Topic: None of the Analog Read Examples are working with 2560 (Read 7370 times) previous topic - next topic
rgPaiva
I tried all the examples (the basic examples ) using analog input with potentiometer, even changed to a resistor but none of them worked, the serial monitor always show 1023, and in other examples using leds, the potentiometer doesn't change led brightness. Sorry for my bad english.
AWOL
You need to tell us exactly what you wired up, and how you wired it.
rgPaiva
#2
Oct 01, 2012, 09:41 pm Last Edit: Oct 01, 2012, 09:43 pm by rgPaiva Reason: 1
 ReadAnalogVoltage
 Reads an analog input on pin 0, converts it to voltage, and prints the result to the serial monitor.
 Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
This example code is in the public domain.
// the setup routine runs once when you press reset:
 // initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
 // read the input on analog pin 0:
 int sensorValue = analogRead(A0);
 // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
 float voltage = sensorValue * (5.0 / 1023.0);
 // print out the value you read:
 Serial.println(voltage);
Following this image:
Using 110k potentiometer. But the serial always showed 1023, even using the potentiometer at the mimimum.
Also tried this example: http://arduino.cc/en/Tutorial/AnalogInOutSerial , but the potentiometer didn't changed led.
And i used other potentiometer but also, no sucess..
AWOL
From that code?
Really?
retrolefty
Well the picture doesn't tell us if you correctly identified the pot's wiper terminal to wire to the analog input pin. You should take a multimeter voltage reading from ground to the input pin to see if the voltage does change from 0 to +5vdc as you move the pot's know through its range. Also 110K ohm pot is awful large value, analog input pins work best with 10k ohm or less of source impedance.
Lefty
rgPaiva
#5
Oct 02, 2012, 08:32 pm Last Edit: Oct 02, 2012, 08:35 pm by rgPaiva Reason: 1
Lefty
I correctly identified the pot's outputs, because i  tested it on the arduino uno today , and it worked perfectly, the same code, all works fine with uno but not with this mega 2560.
AWOL
Your Fritzing diagram. (I hate 'em) doesn't appear to me to show a Mega.
retrolefty
Lefty
I can only tell you how I would approch troubleshooting this symptom. I would first take a meter and measure the actual voltage applied to the pin and see if it tracks with turning of the pot. That would give me a good indication to next look at wiring or the sketch code. If you don't own a meter you should get one soon, as anyone building even simple projects using an arduino should.
Lefty
rgPaiva
Lefty
Lefty
While the pot was connected(it was connected right) to the arduino , i used a meter to measure the voltage in the pot, while i changed the resistance value, but the output of the pot was at 5 v all the time...
AWOL
And when you disconnected the wiper from the input, and measured the voltage on the wiper..?
And when you tried a different input..?
retrolefty
Lefty
Lefty
Sounds like the ground end of the pot isn't connected correctly to arduino ground, or bad wire connection, bad pot terminal, or something of that manner. If you measure only +5vdc on the pin then your software will only read values of 1023.
rgPaiva
Lefty
Lefty
The pot is fine , i tested it on UNO, works perfectly. I connected the Pot terminals even at solder in the back of the board. NONE of the analog ports is working,but the DIGITAL are okay.
retrolefty
Well you are going to have to figure out why you only measure +5vdc at the pot's wiper pin output wired to the analog input pin, even when you turn the knob through it's range. The fact that you only see +5vdc applied to the analog input pin needs to be fixed before you can expect the 2560 board to read the pots value.
Lefty
MarkT
Have you tried replacing
with
  int sensorValue = analogRead(0);
I don't have a Mega to hand to test what A0 compiles to (its definitely done different in Arduino 1.0 from earlier Arduino softwares - I can't find the definitions in 1.0).  Perhaps its broken for Megas?  Sounds a bit unlikely though.
Denbo
It sounds like your pot is hooked up wrong or something electrical is wrong with the Mega since you said the Uno works.
Did you try running the A0 pin straight to ground?  Just to see if the Mega will report back 0?  If that works take the wire out of A0 completely and see what the results are.  'Normally' you get fluctuating values.  If it comes back as 1023 there is a problem.
