Topic: ATtiny85 + TLC5940 (Read 11849 times) previous topic - next topic
ƎR
i didn't understand how you could manage a TLC5940 with an ATtiny, did you use a library?
Riccardo Ertolupi of the Vicenza Thunders Team: http://www.VicenzaThunders.com
fungus
ATtinys have most of the capabilities of the bigger chips, just less pins.
I wrote my own library.
ƎR
great :) i was reading that there are some problems with SPI on attinys... Did you solved them? did you modify the TLC library for arduino or did you make a new one? Is that library public?
And Which core did you use to program attiny?
Thanks for the info ;)
fungus
The standard Arduino SPI library probably doesn't work, no. The tinys don't have SPI, they have USI (which is hardware support for SPI, I2C, etc.)
It's a new library. I can send you a copy, no problem...
ƎR
you haven't published it in some website yet, do you?
funkyguy4000
It would be great if you could share the library.
Accelerate to 88 miles per hour.
fungus
Nope.
Watch this space...
fungus
OK, here's a copy of my library...hope somebody finds it useful!
http://www.artlum.com/arduino/tinytlc.html
dc42
The CPU spends most of its time generating a clock output on a pin at about 4MHz (the tlc5940 needs a clock signal for the PWM). That's 100% in my book...
Why not use one of the 2 counter/timers in the ATtiny85 to generate the 4MHz clock?
fungus
#24
Dec 27, 2012, 02:44 pm Last Edit: Dec 27, 2012, 05:28 pm by fungus Reason: 1
V1.0 of the library did that... but using timers to generate the signals needs both timers and all five I/O pins to make it work. I wanted to get it down to three pins so I could attach a couple of potentiometers/switches/whatever. You could even use a timer to play music on one of the other pins if you wanted to.
Besides, what would you do with all those extra CPU cycles? :) In real life you'd probably only use 1% of them anyway (especially if you can't attach any external devices because you ran out of I/O pins - that kinda limits your processing to basic color sequencing).
Edit: I guess if you want to chain a lot of TLC5940s together the CPU power needed to update them all might become significant - even for basic color fades. In that case I'd dig out the v1.0 version of the library (and use a Tiny84 if I needed some free pins).
ƎR
thank you very much! i will try it asap! ;)
ƎR
well, i tried it and it worked very well: http://www.youtube.com/watch?v=3Br7PhvEIF0
thank you for sharing it! ;)
i had some problems because you suggested not to use millis and delays, but i see that the problems are caused only by delays, so we can use millis and micros... we just need to do the update method very often, right?
i've a question, i'm not an expert of making libraries, but to make this library work in an attiny84 do i just need to add this line?
#if defined (__AVR_ATtiny85__) || (__AVR_ATtiny84__)
or is there some register settings to do?
thanks again ;)
fungus
No problem.
It's fun to think that the teeny chip in the corner is driving something that many LEDs... :)
I don't think millis() will do anything useful. I turned off the hardware timer in setup() (if it's ticking then there's a bug!)
Time spent in between calls to update() is time the LEDs aren't lit up. I think you'd have to do a lot before you notice them get visibly dimmer, but bear it in mind.
thanks again ;)
I just tried it and there's a line in setup() that doesn't compile. The line is:
  TCCR1 = 0;
It should work if you replace that line with:
  TCCR1 = 0;
#else
  TCCR1A = TCCR1B = 0;
#endif
ƎR
yes i noticed that, and i used millis and micros to synchronize the duration of functions and other things, i think it easier to use than the method that you used in your example code... i do something like this, and it acts like a delay, but it's useful for other things too:
#define TIME 100
_time=millis();
while(millis()- _time < TIME) tlc5940.update();
  TCCR1 = 0;
  TCCR1 = 0;
#else
#endif
ok thank you, after i'll try that if i've time ;)
funkyguy4000
Whoa ?R, are those 2pin rgb fade leds or are those 4 pin rgb terminated leds?  They look to only have 2 pins.
