Topic: Replacement for AVR libc ATOMIC_BLOCK macros, now for DUE and other platforms. (Read 17115 times) previous topic - next topic
pico
#15
Oct 04, 2012, 08:25 am Last Edit: Oct 04, 2012, 10:42 am by pico Reason: 1
You are correct that break is still a valid statement, and that this would be an ever greater problem:
Yep, that's a real problem, and potentially an easy trap for the unwary to fall into. Initially, I thought it was an unlikely bug to cause real problems, but now I think this is a shortcoming with potential to cause some real grief. I don't think it unreasonable or unlikely that someone would want to protect only a section of code within a "for" or "while" loop. If that section contains a break or continue, things certainly won't work as expected anymore if using ATOMIC_BLOCK macros.
In which case, I think Pyro's alternative is looking better all the time... I'll have to get around to having a play.
WiFi shields/Yun too expensive? Embeddedcoolness.com is now selling the RFXduino nRF24L01+ <-> TCP/IP Linux gateway: Simpler, more affordable, and even more powerful wireless Internet connectivity for *all* your Arduino projects! (nRF24L01+ shield and dev board kits available too.)
pYro_65
#16
Oct 05, 2012, 05:12 am Last Edit: Oct 08, 2012, 12:58 am by pYro_65 Reason: 1
The only caveat (as far as I can tell) is placement
The Libc macro does not have the same potential problem.
This is a problem indeed, but I believe the macros do suffer too as the atomic operation doesn't take effect until the macro is encountered. I think this is entirely up to the programmer to order their code carefuly, but worth a mention in the documnetation for sure.
@WizenedEE, that is a nice example of a 'break' failure.
Its good to see a few things being discussed weren't even something I had considered.
Now that I can consider the library mildly stable after doing some tests, I can start experimenting with some new ideas.
I have implemented some nice extensions coming soon, with entirely new ways of doing things for more flexibility.
Forum Mod anyone?
https://arduino.land/Moduino/
pYro_65
#17
Oct 08, 2012, 04:17 am Last Edit: Oct 08, 2012, 04:42 am by pYro_65 Reason: 1
G'day all,
I have finished a major update to the library, it is more of an extension as the original functionality hasn't changed.
The library now supports in-line atomic operations on any kind of element* giving you greater control of how long interrupts are held. Some situations may warrant the atomic/critical section to be as short as possible, accessing 'safe' data may be better with short multiple accesses, compared to one long blocking operation. This creates a very easy interface to do so.
For example ( explanations in updated reply #1 ):
  • Atomic reads.
  • Atomic writes.
  • Atomic function calls.
  • Atomic pointer manipulation.
You can download the new code from the first post [here]. The documentation has been updated there as well as a full explanation inside the AtomicBlock.h file. There is more documentation to come, I just wanted to get a quick run down of the new features.
This uses some high level C++ techniques to accomplish safe and efficient operation. If you would like explanations of any parts of the code feel free to ask.
*Object member functions are not currently supported, next update.
Forum Mod anyone?
pYro_65
#18
Nov 02, 2012, 06:44 am Last Edit: Nov 02, 2012, 06:47 am by pYro_65 Reason: 1
As the new Due has come out, I have recently updated my AtomicBlock system to now support a few more platforms.
AtomicBlock V1.2 (beta)
Now supports:
AVR 8-bit processors
  • Arduino 8-bit family ( Compiled / Tested )
  • Teensy 2.0 ( Not Compiled / Not Tested )
  • Teensy++ 2.0 ( Not Compiled / Not Tested )
ARM Cortex-M3
  • Arduino DUE ( Compiled / Not Tested )
  • Olimex STM32 / Leaflabs Maple. ( Compiled / Not Tested )
ARM Cortex-M4
  • Teensy 3.0 ( Compiled / Not Tested )
Experimental:
AVR32
  • Initial implementation. ( Not Compiled / Not Tested )
       ASF ( AVR Software Framework )
       Reference: http://asf.atmel.com/docs/2.11.1/index.html
    GNU Toolchain support will be available soon.
PIC32
  • C++ compiler required.
The new code is posted on google code here: http://code.google.com/p/arduino-extensions/downloads/list
I have also uploaded the file to the original post [here].
Forum Mod anyone?
ajk_
Standard atomic block also has some problems with different C standards as well, I actually made a new macro that works as a one-shot to avoid the issue instead. My application for it is to wrap malloc/free/realloc so that it is IRQ safe.
You can look at what I did here: https://github.com/xxxajk/xmem2/blob/master/malloc.c
