Loading...
Pages: [1]   Go Down
Author Topic: Micro SD example - library SD "datalogger"  (Read 1765 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I'm a newbie, I have just uploaded the example sketch "datalogger" from the SD library.
I' m using an original Arduino UNO Rev 3  + Ethernet shield with SD .
Sd card funtion well, but sometime the firmare stop, without any message.
After some tests to discover where the programm didn' function, I changed the original sketch in the string declaration , in this way :
Original :
String dataString = "";
modified
String dataString = "123456789";
Now, the program function without any stop.
Could the String class occupy a lot of RAM, causing some problems ?
Is it possible that nobody was aware of this problem in the example, or I'm doing some other mistakes ?
Thanks
  SD card datalogger
 This example shows how to log data from three analog sensors
 to an SD card using the SD library.
 The circuit:
 * analog sensors on analog ins 0, 1, and 2
 * SD card attached to SPI bus as follows:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
 ** CS - pin 4
 created  24 Nov 2010
 modified 9 Apr 2012
 by Tom Igoe
 This example code is in the public domain.
#include <SD.h>
// On the Ethernet Shield, CS is pin 4. Note that even if it's not
// used as the CS pin, the hardware CS pin (10 on most Arduino boards,
// 53 on the Mega) must be left as an output or the SD library
// functions will not work.
const int chipSelect = 4;
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.print("Initializing SD card...");
  // make sure that the default chip select pin is set to
  // output, even if you don't use it:
  pinMode(10, OUTPUT);
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    return;
  Serial.println("card initialized.");
  // make a string for assembling the data to log:
  // read three sensors and append to the string:
  for (int analogPin = 0; analogPin < 3; analogPin++) {
    int sensor = analogRead(analogPin);
    dataString += String(sensor);
    if (analogPin < 2) {
      dataString += ",";
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  File dataFile = SD.open("datalog.txt", FILE_WRITE);
  // if the file is available, write to it:
  if (dataFile) {
    dataFile.println(dataString);
    dataFile.close();
    // print to the serial port too:
    Serial.println(dataString);
  // if the file isn't open, pop up an error:
  else {
    Serial.println("error opening datalog.txt");
Logged
Miramar Beach, Florida
Offline Offline
Faraday Member
View Profile
Read this topic. It covers how to initialize the SD so it won't fail.
http://arduino.cc/forum/index.php/topic,125646.0.html
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
Original :
A likely source of your problem is right there. There are major problems with the String class. Quit using it.
Logged
Offline Offline
Faraday Member
View Profile
@PaulS: That may be part of it, but this is the major problem:
Code:
  // this enables the w5100 SPI, so it will step all over the SD comm
  // but it probably won't be initialized correctly
  // because the w5100 will be answering some of the time.
    return;
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
SurferTim,
Disabling all SPI devices except the SD is required to initialize the SD.   However this may not be the problem here since the SD library make SS an output and sets it high.  For 328 chips SS is pin 10 so the code to disable w5100 is in SD.h.  For Mega this is often the problem with initialization of the SD on the Ethernet shield.
From D:/arduino-1.0.1/libraries/SD/utility/Sd2Card.cpp at line 228.
Code:
 // SS must be in output mode even it is not chip select
  pinMode(SS_PIN, OUTPUT);
  digitalWrite(SS_PIN, HIGH); // disable any SPI device using hardware SS pin
« Last Edit: October 06, 2012, 10:34:21 am by fat16lib » Logged
Offline Offline
Faraday Member
View Profile
@fat16lib: That is good to know. I try to write code that will work on all hardware. It eliminates the possibility of the problem happening to the Mega user (like me).
Logged
Pages: [1]   Go Up
Print
Jump to:
