Topic: Arduino ethernet shield w 5100 wifi network (Read 2472 times) previous topic - next topic
antkan
Hello.I have arduino and ethernet w5100 shield with sd card and control my a/c.Can be converted to wireless to communicate with the modem router without network cable?With wifi shield?Thanks.
antkan
#1
Oct 01, 2012, 08:04 pm Last Edit: Feb 22, 2013, 03:19 pm by power7net Reason: 1
I control my a/c via web (webserver) or with local network.My project is inside http://www.power7.net
antkan
If i want control 10 devices (a/c) for all house via wifi can i create arduino-wifi controllers for each device?From arduino webserver send wifi signal for each device(a/c, relays)....home automation with link 2.4 GHz...any ideas?
Arrch
Convert what to wireless? The Ethernet shield? No that can't be converted to a WiFi shield. You can, however, plug it into a wireless access point or get yourself a WiFi shield.
Yes, but it would be pretty expensive. If that's not a problem, then have at it. Otherwise, you might want to consider using cheaper wireless solutions to talk to the nodes from the base station.
