Author Topic: Power supply by USB with a regulated voltage source?  (Read 311 times)
I was thinking about cutting a usb cable, put 5V and Ground on an end with a regulated voltage source, and connect the other end to the Arduino USB input. Is that a bad idea? What should I do with the data cables? Connect them to the ground? With a resistor?
Thank you.
Left Coast, CA (USA)
Measurement changes behavior
Thank you.
That should work fine for powering the board. It really doesn't matter what you do with the data signal pins, I would just cut them and let them float. Keep in mind that the maximum +5vdc current avalible to the board will still be limited by the on board USB thermal fuse rated at 500ma.
Lefty
Ok great, thank you smiley-wink
Greenville, IL
Warning Novice on board! 0 to 1 chance of errors!
 I am going to try a USB power pack that I bought off of Ebay.  Here is the search category for you too consider the options. http://www.ebay.com/sch/i.html?_trksid=p5197.m570.l1313&_nkw=usb+power+pack&_sacat=0&_from=R40
