Oz
Offline
God Member
« on: September 28, 2012, 05:28:40 pm » |
Ooops.
In another post I was complaining about how lower case L and the number ONE look the same. Usually capitol I has the same problem.
I was shown how to change the font and I did.
While doing this I thought to myself: "Make a backup" but as my mind set was in Arduino mode, there is no way of making commented lines.
So I couldn't/didn't.
I changed for font and it sort of worked. There is a subtle difference between l and 1 which may be enough, but the rest of the formatting is now kaput. a line of /'s becomes a bit fuzzy, and "ASCII art"/logos/headers what ever, become corrupt.
I changed two lines with the word FONT in them. One near the top and one a bit further down. I was looking for editorfont and changed the first one I saw.
I like the "Times new roman" font, and tried that.
It works, but as said other problems happen and so I may have to put up with the horrible original font. But what is/was it?
Please.
editor.font.macosx=Times,12 preproc.web_colors=true export.application.platform=true update.check=true update.id=6461665999815212812 editor.indent=true serial.stopbits=1 serial.databits=8 editor.font=Times,plain,12 editor.window.height.default=600
Logged
SF Bay Area (USA)
Offline
Faraday Member
Strongly opinionated, but not official!
« Reply #1 on: September 28, 2012, 06:41:44 pm » |
"Monospaced" is the default, I believe. You should be able to just delete that line from the preferences and have it default to the default, so to speak. I think. You really want a Fixed-Width font for coding (like Courier, and NOT like Times.) There have been some articles about this, for example: http://hivelogic.com/articles/top-10-programming-fonts/I believe that there are also complaints about the way the IDE renders fonts; not doing smoothing, or somesuch. I tried some of the fonts mentioned in the article above on my mac, and they didn't look very good.
Logged
SE USA
Offline
Faraday Member
@ssh0le
« Reply #2 on: September 28, 2012, 07:20:51 pm » |
you can change font smoothing options in preferences.txt
editor.antialias=false
Logged
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
Gosport, UK
Offline
Faraday Member
« Reply #4 on: September 29, 2012, 06:43:01 am » |
You have to use the full name of of the font. If it's called Times New Roman, then that is what you need to put in the editor.font entry.
Logged
nr Bundaberg, Australia
Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
« Reply #6 on: October 11, 2012, 01:54:33 am » |
I use DejaVu Sans Mono, it's pretty nice with a dot in the centre of the 0 so it's real easy to tell from a O.  ______ Rob
Logged
