpp:7:
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:13:22: error: WProgram.h: No such file or directory
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:19: error: expected `)' before 'size'
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:22: error: 'byte' does not name a type
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:23: error: 'byte' does not name a type
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:24: error: 'byte' does not name a type
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:26: error: 'byte' has not been declared
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:27: error: 'byte' has not been declared
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:28: error: 'byte' has not been declared
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:29: error: 'byte' has not been declared
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:30: error: 'byte' has not been declared
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:31: error: 'byte' has not been declared
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:32: error: 'byte' has not been declared
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:33: error: 'byte' has not been declared
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:34: error: 'byte' has not been declared
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:35: error: 'byte' has not been declared
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:36: error: 'byte' has not been declared
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:37: error: 'byte' has not been declared
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:38: error: 'byte' has not been declared
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:40: error: 'boolean' has not been declared
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:41: error: 'boolean' has not been declared
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:45: error: 'byte' does not name a type
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:50: error: 'byte' does not name a type
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:51: error: 'byte' does not name a type
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:52: error: 'byte' does not name a type
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:53: error: ISO C++ forbids declaration of 'byte' with no type
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:53: error: expected ';' before '*' token
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:54: error: ISO C++ forbids declaration of 'byte' with no type
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:54: error: expected ';' before '*' token
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:55: error: ISO C++ forbids declaration of 'byte' with no type
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:55: error: expected ';' before '*' token
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:56: error: 'boolean' does not name a type
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:57: error: 'boolean' does not name a type
/Users/cesare/Documents/Arduino/libraries/LedCube/LedCube.h:60: error: 'byte' has not been declared
ledcube:11: error: 'byte' does not name a type
ledcube:12: error: 'byte' does not name a type
ledcube:14: error: 'levelPins' was not declared in this scope
ledcube:14: error: 'colPins' was not declared in this scope
ledcube.cpp: In function 'void loop()':
ledcube:22: error: 'delay' was not declared in this scope
ledcube:25: error: 'byte' was not declared in this scope
ledcube:25: error: expected `;' before 'level'
ledcube:25: error: 'level' was not declared in this scope
ledcube:25: error: 'class LedCube' has no member named 'getLevels'
ledcube:27: error: expected `;' before 'col'
ledcube:27: error: 'col' was not declared in this scope
ledcube:27: error: 'class LedCube' has no member named 'getCols'
ledcube:34: error: expected `;' before 'd'
ledcube:34: error: 'd' was not declared in this scope
ledcube:36: error: expected `;' before 'l'
ledcube:36: error: 'l' was not declared in this scope
ledcube:36: error: 'class LedCube' has no member named 'getLevels'
ledcube:43: error: expected `;' before 'level'
ledcube:43: error: 'level' was not declared in this scope
ledcube:43: error: 'class LedCube' has no member named 'getLevels'
ledcube:45: error: expected `;' before 'row'
ledcube:45: error: 'row' was not declared in this scope
ledcube:45: error: 'class LedCube' has no member named 'getLevels'
ledcube:52: error: expected `;' before 'i'
ledcube:52: error: 'i' was not declared in this scope
ledcube:54: error: expected `;' before 'row'
ledcube:54: error: 'row' was not declared in this scope
ledcube:54: error: 'class LedCube' has no member named 'getLevels'
ledcube:61: error: 'random' was not declared in this scope
ledcube:64: error: expected `;' before 'x'
ledcube:64: error: 'x' was not declared in this scope
ledcube:66: error: 'class LedCube' has no member named 'getCols'
ledcube:70: error: expected `;' before 'x'
ledcube:70: error: 'x' was not declared in this scope
ledcube:72: error: 'class LedCube' has no member named 'getLevels'
ledcube:76: error: expected `;' before 'planes'
ledcube:77: error: expected `;' before 'i'
ledcube:77: error: 'i' was not declared in this scope
ledcube:79: error: expected `;' before 'p'
ledcube:79: error: 'p' was not declared in this scope
ledcube:79: error: 'planes' was not declared in this scope
ledcube:90: error: expected `;' before 'c'
ledcube:90: error: 'c' was not declared in this scope
ledcube:100: error: expected `;' before 'c'
ledcube:100: error: 'c' was not declared in this scope
ledcube:104: error: 'd' was not declared in this scope
ledcube:114: error: 'd' was not declared in this scope
ledcube:124: error: 'd' was not declared in this scope
ledcube:132: error: expected `;' before 'diamond'
ledcube:133: error: expected `;' before 'box'
ledcube:138: error: 'box' was not declared in this scope
ledcube:139: error: 'diamond' was not declared in this scope
ledcube:142: error: expected `;' before 'topSeq'
ledcube:143: error: expected `;' before 'botSeq'
ledcube:144: error: expected `;' before 'loops'
ledcube:144: error: 'loops' was not declared in this scope
ledcube:146: error: expected `;' before 's'
ledcube:146: error: 's' was not declared in this scope
ledcube:148: error: expected `;' before 'seq'
ledcube:149: error: 'seq' was not declared in this scope
ledcube:158: error: expected `;' before 'w'
ledcube:158: error: 'w' was not declared in this scope
ledcube:158: error: 'max' was not declared in this scope
ledcube:161: error: 'l' was not declared in this scope
ledcube:161: error: 'class LedCube' has no member named 'getLevels'
ledcube:162: error: 'c' was not declared in this scope
ledcube:162: error: 'class LedCube' has no member named 'getCols'
ledcube:164: error: 'class LedCube' has no member named 'getBufferAt'
ledcube:164: error: 'HIGH' was not declared in this scope
COsa posso fare?
Il Vero Programmatore non ha bisogno di manuali sull'assembler, sono<br />  sufficienti i data sheet dei microprocessori.
PaoloP
O aggiorni la libreria per essere compatibile con l'IDE 1.0 o 1.0.1 o usi l'IDE 023 o 022.
cece99
ehehemmmm sto usando la 0022
PaoloP
Allora controlla i percorsi perché l'IDE non trova le librerie di Arduino.
cece99
se io compilo x altre board va tutto a buon fine!
leo72
Se hai l'IDE 0022 quella board nel file boards.txt ce lo dovresti avere di già, non dovresti inserirlo.
Questo l'ho estratto da un vecchio boards.txt della 0022 che ho (le modifiche in grassetto sono per sfruttare tutta la memoria e per flashare il firmware usando l'arduinoISP.
Quote
atmega8.upload.maximum_size=8192
atmega8.upload.using=arduino:arduinoisp
Ah, ricordati che i kB sono composti da 1024 byte  ]:D, quindi 8192 e non 8000.
cece99
Quote
sisi, nn avevo voglia di fare i conti.
Comunque io uso mac, nel quele il programma di arduino è un unico file da 100mb, non uno zip, quindi è impossibile avere accesso alle board originali che ci sono già
leo72
Devi creare una cartella /hardware dentro alla tua cartella degli sketch, poi dentro ad essa ci crei una cartella /arduino e lì copi in un file che chiami boards.txt il contenuto che ti ho scritto.
Se mi ricordo bene i percorsi, così dovrebbe andare. Riavviando l'IDE, questa copia la boards che trova dentro alla cartella degli sketch e la fonde con quella sua.
cece99
anche facendo così mi riestituisce i medesimi errori :(
Pelletta
Prova ad assegnare un nome diverso al micro quando scrivi il nuovo txt, credo va in conflitto con la configurazione dell'atmega8 inclusa nell'ide.
Questo è quello che uso io, vedi se va...
Code: [Select]
atm8.name=ATmega8 standalone 16MHz
atm8.upload.protocol=stk500
atm8.upload.maximum_size=8192
atm8.upload.speed=19200
atm8.upload.using=arduino:arduinoisp
atm8.bootloader.low_fuses=0xdf
atm8.bootloader.high_fuses=0xca
atm8.bootloader.path=atmega8
atm8.bootloader.file=ATmegaBOOT.hex
atm8.bootloader.unlock_bits=0x3F
atm8.bootloader.lock_bits=0x0F
atm8.build.mcu=atmega8
atm8.build.f_cpu=16000000L
atm8.build.core=arduino
menniti
BUD, il nostro primo appuntamento, quanti ricordi =(
Manuale "Arduino e le tecniche di programmazione dei microcontrollori ATMEL"
http://www.michelemenniti.it/manuale_di_programmazione.html
http://www.michelemenniti.it/offerta.html
Articoli ElettronicaIN
http://www.michelemenniti.it/elettronica_in.html
Pelletta
Piangi perchè hai cotto il micro dopo le prove vero? ;)
superp
Quote
Questa cosa non mi è chiara. click destro sull'icona Arduino e mostra contenuto pacchetto. A questo punto sei dentro la cartella come se fosse un programma installato su win. Naturalmente vale per tutte le applicazionisu mac. Era questo che non riuscivi a fare?
N.
menniti
sì, non me lo posso perdonare  =( =( =(
leo72
Vero.
