Loading...
Pages: 1 [2]   Go Down
Author Topic: 6v to DC input jack seems to work fine?  (Read 2169 times)
Anaheim CA.
Offline Offline
Edison Member
Experienced old Whitebeard with a Full head of Hair...
View Profile
Indeed. My offering was simply an opinion it either fits or it doesn't as to multiplexing I chose that example on purpose to reflect the effects of multiplexing, the current drain will still be very similar, Mux'd LED's were all we had for years as indicators. Long before LCD's were more that a laboratory fantasy, They've been used in one form or another for more than 40 years of my direct knowledge. that having been said. I guess the remaining opinion I hold is that it is possible that there is a driver on board the LCD, it is there on my graphic LCD's for PWMing the backlight. 3V3 / 330 ohms = 10 mA. Impressive efficiency or base bias current for an NPN transistor? measuring the drop across the resistor should tell. Again IMO and good fuel for a discussion?
Bob
Logged
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Offline Offline
Edison Member
View Profile
Quote
Let's think it through. 5ma per segment and you have 2 segments -> 10ma per digit when that digit is on, 0ma per digit when that digit is off.
Let's say that you "mux" them 1ms per digit.
ms 1: digit 0 is on, digit 1..7 are off. Total current consumption: 10ma (for digit 0).
ms 2: digit 1 is on, digit 0, 2..7 are off. Total current consumption: 10ma (for digit 1).
ms 3: digit 2 is on, digit 0..1, 3..7 are off. Total current consumption: 10ma (for digit 2)
Do you see a pattern now? What's the new math?
Quote
You guessed right. Many of those lcds have backlight rated at 20ma max and no big difference at 10ma.
Logged
Anaheim CA.
Offline Offline
Edison Member
View Profile
I was also going to recommend that the OP look up the ecact part number of the regulator, there are graph's of dropout voltage vs load current that will serve him well as would looking at the schematic of the regulator and noticing how the reverse voltage protection is done there is a silicon diode in series with the positive DC input lead. The symbol indicates it is a junction type diode so it will have between .5 and .7 V drop across it depending on temperature and load current I just looked at the attached data sheet and again something doesn't add up right. If we accept his measured 6V at the PSU connector and (oops I just realized I don't for sure know which board he has and how it is reverse protected) a .63V typical drop across a si junction then there is 5.36V left to the regulator and according to the attached data sheet it should be out of regulation for all but the lightest loads unless there is another 1/2 volt or so present but unaccounted for. The 7V lower limit is spot on and good engineering according to the data sheet. If it were my problem I'd take a switcher and use the highest "power output" supply I had and set the output of the switcher to either 5V and supply the board directly or take the much safer route of supplying 7V to the board and let the internal supply do it's job, this also allows the switcher to be noisier that usual with no side effects as the linear regulator and attendant filtering will clean it up quite nicely. I would also use a 2A fuse and a 1.5KE6.8 Tranzorb or a 6.8V 2W Zener and a silicon diode to on the output of the switcher and slightly lower the switcher output voltage for board protection should the switcher fail, I've used a grip of LT1170's with one failure and that was caused by the power transformer being wired across a leg of a 440V 3 Phase Pump service and neutral(about 277V If I remember right) the electrician was using a defective wiggie and didn't really know what he was doing. Most switchers (All I own {5} have an area that can be soldered to a copper strap. I would use a .5mm X 50 mm piece of copper sheet metal and solder it to the area just under the actual switcher all of mine and all I've seen have a great lot of Via's at that point for heat conduction to the bottom side of the PCB and I would use a 1.5 - 2mm screw and nut W/Washer to mount it to something that would help in removing whatever excess was developed by the switcher. Efficiencies run about 90% so with a 1A load you would have to get rid of a half watt, Easy. Again just my $0.02's worth or  IMO
Bob
Logged
Offline Offline
Edison Member
View Profile
Quote
Those minimum voltage differential requirements are specified at pretty high current levels (usually at or close to the rated current levels). An arduino board will not draw anything close to that kind of current. So smaller voltage differentials will work - there are two charts in the datasheet that indirectly speak to that.
Plus, out of regulation doesn't mean it doesn't pass power anymore. It just that its ability to regulate output voltage is gone.
Logged
Anaheim CA.
Offline Offline
Edison Member
View Profile
Well it would be a nice world is that were something you could take to the bank... but "Out of Regulation" is undefined and as such is highly questionable and based more on wishful thinking than reality. The reality is that you have a very high gain DC amplifier with an unstable reference voltage. a more understandable comparison might well be that you have a really big car (The Regulator) moving across an area (output Voltage) without a driver (The Reference Voltage) High gain because the reference term is a current (Typ 100uA) controlling a regulator capable of an Ampere of current and it doesn't take a genius to figure out that 100 uA is a tenth of a milliamp and as the name implies a milliamp is 1/1000th of an ampere so we have a gain of 10 X 1000 and no stable input reference. The typical result for an NPN pass type (AKA 78XX series) is oscillation and for the PNP Pass types like the AMS1117 the reference term is a part of the load current... So there is a minimum current that must be drawn from the regulator for the regulator to be stable and a processor unfortunately doesn't fit that condition... again the result is typically oscillation. I first ran into this issue trying to shift the output voltage of an LM2931AZ-5.0 (Data sheet attached) from 5 to 6.2V. Normally the ground pin which carries the reference current for the regulator is connected to a resistor to ground and the output of the regulator is fed back to the ground pin creating a "new" Ground reference voltage and thus shifting the output voltage by the amount of voltage dropped across the resistor to ground. Simple? Right? NO because if the input voltage is slow to come to value even be as little as a hundred uS it causes the regulator to oscillate at about a MHz or so and since the output filter is a short circuit at that frequency the regulator gets hot, goes into thermal limiting, cools down and then does the whole thing again and again it can be simulated easily by placing a 10 ohm resistor in series with the supply lead and not bypassing the input... Just 10 ohms. An interesting side note is that a 78l05 plugged into the same circuit works perfectly because the 78XX series of devices uses an NPN pass transistor and the reference supply is different, internally. In short IF a Regulator isn't biased properly it's output is undetermined and really undeterminable. The Chip designer had some variables and some constants in his design, load current and Minimum reference supply voltage, If you don't meet those conditions then your circuit's response is undeterminable. This statement makes me want to ask where you buy your drugs from...
