Topic: Having trouble on solving the following tasks (Read 10911 times) previous topic - next topic
Jonraptor
if(ThermResist == Table[4][1]) ?
If the ThermResistance is = to the output shown on the table row 4, the 2nd column. Then, it will trigger the printout of the temperature on the same row on column 0
marcello.romani
I guess you ignored my previous comment then ?
Jonraptor
Lose the excess subscript increments. How so? The task mentions that i need to make a simple lookout table based on 2D array (without using the steinhart-hart equation).
AWOL
You're stepping through a lookup table, but only ever using constant subscripts.
That doesn't make sense.
Each loop has double increments on it.
You're looking for equality with floating point values.
Jonraptor
#19
Oct 04, 2012, 12:20 pm Last Edit: Oct 04, 2012, 12:31 pm by Jonraptor Reason: 1
The For loop statement is suppose to provide a loop. One for the rows(0-9), and the other for the cols(0-1). Inside both loops, i am trying to state an if statement which applies to the Thermresist if it hits on a certain point based on table[4][1] 3800, then it will trigger a printout statement. Otherwise, it continues on with its sensorval, volt, and ohm printout process. This is what i am trying to do. But it doesn't seem to work out well for me. If this doesn't make any sense to you, can you please provide an explanation on what your suggestion going to be on this occassion?
AWOL
My suggestion is to lose the the second i++ and j++ in the loops (I think I've already said this).
My suggestion is to test not for equality, but for a range of values. (I think others have said this).
I still don't know why you're looping through a table but using constant subscripts, or even why you're looping across the columns. Maybe you can answer this.
Jonraptor
Ok, i think i got it somehow working. Except it isn't as accurate as i've expected. I've followed your lead, and this is what i've done so far: -
float Vin = 5.0;
float ThermResist = 0.0;
float R2 = 10000.0;
float SensorValue = 0.0;
float Vout = 0.0;
  SensorValue = analogRead(ThermPin);
  Serial.print("Value = ");
  Serial.print(SensorValue);
  Vout = (((SensorValue+1)*Vin)/1024.0);
  Serial.print("\t Voltage = ");
  Serial.print(Vout);
  Serial.print(" V");
  ThermResist =((R2*Vin)/Vout)-R2;
  Serial.print("\t Resistance = ");
  Serial.print(ThermResist);
  Serial.println(" Ohm");
      if(ThermResist <= Table[4][1] && ThermResist >= Table[5][1])
        Serial.print(Table[4][0]);
        Serial.println(" C");
I've tried to go between those 2 values, but no luck. Except, if i've gone below Table[5][1], the printout statement have been triggered.
AWOL
Can you tell us what your expectations are, and how your observations differ?
What sort of value are you seeing for "TermResist"
Jonraptor
My expectations is, if the ThermResist values hits below 3800. At the same time, stays above 3530. A printout statement of the Temp of 29 C have been initiated. Otherwise, it will keep on repeating the sensval, volt, & ohm outputs the usual.
ThermResist records the resistance of the Thermister, by adding the static resistance with it.
AWOL
OK, I'll try one more time.
What sort of value are you seeing for "ThermResist" ? (OK, I know I spelled it wrong last time)
Jonraptor
I see the ThermResist as a float value to calculate the resistance of the Thermistor based on the voltage Output
marcello.romani
#26
Oct 04, 2012, 02:19 pm Last Edit: Oct 04, 2012, 02:22 pm by tuxduino Reason: 1
Ok, I'll repeat: you get an analog value and you search it with equality among a (small) set of predefined values. An analog value in Arduino is an integer number between 0 and 1023. If you compare it to, say, 10 values you roughly have 1% probability to "catch" it each time.
Back to your code, it's clear that you're trying to identify the type of battery based on its weight. Each battery type has a minimum and maximum weight. You want to determine in which weight range your analog value falls. For this you need to test it against the minimum and maximum value of each range. And for this you need >= and <=, not ==.
I don't understand why using a lookup table implies using (only) ==.
If you insist on using ==, you could probably make a 1024-elements lookup table and use the analogRead result as an index into it. Total waste of RAM, IMHO, but using just 1 byte per element it could be doable (you'd be using half RAM just for that...).
(edit: sorry I assumed you would search using an integer value. If you use floats, then == is _definitely out of question_)
AWOL
#27
Oct 04, 2012, 02:22 pm Last Edit: Oct 04, 2012, 02:24 pm by AWOL Reason: 1
Sigh.
"Seeing" with your actual eyes, not your mind's eye.
marcello.romani
Please copy-n-paste here what you get on the serial monitor after running your program.
Tell us why what you see is wrong, and what it should be instead.
I hope it's clear now.
Jonraptor
Yup, in a min.
Here is an output of my code: -
Value = 754.00 Voltage = 3.69 V Resistance = 3562.91 Ohm
Value = 753.00 Voltage = 3.68 V Resistance = 3580.90 Ohm
Value = 751.00 Voltage = 3.67 V Resistance = 3617.02 Ohm
Value = 755.00 Voltage = 3.69 V Resistance = 3544.97 Ohm
Value = 752.00 Voltage = 3.68 V Resistance = 3598.94 Ohm
Value = 756.00 Voltage = 3.70 V Resistance = 3527.08 Ohm
29 C
29 C
29 C
29 C
29 C
29 C
29 C
Value = 757.00 Voltage = 3.70 V Resistance = 3509.23 Ohm
29 C
29 C
Value = 758.00 Voltage = 3.71 V Resistance = 3491.44 Ohm
29 C
29 C
29 C
29 C
29 C
29 C
29 C
29 C
29 C
29 C
29 C
29 C
29 C
29 C
29 C
29 C
29 C
29 C
29 C
Value = 759.00 Voltage = 3.71 V Resistance = 3473.68 Ohm
29 C
29 C
29 C
