Pages: 1 [2]   Go Down
Author Topic: SOLVED - unable to make it work 1.8 SPI TFT 128x160  (Read 4339 times)
Leeds, UK
Once the magic blue smoke is released, it won't go back in!
Its a 10 ohm resistor. But the LED is rated at 3.3V with a current rating of 30mA (two LEDs of 15mA in parallel). So at 30mA, the Resistor would drop 0.3V giving the LED a voltage drop of 3V which is well within spec.
~Tom~
Thanks guys all your support.
I connected the LED pins, then I've tried out again the adafruit example and everything works now!
Big thanks to all of you!!!
Leeds, UK
I'm glad it is working for you. And I am also glad the adafruit library works with the display so you don't have to use that awful sample code!!  smiley
~Tom~
I realize this topic is months old, but I cannot get this module working.  I've hooked it up as in the original posting and all I get is a white screen.  I'm curious as to whether A0 on the lcd is actually the same as the D/C on the adafruit module and if MOSI and SDA are the same.  From what I've found online these last two are probably interchangeable.  Has anyone else gotten these to work?  I've got three of them sitting here and am at a total loss.  Thanks in advance for all the help.
Rapa Nui
Pukao hats cleaning services
The module works fine here with adafruit's libs and following wiring (328p Uno):
SW SPI:
#define sclk 4
#define mosi 5
#define cs   6
#define dc   7
#define rst  8
where dc=A0, mosi=SDA
HW SPI:
//#define sclk 13
//#define mosi 11
#define cs   10
#define dc   9
#define rst  8
P.
PS: my module has got a BGR color coding..
« Last Edit: January 07, 2013, 01:48:30 pm by pito » Logged
That configuration is working perfectly to handle the TFT. What about the card reader?  smiley-razz
Hello there i have just got the same TFT screen from ebay please could you tell me how you got it working and with some sample code as i'm pulling my hair out over it.
UK
If using the card reader then you need to connect it to SPI. MOSI, MISO and SCK to respective lines. I used D4 for the SD Card CS. If you connect the TFT to hardware SPI too (much faster update) then what I did was connect the SD card through to hardware SPI (11, 12, 13 on UNO) and then connect the TFT SDA to the SD MOSI, TFT SCL to SD SCK, then TFT CD & AO to your defined pins.
I'll try and find time to put a more comprehensive example together of how to connect it all shortly.
Please do it because I'm having alot of trouble to get it to work.
#include <SD.h>
File myFile;
int cspin = 10;
  Serial.print("Initializing SD card...");
  if (!SD.begin(cspin)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  myFile = SD.open("test.txt", FILE_WRITE);
  if (myFile) {
    Serial.print("Writing to test.txt...");
    myFile.println("Demotext.");
    myFile.close();
    Serial.println("done.");
    Serial.println("error opening test.txt");
   Serial.println( "Closed!");
//NOP
I can't make this simple piece of code to work.  The LCD is disconnected but I can perfectly use it. This is how it is wired to the arduino:
SD Reader:
SCK -> 13
MISO -> 12
MOSI -> 11
CS -> 10
I'm using a stickduino with an atmega168. The memory card is a generic one with 1GB formatted with FAT. I'm using both power connections (5v to the LCD and the 3.3v of the backlight).
Anaheim CA.
Experienced old Whitebeard with a Full head of Hair...
Isn't the SD card 3V3? that will require an interface to work properly. There are great tutorials and sample sketches from Adafruit, I bought mine there but I can't remember about the SD card.
Bob
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
UK
Don't forget that
MOSI > MISO
MISO > MOSI
One devices OUT is another devices IN.
I'll do a full schematic reminder, when I get home tonight, showing exactly how to connect this up and the example code for respective pin assignments.
I did write all the connections out, with the intention of doing this last night, but some other stud came up.
« Last Edit: January 16, 2013, 04:46:51 am by tack » Logged
Leeds, UK
Don't forget that
MOSI > MISO
MISO > MOSI
No...
MOSI -> MOSI
MISO -> MISO
MOSI = "Master OUT, Slave IN"
MISO = "Master IN, Slave OUT"
The Slave devices IN pin, connects to the Master devices OUT pin, so the Slave MOSI and Master MOSI must be connected.
This is not UART, its SPI, where data moves around in a loop containing shift registers.
~Tom~
Thanks for the replies but I've found out that the problem was due to the stickduino. I switched to an ardunino nano v3 and everything is working perfectly but now  I have another problem.
The LCD works great and so the SD card reader. But when I try to use them at the same time the LCD becomes extremely slow.  smiley-sad
Pleae take a look at this sample of code:
#define cs_lcd   10
#define cs_sd    7
#define dc       9
#define rst      8
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library
#include <SPI.h>
#include <SD.h>
Adafruit_ST7735 tft = Adafruit_ST7735(cs_lcd, dc, rst);
File myFile;
  tft.initR(INITR_REDTAB);
  tft.fillScreen(ST7735_BLACK);
  tft.setTextWrap(false);
  tft.setTextSize(5);
  tft.setTextColor(ST7735_RED, ST7735_BLACK);
  for ( int i = 0; i < 100; i++ )
    tft.setCursor(40, 50);
    tft.print( i );
    delay( 100 );
This sample of code works perfectly without any problem. But if I add a simple function to open and write data to a file it will start lagging severely:
#define cs_lcd   10
#define cs_sd    7
#define dc       9
#define rst      8
#include <SPI.h>
#include <SD.h>
File myFile;
  tft.setTextSize(5);
    tft.print( i );
    delay( 100 );
  writeCard();
void writeCard()
  if (!SD.begin(cs_sd)) {
    //Error accessing SD CARD.
    return;
  myFile = SD.open("tmp.txt", FILE_WRITE);
   if (myFile) {
    //WRITING TO FILE
    myFile.println("Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.");
    // close the file:
    myFile.close();
I though that this could have something to do with the SS, after all I'm enabling the SD pin without disabling the LCD one but still no good.  smiley-sad-blue
void writeCard()
  //TRY TO DISABLE THE LCD SS PIN
  digitalWrite( cs_lcd, HIGH );
    //Error accessing SD CARD. Re-enable LCD SS pin, force the SD SS pin to be disabled and exit.
    digitalWrite( cs_lcd, LOW );
    digitalWrite( cs_sd, HIGH );
    return;
   if (myFile) {
    //WRITING TO FILE
    // close the file:
    myFile.close();
  //Writing finished. Lets re-enable LCD SS pin and disable the SD SS pin.
I would really love not to have to hack (aka mess with)  the Sd.h but right now I feel like I've hit a wall.
Any ideas?  smiley-sad
« Last Edit: January 18, 2013, 07:35:05 am by overflow » Logged
Pages: 1 [2]   Go Up