Quote
Now what can that mean? What kind of POWER DOES IT PASS... if at all. My intent here is to point out that just because it might work in basic testing is no guarantee that it will work accurately and to "Some" specification under varying input and load conditions. which is basically what you said when you said that it wasn't a "regulator" anymore the problem is that not meeting basic spec means literally that the "regulator" is more a liability than an asset. IMNSHO
Bob
Logged
Offline Offline
Edison Member
View Profile
Quote
I don't know where you got that "unstable reference voltage".
Quote
Let me be the first one to say that I have absolutely no clue what the above is talking about and I doubt you do.
Those regulators work not by amplifying some kind of current. The current" is needed to run a voltage reference / error amplifier. In the case of LM117/317 for example, that current runs the bandgap voltage reference. That current itself has nothing to do with the output current, otherwise.
The minimum voltage drop you observed is due to Vce of the regulator. In the case of a regulator regulator (like LM317 or AMS1117), it is two Vbe voltage drop as the regulator works as a follower. In the case of a true LDO, that's the Vce of a common collector amplifier.
[/quote]I first ran into this issue ...[/quote]
I have no idea what you are talking about and I doubt you do either.
Quote
The kind of power that powers your arduino.
Quote
My intent here is to point out that just because the in-output voltage differential goes below the figure specified in the datasheet doesn't mean you cannot power your arduino with it.
If you would like to discuss more on technical terms, I am happy to.
Logged
Offline Offline
Jr. Member
View Profile
Ok, I've had a chance to do some more experimenting with this. As suspected, the 6v supply just isn't enough. I noticed this by the LCD screen's behavior on the 6v supply, it was sluggish when updating and kind of glitchy. On USB or the higher voltage supplies it works normally. I tried a 7.5v 1A supply, and it put out 10v under the arduino load. Vreg chip got hot enough to get that burning feeling after checking its temp for 4-5 seconds. I found a 600ma 7.5v supply which I had to rewire for positive tip polarity, tried it out. That one had 9v under load. Unfortunately, vreg chip is still burning hot. Back to using USB cable for now, and vreg chip is running nice and cool with that. Might have to get one of those well regulated USB charger supplies, I've run out of suitable wall warts to test.
Logged
Anaheim CA.
Offline Offline
Edison Member
View Profile
As to
Quote
I wouldn't try discussing anything with an expert of your caliber... I'd be fighting with an un armed man... The regulator can't get hot on USB power... it isn't used, that's what the OP-AMP does it turns on a fet when there is no DC power applied... connecting the USB power to the board... 5V directly from the USB power... this also seems rather strange consiidering your hardware list and I quote:
Quote
To give you some sense, I have a board with the following load: 3 avrs, 1 pic, 1 1602 lcd, two hc132 oscillator (14Mhz + 70k), two hc04 oscillators (4Mhz + 12Mhz), 1 4-digit 7-segment led, 1 25Mhz oscillator, 1 14.7Mhz oscillator, one rgb led, 9 bright leds, 2 7-segment leds.
Powered from a 15v Verizon phone adapter, regulated down to 3.3v, the linear regulator (to220, no heatsink) is lukewarm. I think I measured my current consumption at one time and it was around 50ma.
50 mA would cause a small heat rise in the linear regulator a Backlight @ ~150mA would make it quite warm, uncomfortably so but not noticeable if operated from USB power as the regulator wouldn't be in circuit. I was really beginning to wonder if you would ever realize that... Small Detail. And Yes, I have forgotten more about linear regulators that you will ever learn, I made my first discrete 40 years ago... from the style of your writing I'd put you at under 30... well under, so don't even try to question my experience or knowledge until you've walked a mile in my shoes.
Bob
Logged
Offline Offline
Edison Member
View Profile
Quote
Isn't that the same year when you invented the internet?
Logged
Anaheim CA.
Offline Offline
Edison Member
View Profile
You are cute and ever so typical... that joke fell on it's face about 30 seconds after it was born... Like I said a battle with an un armed man
Bob
Logged
USA
Offline Offline
God Member
View Profile
FYI, there are well regulated power supplies other than USB chargers, some even come in wall wart form.  Generally, if the label states it's a regulated supply that can be trusted.  However, by now you should be able to verify that easily and such verification never hurts.
Logged
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
Have you looked at switching regulator wallwarts?
http://www.dipmicro.com/store/DCA-07510
These do not put out the high voltages that you seem to be seeing with your other sources.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Pages: 1 [2]   Go Up
Print
Jump to:
