Loading...
Pages: [1]   Go Down
Author Topic: BUG delayMicroseconds(input), output=input/0.75  (Read 1342 times)
Lithuania
Offline Offline
Newbie
View Profile
WWW
I have a bug with the arduino 1.0.1 IDE
I have 2 brushless controllers, which require 1-2ms of pulses.
So i write BLDC_us=1500; and I get nothing, so I measured with digital signal osciloscope, and it was actually 2000us. Now I have to use Kproportional=0.75 to change it. In software 1500*0.75=1125
Well I dont like this anyway it consumes my time. smiley-cry
Please help to fix the delayMicroseconds() function
Quote
#include <IRremote.h>
#define TSOPG         49
#define TSOPV         51
#define RECV          53
#define UP            0x2C9B //Inflate duty cycle, as button T
#define DOWN          0x6C9B //Deflate duty cycle, as button W
#define POWER         0x4C9D //Turn off 0 as RED "Power" button
#define BLDC          12
int BLDC_us=1125; //1125/0.75=1500us
IRrecv irrecv(RECV);
decode_results results;
  pinMode(TSOPG, OUTPUT);
  pinMode(TSOPV, OUTPUT);
  pinMode(RECV, INPUT);
  pinMode(BLDC, OUTPUT);
  digitalWrite(TSOPG, LOW);
  digitalWrite(TSOPV, HIGH);
  irrecv.enableIRIn();          //Start the IR receiver
  if (irrecv.decode(&results)) {
    switch (results.value) {
      case UP    : BLDC_us=constrain(BLDC_us+1,750,1500); break;
      case DOWN  : BLDC_us=constrain(BLDC_us-1,750,1500); break;
      case POWER : BLDC_us=1125; break;
      default: break;
    irrecv.resume();      //Prepare to receive the next value
  digitalWrite(BLDC, HIGH);
  delayMicroseconds(BLDC_us);
  digitalWrite(BLDC, LOW);
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Note that the other instructions in loop() especially digitalwrite() also consumes time.
have a look at - http://www.arduino.cc/en/Reference/PortManipulation - for faster writing.
(especially if you prepare the bitmasks in advance).
And I would remove the constrain from the switch and use only 2 if statements.
partially patched - not tested
Code:
      case UP    : if (BLDC_us < 1500) BLDC_us++;
      case DOWN  : if (BLDC_us > 750) BLDC_us--;
      default: break;
  //digitalWrite(BLDC, HIGH);
  PORTB = highmask;
  // digitalWrite(BLDC, LOW);
  PORTB = lowmask;
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
Do you have a link to the controller?
The pulse timings you give are suspiciously like R/C PWM timings, except your code always give a low frequency 50% duty cycle, which is fairly unusual.
If it is an R/C controller, you'll get better results with the servo library.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Lithuania
Offline Offline
Newbie
View Profile
WWW
Well, i tested the stuff, before I had arduino, directly with ATmega16 and Atmel Studio, and it just receives a pulse width 1-2ms, possible minimum gap between as low as 10us.
Hobby King 100A Car ESC. But it doesent matter, the code bugs with the other ESC from Ebay. I have to keep a correction.
Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
Have you tried the Servo library?
Logged
Pages: [1]   Go Up
Print
Jump to:
